21 Replies Latest reply on Jul 12, 2014 12:32 PM by ReubenFink
    Audition CC 2014 still crashing on startup (Mac)
    T Milner Level 1
      I had this problem with CC, and found a solution with help from the community.  The first solution involved pasting a .txt file into the preferences folder.  I tried that again with CC 2014, but it didn't work.  I wonder if this is a new problem, or does it require a different code?
      Thanks.
        • 1. Re: Audition CC 2014 still crashing on startup (Mac)
          Charles VW Adobe Employee
          please post your crash report
          • 2. Re: Audition CC 2014 still crashing on startup (Mac)
            T Milner Level 1
            Thanks.  Here's the report:
            Process:         Adobe Audition CC 2014 [997]
            Path:            /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/MacOS/Adobe Audition CC 2014
            Identifier:      com.adobe.Audition.2014.0
            Version:         7.0x118 (7.0.0)
            Code Type:       X86-64 (Native)
            Parent Process:  launchd [134]
            User ID:         501
            Date/Time:       2014-06-23 08:50:36.815 -0500
            OS Version:      Mac OS X 10.8.5 (12F45)
            Report Version:  10
            Interval Since Last Report:          21546 sec
            Crashes Since Last Report:           1
            Per-App Interval Since Last Report:  9 sec
            Per-App Crashes Since Last Report:   1
            Anonymous UUID:                      26D012B4-7E13-5C93-8E9C-932A73AA1033
            Crashed Thread:  0  Dispatch queue: com.apple.main-thread
            Exception Type:  EXC_CRASH (SIGABRT)
            Exception Codes: 0x0000000000000000, 0x0000000000000000
            Application Specific Information:
            terminate called throwing an exception
            abort() called
            Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
            0   libsystem_kernel.dylib         0x00007fff85432212 __pthread_kill + 10
            1   libsystem_c.dylib             0x00007fff8b0b4b24 pthread_kill + 90
            2   libsystem_c.dylib             0x00007fff8b0f8f61 abort + 143
            3   libc++abi.dylib               0x00007fff879c89eb abort_message + 257
            4   libc++abi.dylib               0x00007fff879c639a default_terminate() + 28
            5   libobjc.A.dylib               0x00007fff8cfff887 _objc_terminate() + 111
            6   libc++abi.dylib               0x00007fff879c63c9 safe_handler_caller(void (*)()) + 8
            7   libc++abi.dylib               0x00007fff879c6424 std::terminate() + 16
            8   libc++abi.dylib               0x00007fff879c758b __cxa_throw + 111
            9   com.adobe.auui.framework       0x00000001052e4cc8 aui::ErrorManager::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) const + 120
            10  com.adobe.dvacore.framework   0x00000001000bbb32 dvacore::config::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) + 226
            11  com.adobe.auui.framework       0x0000000105b19569 dvaui::drawbot::AGMFontData::ThrowFontError() const + 121
            12  com.adobe.auui.framework       0x0000000105b18663 dvaui::drawbot::AGMFontData::LoadFont(BIB_T_MT::CCTFontSet const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, bool) + 611
            13  com.adobe.auui.framework       0x0000000105b1832f dvaui::drawbot::AGMFontData::AGMFontData(BIB_T_MT::CCTFontSet const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, bool) + 159
            14  com.adobe.auui.framework       0x0000000105b08737 dvaui::drawbot::AGMFontInterface::AGMFontInterface(dvaui::drawbot::AGMSupplier const*, unsigned short const*, unsigned short const*, float) + 1303
            15  com.adobe.auui.framework       0x0000000105afd7e0 dvaui::drawbot::AGMSupplier::NewFont(unsigned short const*, unsigned short const*, float) const + 64
            16  com.adobe.dvaui.framework     0x0000000100521a97 dvaui::drawbot::FontP::FontP(dvaui::drawbot::SupplierInterface const*, unsigned short const*, unsigned short const*, float) + 55
            17  com.adobe.dvaui.framework     0x000000010066754f dvaui::controls::UI_StaticText::GetRecommendedSize_Helper(dvaui::drawbot::Drawbot*, boost::intrusive_ptr<dvaui::ui::Theme>, bool) const + 175
            18  com.adobe.dvaui.framework     0x0000000100667845 dvaui::controls::UI_StaticText::UI_GetRecommendedSize(dvaui::drawbot::Drawbot*) const + 53
            19  com.adobe.dvaui.framework     0x00000001007cafb8 dvaui::ui::(anonymous namespace)::LayoutNode::operator()(boost::intrusive_ptr<dvaui::ui::UI_Node>) + 536
            20  com.adobe.dvaui.framework     0x00000001007ca83a dvaui::ui::AutoLayoutSubView(boost::intrusive_ptr<dvaui::ui::UI_SubView>, dvaui::drawbot::Drawbot*) + 1386
            21  com.adobe.dvaui.framework     0x000000010079bf25 dvaui::ui::UI_SubViewAdapter::AutoLayout(dvaui::drawbot::Drawbot*, boost::intrusive_ptr<dvaui::ui::UI_Node>, boost::intrusive_ptr<dvaui::ui::UI_Node>) const + 37
            22  com.adobe.dvaui.framework     0x00000001007d27a8 dvaui::ui::UI_NodeArchive::CreateNode(boost::intrusive_ptr<dvaui::ui::UI_Node>, dvacore::proplist::PropList const&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> (std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) + 2456
            23  com.adobe.dvaui.framework     0x00000001007d30c9 dvaui::ui::UI_NodeArchive::BuildFromPropList(dvacore::proplist::PropList const&, std::map<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*, std::less<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const>, std::allocator<std::pair<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*> > >&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> (std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) + 297
            24  com.adobe.dvaui.framework     0x00000001007d364d dvaui::ui::UI_NodeBuilder::Build(dvaui::drawbot::SupplierInterface const*, std::map<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*, std::less<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const>, std::allocator<std::pair<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*> > >&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> (std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) const + 173
            25  com.adobe.dvaui.framework     0x0000000100754053 dvaui::sharedui::DVAAboutDlog::ConstructCommon(dvaui::utility::ResourceManager const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::geom::PointT<float>, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> (std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>, bool) + 1187
            26  com.adobe.dvaui.framework     0x0000000100753a62 dvaui::sharedui::DVAAboutDlog::DVAAboutDlog(dvaui::utility::ResourceManager const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::geom::PointT<float>, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> (std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>, bool) + 578
            27  com.adobe.auui.framework       0x00000001052e7973 aui::SplashScreen::SplashScreen(dvaworkspace::workspace::Workspace*, dvaui::utility::ResourceManager*) + 179
            28  com.adobe.auui.framework       0x00000001052cfebf aui::Application::GetNewSplashScreen() + 63
            29  com.adobe.exo.framework       0x0000000102139c3a exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 986
            30  com.adobe.auui.framework       0x00000001052c02fc aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 140
            31  com.adobe.auui.framework       0x00000001052e8b8d AudMacMain(int, char**) + 509
            32  com.adobe.Audition.2014.0     0x0000000100002dd7 main + 119
            33  com.adobe.Audition.2014.0     0x0000000100002c14 start + 52
            Thread 1:
            0   libsystem_kernel.dylib         0x00007fff854326d6 __workq_kernreturn + 10
            1   libsystem_c.dylib             0x00007fff8b0b5f1c _pthread_workq_return + 25
            2   libsystem_c.dylib             0x00007fff8b0b5ce3 _pthread_wqthread + 412
            3   libsystem_c.dylib             0x00007fff8b0a0191 start_wqthread + 13
            Thread 2:: Dispatch queue: com.apple.libdispatch-manager
            0   libsystem_kernel.dylib         0x00007fff85432d16 kevent + 10
            1   libdispatch.dylib             0x00007fff88d51dea _dispatch_mgr_invoke + 883
            2   libdispatch.dylib             0x00007fff88d519ee _dispatch_mgr_thread + 54
            Thread 3:
            Thread 4:
            0   libsystem_kernel.dylib         0x00007fff854320fa __psynch_cvwait + 10
            1   libsystem_c.dylib             0x00007fff8b0b7fb9 _pthread_cond_wait + 869
            2   com.apple.CoreServices.CarbonCore 0x00007fff90c70210 TSWaitOnCondition + 108
            3   com.apple.CoreServices.CarbonCore 0x00007fff90c703e7 TSWaitOnConditionTimedRelative + 132
            4   com.apple.CoreServices.CarbonCore 0x00007fff90bd2a98 MPWaitOnQueue + 252
            5   com.adobe.ACE                 0x0000000109fbf2c9 0x109f86000 + 234185
            6   com.adobe.ACE                 0x0000000109fbe5da 0x109f86000 + 230874
            7   com.apple.CoreServices.CarbonCore 0x00007fff90c477e0 PrivateMPEntryPoint + 58
            8   libsystem_c.dylib             0x00007fff8b0b3772 _pthread_start + 327
            9   libsystem_c.dylib             0x00007fff8b0a01a1 thread_start + 13
            Thread 5:
            Thread 6:
            Thread 0 crashed with X86 Thread State (64-bit):
              rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x00007fff5fbfe258  rdx: 0x0000000000000000
              rdi: 0x0000000000000c07  rsi: 0x0000000000000006  rbp: 0x00007fff5fbfe280  rsp: 0x00007fff5fbfe258
               r8: 0x00007fff75c72278   r9: 0x0000000000000000  r10: 0x0000000020000000  r11: 0x0000000000000206
              r12: 0x00007fff5fbfe3e0  r13: 0x00007fff5fbfea00  r14: 0x00007fff75c73180  r15: 0x00007fff5fbfe2c0
              rip: 0x00007fff85432212  rfl: 0x0000000000000206  cr2: 0x00007fff75c6bff0
            Logical CPU: 0
            Binary Images:
                   0x100000000 -        0x100003fff +com.adobe.Audition.2014.0 (7.0x118 - 7.0.0) <D206AD49-C98F-3775-A11C-5421FE8F336C> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/MacOS/Adobe Audition CC 2014
                   0x10000a000 -        0x10000dfff +com.adobe.AdobeCrashReporter (7.0 - 7.1.2) <68EAA7D6-B3A5-3765-BB50-E8E64E1B32EF> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                   0x100015000 -        0x10001bff7 +com.adobe.boost_date_time.framework (7.0.0 - 7.0.0.0) <031B5A2F-8B8C-3FAD-BD58-EC3580A0A428> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                   0x100032000 -        0x100040fff +com.adobe.boost_threads.framework (7.0.0 - 7.0.0.0) <9219418E-40AA-31D3-BB83-2DBA4C56F7DE> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                   0x100064000 -        0x10006ffff +com.adobe.boost_signals.framework (7.0.0 - 7.0.0.0) <C3636563-5006-3208-8982-07F84E448F64> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                   0x100087000 -        0x10008bfff +com.adobe.boost_system.framework (7.0.0 - 7.0.0.0) <012CBEA2-F04F-39FD-80F7-91DF43011F7D> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                   0x100094000 -        0x1002deff7 +com.adobe.dvacore.framework (7.0.0 - 7.0.0.0) <32ACE81E-0A2F-3117-B518-45D888CA8F3A> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                   0x100514000 -        0x10098cff7 +com.adobe.dvaui.framework (7.0.0 - 7.0.0.0) <1BADEF21-FBAA-3201-A70A-E84AA6704BF5> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                   0x100f77000 -        0x101295ff7 +com.adobe.dvaadameve.framework (7.0.0 - 7.0.0.0) <CF6F7262-D28F-3999-B9C5-0B17FE34D348> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                   0x101933000 -        0x1019e1ff7 +com.adobe.dvaworkspace.framework (7.0.0 - 7.0.0.0) <0E92ACA1-CC72-308E-B094-404F2769AF92> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                   0x101aeb000 -        0x101b26ff7 +com.adobe.dvamediatypes.framework (7.0.0 - 7.0.0.0) <79A0ADC7-405F-3355-80F4-3735D8AF1096> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                   0x101b5f000 -        0x101bccfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.5 -c 14 - 79.151805) <13002997-BD96-3A65-BFEC-09C9EB786A35> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                   0x101bff000 -        0x101d0bfff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 51 - 79.151805) <596FEA1A-3627-30B3-8AC4-BE1885788307> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                   0x101db9000 -        0x101e2efff +com.adobe.dvametadata.framework (7.0.0 - 7.0.0.0) <F9DE3D4E-A894-3FD1-8E5D-554F68B1AC46> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                   0x101ee7000 -        0x101fa0fff +com.adobe.dvametadataUI.framework (7.0.0 - 7.0.0.0) <F4CD52CA-2874-3125-845A-A5EBADDD4F0E> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                   0x1020a7000 -        0x1020feff7 +com.adobe.dvatemporalxmp.framework (7.0.0 - 7.0.0.0) <6E51E772-A111-32DA-8390-62C236BB99E5> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                   0x102137000 -        0x1021f9fff +com.adobe.exo.framework (7.0.0 - 7.0.0.0) <148783A8-780F-3251-AF8D-C0BA21F30ABB> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/exo.framework/Versions/A/exo
                   0x102350000 -        0x102370ff7 +com.adobe.dvaunittesting.framework (7.0.0 - 7.0.0.0) <97BB514A-3D86-3D7D-87A2-AE27C17B7A85> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                   0x1023b0000 -        0x1023beff7 +com.adobe.aucore.framework (1.0 - 1.0) <D49A2E8D-3498-3795-9055-504A497C6B09> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
                   0x1023d8000 -        0x1027e1fdf +com.adobe.audsp.framework (1.0 - 1.0) <C85878EB-1017-383A-B20C-1F0C94DA09B5> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
                   0x1028a1000 -        0x10295afff +com.adobe.dvaaudiofilterhost.framework (7.0.0 - 7.0.0.0) <6C61C5D0-F777-3EE7-9E8F-078CB4B0E1DC> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
                   0x102a46000 -        0x102b8ffd7 +com.adobe.auaudiocomponents.framework (1.0 - 1.0) <4B019E4E-F6F9-346F-B462-08EE758768FD> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AuAudioComponents.framework/Versions/A/AuAudioComponents
                   0x102c6e000 -        0x102cf5fff +com.adobe.dvaaudiodevice.framework (7.0.0 - 7.0.0.0) <560F0DC6-DF6E-308C-B853-CF852087C128> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                   0x102db8000 -        0x102e19ff7 +com.adobe.dvatransport.framework (7.0.0 - 7.0.0.0) <3CCBC76E-05DE-3FA1-92CB-56596117D63E> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                   0x102eb3000 -        0x102edbfff +com.adobe.dvamarshal.framework (7.0.0 - 7.0.0.0) <3F3CD31E-C603-3D0D-BDC5-5FFA7A1E25F8> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                   0x102f24000 -        0x103115ff7 +com.adobe.dynamiclink.framework (7.0.0 - 7.0.0.0) <4F9346CA-9927-3C3B-8C77-7419D5980AE8> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                   0x103376000 -        0x103427fff +com.adobe.dvaplayer.framework (7.0.0 - 7.0.0.0) <EB31C034-1D88-399E-A3BB-D48223CC69CB> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                   0x103598000 -        0x103911fef +com.adobe.aubackend.framework (1.0 - 1.0) <ECA7A25C-5D01-31D9-B2BF-1AF4C2F6CE09> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBackEnd
                   0x103cef000 -        0x103cf7fff +com.adobe.dvaundo.framework (7.0.0 - 7.0.0.0) <349BCA68-0696-34E1-8202-4EB44CD60EBA> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
                   0x103d08000 -        0x1041acfff +com.adobe.auapplication.framework (1.0 - 1.0) <DE7C45F3-E8EB-3E4E-9863-21DE83B65340> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AuApplication.framework/Versions/A/AuApplication
                   0x1045f8000 -        0x1046c9ff7 +com.adobe.auuitoolkit.framework (1.0 - 1.0) <233C0182-AC04-35BC-881B-174CEED87052> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuUIToolkit
                   0x10485e000 -        0x10491cff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.5 - 4.5.5.24321) <C111ECAF-33B8-31E9-A0CD-5E5DBFC15652> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                   0x10496c000 -        0x104a16fff +com.adobe.AdobeScCore (ScCore 4.5.5 - 4.5.5.24321) <520981E9-7761-34EA-964F-3FFB2B23FFE5> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                   0x104a5b000 -        0x104c98ff7 +com.adobe.auscripting.framework (1.0 - 1.0) <5AED0E71-0DBB-34AB-8D22-36909C168B74> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuScripting
                   0x104f43000 -        0x104f90fff +com.adobe.dvaaudiofilterhostui.framework (7.0.0 - 7.0.0.0) <B7BA93CE-C202-392F-BA50-AF9C4BA33E46> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhost ui
                   0x10502a000 -        0x105111ff7 +com.adobe.auaudiocomponentsui.framework (1.0 - 1.0) <2B28EEDC-F237-3C30-A2A2-DD8CF11BB753> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versions/A/AuAudioComponentsUI
                   0x10524d000 -        0x105e32fff +com.adobe.auui.framework (1.0 - 1.0) <A6EE2B6B-F057-3CDF-9CC9-BF89C962385B> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
                   0x1068ed000 -        0x1068fffff +com.adobe.boost_filesystem.framework (7.0.0 - 7.0.0.0) <6B71BEBE-AA81-3A06-8D78-068EE48756E1> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                   0x10691d000 -        0x1069b8ff7 +com.adobe.boost_regex.framework (7.0.0 - 7.0.0.0) <522CC0DE-203F-3F97-AB8C-EC47CAC58D32> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                   0x106a4f000 -        0x106b0bff7 +com.adobe.dvaeve.framework (7.0.0 - 7.0.0.0) <B2825BA6-8BAA-3930-916F-BDBC23EBF6B6> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                   0x106c7a000 -        0x1073f4ff7 +libmkl_intel_lp64.dylib (0) <7B0FDA28-FA31-3BAB-AE51-D59247FC50F2> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/libmkl_intel_lp64.dylib
                   0x1074b5000 -        0x107c5eff7 +libmkl_sequential.dylib (0) <F802B979-DB19-3CA5-B2E3-81CD2580E3E0> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/libmkl_sequential.dylib
                   0x107d60000 -        0x108d00fef +libmkl_core.dylib (0) <29274263-3EC2-36C8-8BB5-651B73600719> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/libmkl_core.dylib
                   0x108ece000 -        0x108efcfff  com.apple.audio.CoreAudioKit (1.6.5 - 1.6.5) <DF069200-1DBF-3137-9440-1758B47334C1> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                   0x108f17000 -        0x108fc1fff +iZotope_Radius (1) <A3438380-77F2-3391-BCB6-0310E054984D> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZotope_Radius
                   0x108ffd000 -        0x109033fff +iZotopeOmegaStreaming (1) <8C3C07FF-22B8-EFEA-62BF-DC71DAB3F836> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/iZotopeOmegaStreaming.framework/Versions/A/iZotopeOmegaStrea ming
                   0x109048000 -        0x1096affef +com.sonic.AS_Storage (5.4.17) <68FF6C5F-1703-7508-C200-3E05BADA8C57> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AS_Storage.framework/Versions/A/AS_Storage
                   0x109a61000 -        0x109aedfff +com.adobe.headlights.LogSessionFramework (7.2.1.3399) <4D4A32E1-2B7F-34AC-A310-B842CABE6080> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                   0x109b34000 -        0x109e0cfe6 +libxerces-c-3.0.dylib (0) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/libxerces-c-3.0.dylib
                   0x109f86000 -        0x10a0fffff +com.adobe.ACE (AdobeACE 2.19.18.19243 - 2.19.18.19243) <7F28B188-1D1B-20C9-BBB9-B74FCC12ECAD> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                   0x10a113000 -        0x10a83dfff +com.adobe.AGM (AdobeAGM 4.26.17.19243 - 4.26.17.19243) <62F60F9B-53EF-B531-472E-CEC0947BC869> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                   0x10a8eb000 -        0x10a90afff +com.adobe.BIB (AdobeBIB 1.2.02.19243 - 1.2.02.19243) <B7D7EE28-D604-2989-B099-62AEF4885C21> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                   0x10a912000 -        0x10a93aff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <9BDD08A8-2DD8-A570-7A7B-EDAA7097D61B> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                   0x10a942000 -        0x10aca3fef +com.adobe.CoolType (AdobeCoolType 5.10.31.19243 - 5.10.31.19243) <8BFF14FB-AA14-1CBF-C2A3-715363B5A841> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                   0x10acf1000 -        0x10acf6fff  com.apple.agl (3.2.1 - AGL-3.2.1) <F3FD497C-AEB8-35CB-92D4-1669B941435F> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                   0x10acfd000 -        0x10adf6fff +com.adobe.amtlib (8.0.0.68 - 8.0.0.68) <D3641035-0C73-3572-BB1B-2D2FBC7268F4> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                   0x10ae09000 -        0x10ae23ff7 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                   0x10ae2d000 -        0x10ae61ff7 +com.adobe.dvacontrolsurfacehost.framework (7.0.0 - 7.0.0.0) <0831A848-0476-3C2A-9BD7-DD245A51C9F5> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurface host
                   0x10aed8000 -        0x10aedafff +com.adobe.PRM.framework (7.0.0 - 7.0.0.0) <9FDC05A5-5F14-3171-BFCF-25C387135C22> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                   0x10aee2000 -        0x10af2eff7 +com.adobe.ASLFoundation.framework (7.0.0 - 7.0.0.0) <D8B2CFB2-2070-33B0-A0EF-D7B46A4B63ED> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                   0x10b016000 -        0x10b026fff +com.adobe.ASLMessaging.framework (7.0.0 - 7.0.0.0) <124B696A-519A-3B26-A259-4E6F815B0200> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
                   0x10b043000 -        0x10b052fff +com.adobe.ASLUnitTesting.framework (7.0.0 - 7.0.0.0) <514DA28A-AE72-3BF4-9564-18FB8AA3F902> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
                   0x10b071000 -        0x10b0dfff7 +com.adobe.MediaFoundation.framework (7.0.0 - 7.0.0.0) <0C99F8E8-F2AD-35A0-8883-2FAC7C3E202B> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                   0x10b185000 -        0x10b1b9ff7 +com.adobe.DisplaySurface.framework (7.0.0 - 7.0.0.0) <AF278DAB-988C-39EA-93BD-9102084B2783> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
                   0x10b208000 -        0x10b41dfe7 +com.adobe.ImageRenderer.framework (7.0.0 - 7.0.0.0) <70A262CF-39F7-3409-8461-6B781B027E10> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                   0x10b52f000 -        0x10b531fff +com.adobe.Memory.framework (7.0.0 - 7.0.0.0) <CCC9A04C-C0DD-3598-A18D-17ECE11F0545> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                   0x10b53a000 -        0x10b5b2ff7 +com.adobe.VideoFrame.framework (7.0.0 - 7.0.0.0) <FD9E0800-2B85-32AF-B373-759207297A48> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                   0x10b632000 -        0x10b656fe7 +com.mainconcept.mc.enc.dv (9.6 - 9.6.8.3415) <DDF1DA2E-1FF1-D353-0C4D-D05D7A6E28D4> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
                   0x10dfee000 -        0x10dff3ff7  libFontRegistryUI.dylib (100) <9F172961-DB6F-3A82-9F90-28F9A233F755> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
                   0x10faed000 -        0x10faeeff7  ATSHI.dylib (341.2) <8727FE94-7CED-3691-89E8-02BA300B4313> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                   0x111a0b000 -        0x111a27ff7  libJapaneseConverter.dylib (61) <D0F762C2-5372-3AA2-BBA4-066B8E4B1F8E> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                   0x111a2c000 -        0x111a3bff7  libSimplifiedChineseConverter.dylib (61) <A2B475FF-667F-3B7B-A6E9-8768347F2BD6> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                   0x111a3f000 -        0x111a51ff7  libTraditionalChineseConverter.dylib (61) <DDAFF75C-0714-34F4-818F-8B439AC7BBCA> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                   0x111a55000 -        0x111a76fff  libKoreanConverter.dylib (61) <7A601BB8-19DF-3DDC-9C50-3A798290F377> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                0x7fff66243000 -     0x7fff6627793f  dyld (210.2.3) <36CAA36E-72BC-3E48-96D9-B96A2DF77730> /usr/lib/dyld
                0x7fff84f5d000 -     0x7fff84f98fff  com.apple.LDAPFramework (2.4.28 - 194.5) <7E4F2C08-0010-34AE-BC46-149B7EE8A0F5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                0x7fff85212000 -     0x7fff852cfff7  com.apple.ColorSync (4.8.0 - 4.8.0) <6CE333AE-EDDB-3768-9598-9DB38041DC55> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                0x7fff85420000 -     0x7fff8543bff7  libsystem_kernel.dylib (2050.48.12) <4B7993C3-F62D-3AC1-AF92-414A0D6EED5E> /usr/lib/system/libsystem_kernel.dylib
                0x7fff8547f000 -     0x7fff85487fff  liblaunch.dylib (442.26.2) <2F71CAF8-6524-329E-AC56-C506658B4C0C> /usr/lib/system/liblaunch.dylib
                0x7fff8548e000 -     0x7fff860bbfff  com.apple.AppKit (6.8 - 1187.40) <F12CF463-6F88-32ED-9EBA-0FA2AD3CF576> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                0x7fff8620e000 -     0x7fff86244fff  com.apple.DebugSymbols (98 - 98) <14E788B1-4EB2-3FD7-934B-849534DFC198> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                0x7fff86245000 -     0x7fff86248fff  com.apple.help (1.3.2 - 42) <343904FE-3022-3573-97D6-5FE17F8643BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                0x7fff86501000 -     0x7fff86537fff  libsystem_info.dylib (406.17) <4FFCA242-7F04-365F-87A6-D4EFB89503C1> /usr/lib/system/libsystem_info.dylib
                0x7fff86538000 -     0x7fff86562ff7  com.apple.CoreVideo (1.8 - 99.4) <E5082966-6D81-3973-A05A-38AA5B85F886> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                0x7fff86563000 -     0x7fff86563fff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <F565B686-24E2-39F2-ACC3-C5E4084476BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                0x7fff865d0000 -     0x7fff865d5fff  com.apple.OpenDirectory (10.8 - 151.10) <CF44120B-9B01-32DD-852E-C9C0E1243FC0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                0x7fff86600000 -     0x7fff86600fff  com.apple.Cocoa (6.7 - 19) <1F77945C-F37A-3171-B22E-F7AB0FCBB4D4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                0x7fff86671000 -     0x7fff867e6fff  com.apple.CFNetwork (596.6.2 - 596.6.2) <03663F71-3E01-3958-9BBC-D7015189A4AC> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                0x7fff867e7000 -     0x7fff867ebff7  com.apple.TCC (1.0 - 1) <F2F3B753-FC73-3543-8BBE-859FDBB4D6A6> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                0x7fff86a64000 -     0x7fff86e81fff  FaceCoreLight (2.4.1) <A34C9575-C4C1-31B1-809B-7751070B4E8B> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                0x7fff86ef3000 -     0x7fff87128ff7  com.apple.CoreData (106.1 - 407.7) <24E0A6B4-9ECA-3D12-B26A-72B9DCF09768> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                0x7fff87173000 -     0x7fff871b0fef  libGLImage.dylib (8.10.1) <91E31B9B-4141-36D5-ABDC-20F1D6D1D0CF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                0x7fff871b1000 -     0x7fff871b1ffd  com.apple.audio.units.AudioUnit (1.9.2 - 1.9.2) <6D314680-7409-3BC7-A807-36341411AF9A> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                0x7fff871d5000 -     0x7fff872cafff  libiconv.2.dylib (34) <FEE8B996-EB44-37FA-B96E-D379664DEFE1> /usr/lib/libiconv.2.dylib
                0x7fff872d9000 -     0x7fff872d9fff  com.apple.vecLib (3.8 - vecLib 3.8) <6CBBFDC4-415C-3910-9558-B67176447789> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                0x7fff872da000 -     0x7fff874dafff  libicucore.A.dylib (491.11.3) <5783D305-04E8-3D17-94F7-1CEAFA975240> /usr/lib/libicucore.A.dylib
                0x7fff874e2000 -     0x7fff87541fff  com.apple.AE (645.6 - 645.6) <44F403C1-660A-3543-AB9C-3902E02F936F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                0x7fff87542000 -     0x7fff87599ff7  com.apple.ScalableUserInterface (1.0 - 1) <F1D43DFB-1796-361B-AD4B-39F1EED3BE19> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                0x7fff875cf000 -     0x7fff87600ff7  com.apple.DictionaryServices (1.2 - 184.4) <054F2D6F-9CFF-3EF1-9778-25C551B616C1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                0x7fff879c4000 -     0x7fff879c4fff  com.apple.ApplicationServices (45 - 45) <A3ABF20B-ED3A-32B5-830E-B37831A45A80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                0x7fff879c5000 -     0x7fff879eaff7  libc++abi.dylib (26) <D86169F3-9F31-377A-9AF3-DB17142052E4> /usr/lib/libc++abi.dylib
                0x7fff879f4000 -     0x7fff87a5cfff  libvDSP.dylib (380.10) <3CA154A3-1BE5-3CF4-BE48-F0A719A963BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                0x7fff87a5d000 -     0x7fff87be3fff  libBLAS.dylib (1073.4) <C102C0F6-8CB6-3B49-BA6B-2EB61F0B2784> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                0x7fff87be4000 -     0x7fff87be4fff  com.apple.Carbon (154 - 155) <1B2846B1-384E-3D1C-8999-201215723349> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                0x7fff87be5000 -     0x7fff87f44fff  com.apple.Foundation (6.8 - 945.19) <C98E55BA-553B-314B-B056-849FFB20C220> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                0x7fff87f45000 -     0x7fff87f49ff7  com.apple.CommonPanels (1.2.5 - 94) <AAC003DE-2D6E-38B7-B66B-1F3DA91E7245> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                0x7fff87f4a000 -     0x7fff87f61fff  com.apple.GenerationalStorage (1.1 - 132.3) <FD4A84B3-13A8-3C60-A59E-25A361447A17> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                0x7fff87f63000 -     0x7fff88111fff  com.apple.QuartzCore (1.8 - 304.4) <84F0B40E-DF91-36F2-9F2E-3922234206A3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                0x7fff88112000 -     0x7fff88118fff  com.apple.DiskArbitration (2.5.2 - 2.5.2) <C713A35A-360E-36CE-AC0A-25C86A3F50CA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                0x7fff88119000 -     0x7fff8821bfff  libcrypto.0.9.8.dylib (47.2) <CF3BAB7E-4972-39FD-AF92-28ACAFF0873E> /usr/lib/libcrypto.0.9.8.dylib
                0x7fff88229000 -     0x7fff882cfff7  com.apple.CoreServices.OSServices (557.6 - 557.6) <1BDB5456-0CE9-301C-99C1-8EFD0D2BFCCD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                0x7fff882d1000 -     0x7fff882d9ff7  libsystem_dnssd.dylib (379.38.1) <BDCB8566-0189-34C0-9634-35ABD3EFE25B> /usr/lib/system/libsystem_dnssd.dylib
                0x7fff882da000 -     0x7fff882e3fff  com.apple.CommerceCore (1.0 - 26.3) <870C7810-0D27-3AC5-95A0-3224BB4890C0> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                0x7fff882e4000 -     0x7fff882e4fff  libOpenScriptingUtil.dylib (148.3) <F8681222-0969-3B10-8BCE-C55A4B9C520C> /usr/lib/libOpenScriptingUtil.dylib
                0x7fff882e5000 -     0x7fff882e6fff  libDiagnosticMessagesClient.dylib (8) <8548E0DC-0D2F-30B6-B045-FE8A038E76D8> /usr/lib/libDiagnosticMessagesClient.dylib
                0x7fff882e7000 -     0x7fff88617fff  com.apple.HIToolbox (2.0 - 626.1) <656D08C2-9068-3532-ABDD-32EC5057CCB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                0x7fff88618000 -     0x7fff88664ff7  libauto.dylib (185.4) <AD5A4CE7-CB53-313C-9FAE-673303CC2D35> /usr/lib/libauto.dylib
                0x7fff886b5000 -     0x7fff886dcfff  com.apple.framework.familycontrols (4.1 - 410) <50F5A52C-8FB6-300A-977D-5CFDE4D5796B> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                0x7fff886dd000 -     0x7fff8875dff7  com.apple.ApplicationServices.ATS (341.2 - 341.2) <0EF1BB57-71AA-304D-A455-55CBE0A4983A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                0x7fff8875e000 -     0x7fff88760fff  com.apple.TrustEvaluationAgent (2.0 - 23) <A97D348B-32BF-3E52-8DF2-59BFAD21E1A3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                0x7fff8888c000 -     0x7fff8888dfff  libsystem_blocks.dylib (59) <D92DCBC3-541C-37BD-AADE-ACC75A0C59C8> /usr/lib/system/libsystem_blocks.dylib
                0x7fff8888e000 -     0x7fff888ddff7  libFontRegistry.dylib (100) <2E03D7DA-9B8F-31BB-8FB5-3D3B6272127F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                0x7fff888de000 -     0x7fff88a79fef  com.apple.vImage (6.0 - 6.0) <FAE13169-295A-33A5-8E6B-7C2CC1407FA7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                0x7fff88a7a000 -     0x7fff88b07ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <C7F43889-F8BF-3CB9-AD66-11AEFCBCEDE7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                0x7fff88b08000 -     0x7fff88b0aff7  libunc.dylib (25) <92805328-CD36-34FF-9436-571AB0485072> /usr/lib/system/libunc.dylib
                0x7fff88b0b000 -     0x7fff88b79ff7  com.apple.framework.IOKit (2.0.1 - 755.42.1) <A90038ED-48F2-3CC9-A042-53A3D7985844> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                0x7fff88b7a000 -     0x7fff88ba2fff  libJPEG.dylib (852) <4E159C31-1B41-3EFF-89EC-3F7BC9053F2C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                0x7fff88ba3000 -     0x7fff88ba5fff  com.apple.securityhi (4.0 - 55002) <26E6D477-EF61-351F-BA8C-67824AA231C6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                0x7fff88bd3000 -     0x7fff88be1fff  libcommonCrypto.dylib (60027) <BAAFE0C9-BB86-3CA7-88C0-E3CBA98DA06F> /usr/lib/system/libcommonCrypto.dylib
                0x7fff88c6f000 -     0x7fff88c7dfff  com.apple.Librarian (1.1 - 1) <5AC28666-7642-395F-A923-C6F8A274BBBD> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
                0x7fff88c96000 -     0x7fff88ca4ff7  libsystem_network.dylib (77.10) <0D99F24E-56FE-380F-B81B-4A4C630EE587> /usr/lib/system/libsystem_network.dylib
                0x7fff88ca5000 -     0x7fff88cb4fff  com.apple.opengl (1.8.10 - 1.8.10) <AD49CF56-B7C1-3598-8610-58532FC41345> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                0x7fff88cb5000 -     0x7fff88cc0ff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <C12962D5-85FB-349E-AA56-64F4F487F219> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                0x7fff88d4b000 -     0x7fff88d4cff7  libremovefile.dylib (23.2) <6763BC8E-18B8-3AD9-8FFA-B43713A7264F> /usr/lib/system/libremovefile.dylib
                0x7fff88d4d000 -     0x7fff88d62ff7  libdispatch.dylib (228.23) <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
                0x7fff88d70000 -     0x7fff88d74fff  libpam.2.dylib (20) <C8F45864-5B58-3237-87E1-2C258A1D73B8> /usr/lib/libpam.2.dylib
                0x7fff88d75000 -     0x7fff88d96fff  com.apple.Ubiquity (1.2 - 243.15) <C9A7EE77-B637-3676-B667-C0843BBB0409> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                0x7fff88d97000 -     0x7fff88dc3ff7  libRIP.A.dylib (333.1.1) <606E69AD-20AD-3517-B304-AD03F68CF47D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                0x7fff88dd1000 -     0x7fff88e2bff7  com.apple.opencl (2.2.19 - 2.2.19) <3C7DFB2C-B3F9-3447-A1FC-EAAA42181A6E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                0x7fff88e2c000 -     0x7fff88e2efff  libquarantine.dylib (52.1) <143B726E-DF47-37A8-90AA-F059CFD1A2E4> /usr/lib/system/libquarantine.dylib
                0x7fff88e57000 -     0x7fff88e6bfff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <94EDF2AB-809C-3D15-BED5-7AD45B2A7C16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                0x7fff88ebc000 -     0x7fff88ec0fff  libCGXType.A.dylib (333.1.1) <3010D3F9-C3A9-3D2E-ACDD-9020FB17482E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                0x7fff8973c000 -     0x7fff89747fff  libsystem_notify.dylib (98.5) <C49275CC-835A-3207-AFBA-8C01374927B6> /usr/lib/system/libsystem_notify.dylib
                0x7fff89748000 -     0x7fff899ecff7  com.apple.CoreImage (8.4.0 - 1.0.1) <CC6DD22B-FFC6-310B-BE13-2397A02C79EF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                0x7fff89adf000 -     0x7fff89b35fff  com.apple.HIServices (1.20 - 417) <A1129272-FEC8-350B-BA26-5A97F23C413D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                0x7fff89dd2000 -     0x7fff89dd9fff  libGFXShared.dylib (8.10.1) <B4AB9480-2CDB-34F8-8D6F-F5A2CFC221B0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                0x7fff89dda000 -     0x7fff89deffff  com.apple.ImageCapture (8.0 - 8.0) <17A45CE6-7DA3-36A5-B7EF-72BC136981AE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                0x7fff89e45000 -     0x7fff8a7d5807  com.apple.CoreGraphics (1.600.0 - 333.1.1) <E3316BA5-1A34-39B1-8FA7-97727488869B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                0x7fff8a7d6000 -     0x7fff8a8effff  com.apple.ImageIO.framework (3.2.2 - 852) <1D023BCE-1FA2-3743-B449-7489BC0C5C43> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                0x7fff8ac80000 -     0x7fff8b077fff  libLAPACK.dylib (1073.4) <D632EC8B-2BA0-3853-800A-20DA00A1091C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                0x7fff8b078000 -     0x7fff8b079ff7  libSystem.B.dylib (169.3) <9089D72D-E714-31E1-80C8-698A8E8B05AD> /usr/lib/libSystem.B.dylib
                0x7fff8b07c000 -     0x7fff8b09eff7  com.apple.Kerberos (2.0 - 1) <C49B8820-34ED-39D7-A407-A3E854153556> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                0x7fff8b09f000 -     0x7fff8b16bff7  libsystem_c.dylib (825.40.1) <543B05AE-CFA5-3EFE-8E58-77225411BA6B> /usr/lib/system/libsystem_c.dylib
                0x7fff8b177000 -     0x7fff8b196ff7  libresolv.9.dylib (51) <0882DC2D-A892-31FF-AD8C-0BB518C48B23> /usr/lib/libresolv.9.dylib
                0x7fff8b197000 -     0x7fff8b269ff7  com.apple.CoreText (260.0 - 275.17) <AB493289-E188-3CCA-8658-1E5039715F82> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                0x7fff8b2b1000 -     0x7fff8b330ff7  com.apple.securityfoundation (6.0 - 55115.4) <8676E0DF-295F-3690-BDAA-6C9C1D210B88> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                0x7fff8b331000 -     0x7fff8b331fff  com.apple.CoreServices (57 - 57) <9DD44CB0-C644-35C3-8F57-0B41B3EC147D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                0x7fff8b332000 -     0x7fff8b3b3fff  com.apple.Metadata (10.7.0 - 707.12) <69E3EEF7-8B7B-3652-8320-B8E885370E56> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                0x7fff8b3b4000 -     0x7fff8b3bafff  libmacho.dylib (829) <BF332AD9-E89F-387E-92A4-6E1AB74BD4D9> /usr/lib/system/libmacho.dylib
                0x7fff8b64f000 -     0x7fff8b6a4ff7  libTIFF.dylib (852) <0CA1662F-EB05-34DE-B9BA-0A03EC59B846> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                0x7fff8b6a5000 -     0x7fff8b7c5fff  com.apple.desktopservices (1.7.4 - 1.7.4) <ED3DA8C0-160F-3CDC-B537-BF2E766AB7C1> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                0x7fff8b7ff000 -     0x7fff8b81cff7  com.apple.openscripting (1.3.6 - 148.3) <C008F56A-1E01-3D4C-A9AF-97799D0FAE69> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                0x7fff8b81d000 -     0x7fff8b857ff7  com.apple.GSS (3.0 - 2.0) <423BDFCC-9187-3F3E-ABB0-D280003EB15E> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                0x7fff8b858000 -     0x7fff8b86bff7  libbsm.0.dylib (32) <F497D3CE-40D9-3551-84B4-3D5E39600737> /usr/lib/libbsm.0.dylib
                0x7fff8ba19000 -     0x7fff8ba47ff7  libsystem_m.dylib (3022.6) <B434BE5C-25AB-3EBD-BAA7-5304B34E3441> /usr/lib/system/libsystem_m.dylib
                0x7fff8ba54000 -     0x7fff8ba58fff  libCoreVMClient.dylib (32.5) <DB009CD4-BB0E-3331-BBB4-A118781D193F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                0x7fff8ba59000 -     0x7fff8ba63fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <D803919C-3102-3515-A178-61E9C86C46A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                0x7fff8ba64000 -     0x7fff8ba66fff  libCVMSPluginSupport.dylib (8.10.1) <F0239392-E0CB-37D7-BFE2-D6F5D42F9196> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                0x7fff8ba67000 -     0x7fff8bae9ff7  com.apple.Heimdal (3.0 - 2.0) <ACF0C667-5ACC-382A-A998-61E85386C814> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                0x7fff8baea000 -     0x7fff8bb53fff  libstdc++.6.dylib (56) <EAA2B53E-EADE-39CF-A0EF-FB9D4940672A> /usr/lib/libstdc++.6.dylib
                0x7fff8bba0000 -     0x7fff8bbcbfff  libxslt.1.dylib (11.3) <441776B8-9130-3893-956F-39C85FFA644F> /usr/lib/libxslt.1.dylib
                0x7fff8bbcc000 -     0x7fff8bbe3fff  libGL.dylib (8.10.1) <F8BABA3C-7810-3A65-83FC-61945AA50E90> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                0x7fff8bbe4000 -     0x7fff8bc82ff7  com.apple.ink.framework (10.8.2 - 150) <84B9825C-3822-375F-BE58-A753444FBDE2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                0x7fff8bc8d000 -     0x7fff8bc9cff7  libxar.1.dylib (105) <370ED355-E516-311E-BAFD-D80633A84BE1> /usr/lib/libxar.1.dylib
                0x7fff8bc9d000 -     0x7fff8bcaeff7  libsasl2.2.dylib (166) <649CAE0E-8FFE-3C60-A849-BE6300E4B726> /usr/lib/libsasl2.2.dylib
                0x7fff8bcaf000 -     0x7fff8bd1cff7  com.apple.datadetectorscore (4.1 - 269.3) <5775F0DB-87D6-310D-8B03-E2AD729EFB28> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                0x7fff8bece000 -     0x7fff8becfff7  libdnsinfo.dylib (453.19) <14202FFB-C3CA-3FCC-94B0-14611BF8692D> /usr/lib/system/libdnsinfo.dylib
                0x7fff8bf70000 -     0x7fff8bf7dfff  libbz2.1.0.dylib (29) <CE9785E8-B535-3504-B392-82F0064D9AF2> /usr/lib/libbz2.1.0.dylib
                0x7fff8c026000 -     0x7fff8c089fff  com.apple.audio.CoreAudio (4.1.2 - 4.1.2) <FEAB83AB-1DE5-3813-BA48-7A7F2374CCF0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                0x7fff8c095000 -     0x7fff8c147ff7  com.apple.LaunchServices (539.11 - 539.11) <A86F44E5-F285-3029-A5D1-00CD3C231A08> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                0x7fff8cbbf000 -     0x7fff8ce90fff  com.apple.security (7.0 - 55179.16.1) <49A6A8FD-124D-30E0-94C3-C73F8C9469E6> /System/Library/Frameworks/Security.framework/Versions/A/Security
                0x7fff8ce91000 -     0x7fff8cf8efff  libsqlite3.dylib (138.1) <ADE9CB98-D77D-300C-A32A-556B7440769F> /usr/lib/libsqlite3.dylib
                0x7fff8cfee000 -     0x7fff8d10692f  libobjc.A.dylib (532.2) <90D31928-F48D-3E37-874F-220A51FD9E37> /usr/lib/libobjc.A.dylib
                0x7fff8d107000 -     0x7fff8d10cfff  libcompiler_rt.dylib (30) <08F8731D-5961-39F1-AD00-4590321D24A9> /usr/lib/system/libcompiler_rt.dylib
                0x7fff8d10d000 -     0x7fff8d111fff  com.apple.IOSurface (86.0.4 - 86.0.4) <26F01CD4-B76B-37A3-989D-66E8140542B3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                0x7fff8d112000 -     0x7fff8d129fff  com.apple.CFOpenDirectory (10.8 - 151.10) <10F41DA4-AD54-3F52-B898-588D9A117171> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                0x7fff8d12a000 -     0x7fff8d186ff7  com.apple.Symbolication (1.3 - 93) <97F3B1D2-D81D-3F37-87B3-B9A686124CF5> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                0x7fff8d43d000 -     0x7fff8d53aff7  libxml2.2.dylib (22.3) <47B09CB2-C636-3024-8B55-6040F7829B4C> /usr/lib/libxml2.2.dylib
                0x7fff8d53b000 -     0x7fff8d583fff  libcurl.4.dylib (69.2.71) <F52E1881-A425-3AE9-8386-A434F10AE0A2> /usr/lib/libcurl.4.dylib
                0x7fff8e544000 -     0x7fff8e552ff7  libkxld.dylib (2050.48.12) <B8F7ED1F-CF84-3777-9183-0A1C513DF81F> /usr/lib/system/libkxld.dylib
                0x7fff8e553000 -     0x7fff8e596ff7  com.apple.RemoteViewServices (2.0 - 80.6) <5CFA361D-4853-3ACC-9EFC-A2AC1F43BA4B> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                0x7fff8e597000 -     0x7fff8e59efff  com.apple.NetFS (5.0 - 4.0) <82E24B9A-7742-3DA3-9E99-ED267D98C05E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                0x7fff8e62d000 -     0x7fff8e739fff  libFontParser.dylib (84.7) <C3D1121B-B066-34C3-9D31-ADDF387C0B20> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                0x7fff8e73a000 -     0x7fff8e924ff7  com.apple.CoreFoundation (6.8 - 744.19) <0F7403CA-2CB8-3D0A-992B-679701DF27CA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                0x7fff8eaaf000 -     0x7fff8eab5ff7  libunwind.dylib (35.1) <21703D36-2DAB-3D8B-8442-EAAB23C060D3> /usr/lib/system/libunwind.dylib
                0x7fff8eab6000 -     0x7fff8ebb8fff  libJP2.dylib (852) <01E502E9-7FD3-3A5D-8EA4-2DC8C56E0497> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                0x7fff8ebb9000 -     0x7fff8ebb9fff  libkeymgr.dylib (25) <CC9E3394-BE16-397F-926B-E579B60EE429> /usr/lib/system/libkeymgr.dylib
                0x7fff8ecd1000 -     0x7fff8ed10ff7  com.apple.QD (3.42.1 - 285.1) <77A20C25-EBB5-341C-A05C-5D458B97AD5C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                0x7fff8ef5c000 -     0x7fff8ef67fff  com.apple.CommonAuth (3.0 - 2.0) <1CA95702-DDC7-3ADB-891E-7F037ABDDA14> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                0x7fff8ef68000 -     0x7fff8efacfff  libcups.2.dylib (327.7) <9F35B58A-F47E-348A-8E09-E235FA4B9270> /usr/lib/libcups.2.dylib
                0x7fff8efc8000 -     0x7fff8efcdfff  libcache.dylib (57) <65187C6E-3FBF-3EB8-A1AA-389445E2984D> /usr/lib/system/libcache.dylib
                0x7fff8f05f000 -     0x7fff8f0a2ff7  com.apple.bom (12.0 - 192) <0BF1F2D2-3648-36B7-BE4B-551A0173209B> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                0x7fff8f0a3000 -     0x7fff8f13dfff  libvMisc.dylib (380.10) <A7F12764-A94C-36EB-88E0-F826F5AF55B4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                0x7fff8f13e000 -     0x7fff8f154fff  com.apple.MultitouchSupport.framework (237.4 - 237.4) <0F7FEE29-161B-3D8E-BE91-308CBD354461> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                0x7fff8f155000 -     0x7fff8f167ff7  libz.1.dylib (43) <2A1551E8-A272-3DE5-B692-955974FE1416> /usr/lib/libz.1.dylib
                0x7fff8f711000 -     0x7fff8f762ff7  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <A4341BBD-A330-3A57-8891-E9C1A286A72D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                0x7fff8f763000 -     0x7fff8f76afff  libcopyfile.dylib (89) <876573D0-E907-3566-A108-577EAD1B6182> /usr/lib/system/libcopyfile.dylib
                0x7fff8f823000 -     0x7fff8f851fff  com.apple.CoreServicesInternal (154.4 - 154.4) <EE77C328-BCC7-3EBD-B3BC-E0E48537D4FF> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                0x7fff8f852000 -     0x7fff8f9a4fff  com.apple.audio.toolbox.AudioToolbox (1.9.2 - 1.9.2) <DC5F3D1B-036A-37DE-BC24-7636DC95EA1C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                0x7fff8f9ed000 -     0x7fff8f9edfff  com.apple.Accelerate (1.8 - Accelerate 1.8) <878A6E7E-CB34-380F-8212-47FBF12C7C96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                0x7fff8fe69000 -     0x7fff8fea2ff7  libssl.0.9.8.dylib (47.2) <46DF85DC-18FB-3108-91F6-52AE3EBF2347> /usr/lib/libssl.0.9.8.dylib
                0x7fff8fee4000 -     0x7fff8fef1fff  com.apple.AppleFSCompression (49 - 1.0) <5508344A-2A7E-3122-9562-6F363910A80E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                0x7fff904a0000 -     0x7fff904c1ff7  libCRFSuite.dylib (33) <736ABE58-8DED-3289-A042-C25AF7AE5B23> /usr/lib/libCRFSuite.dylib
                0x7fff9063e000 -     0x7fff9064afff  libCSync.A.dylib (333.1.1) <1EE4C872-5236-3577-A458-691DA2B43370> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                0x7fff9064b000 -     0x7fff906b3ff7  libc++.1.dylib (65.1) <20E31B90-19B9-3C2A-A9EB-474E08F9FE05> /usr/lib/libc++.1.dylib
                0x7fff90bbe000 -     0x7fff90bc2fff  libGIF.dylib (852) <326C48F1-C892-3AF9-94BC-32768EFF6731> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                0x7fff90bc3000 -     0x7fff90edaff7  com.apple.CoreServices.CarbonCore (1037.6 - 1037.6) <1E567A52-677F-3168-979F-5FBB0818D52B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                0x7fff91055000 -     0x7fff910affff  com.apple.print.framework.PrintCore (8.3 - 387.2) <5BA0CBED-4D80-386A-9646-F835C9805B71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                0x7fff910b0000 -     0x7fff910ffff7  libcorecrypto.dylib (106.2) <CE0C29A3-C420-339B-ADAA-52F4683233CC> /usr/lib/system/libcorecrypto.dylib
                0x7fff9110d000 -     0x7fff911a8fff  com.apple.CoreSymbolication (3.0 - 117) <7D43ED93-BD81-338C-8076-6A932A1D19E8> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                0x7fff91208000 -     0x7fff91209fff  liblangid.dylib (116) <864C409D-D56B-383E-9B44-A435A47F2346> /usr/lib/liblangid.dylib
                0x7fff914c7000 -     0x7fff914e6ff7  com.apple.ChunkingLibrary (2.0 - 133.3) <8BEC9AFB-DCAA-37E8-A5AB-24422B234ECF> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                0x7fff91537000 -     0x7fff91538ff7  libsystem_sandbox.dylib (220.3) <B739DA63-B675-387A-AD84-412A651143C0> /usr/lib/system/libsystem_sandbox.dylib
                0x7fff91541000 -     0x7fff91544fff  libRadiance.dylib (852) <139962CD-21E2-3D31-9F47-D5F2D6C2C2BC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                0x7fff91619000 -     0x7fff91663ff7  libGLU.dylib (8.10.1) <6699DEA6-9EEB-3B84-A57F-B25AE44EC584> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                0x7fff916bc000 -     0x7fff91781ff7  com.apple.coreui (2.0 - 181.1) <83D2C92D-6842-3C9D-9289-39D5B4554C3A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                0x7fff91782000 -     0x7fff9185cfff  com.apple.backup.framework (1.4.3 - 1.4.3) <6B65C44C-7777-3331-AD9D-438D10AAC777> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                0x7fff9185d000 -     0x7fff9187fff7  libxpc.dylib (140.43) <70BC645B-6952-3264-930C-C835010CCEF9> /usr/lib/system/libxpc.dylib
                0x7fff91b62000 -     0x7fff91b65ff7  libdyld.dylib (210.2.3) <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
                0x7fff91b66000 -     0x7fff91b73ff7  com.apple.NetAuth (4.0 - 4.0) <F5BC7D7D-AF28-3C83-A674-DADA48FF7810> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                0x7fff91b74000 -     0x7fff91b87ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2F2694E9-A7BC-33C7-B4CF-8EC907DF0FEB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                0x7fff91bd2000 -     0x7fff91bf9ff7  com.apple.PerformanceAnalysis (1.16 - 16) <E4888388-F41B-313E-9CBB-5807D077BDA9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                0x7fff91c51000 -     0x7fff91c53ff7  com.apple.print.framework.Print (8.0 - 258) <34666CC2-B86D-3313-B3B6-A9977AD593DA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                0x7fff91c5e000 -     0x7fff91c6afff  com.apple.CrashReporterSupport (10.8.3 - 418) <DE6AFE16-D97E-399D-82ED-3522C773C36E> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                0x7fff91c6b000 -     0x7fff91c8bfff  libPng.dylib (852) <CCBFA9A9-33C0-3189-AFE0-A77E831EEBA8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
            External Modification Summary:
              Calls made by other processes targeting this process:
                task_for_pid: 2
                thread_create: 0
                thread_set_state: 0
              Calls made by this process:
                task_for_pid: 0
                thread_create: 0
                thread_set_state: 0
              Calls made by all processes on this machine:
                task_for_pid: 697
                thread_create: 2
                thread_set_state: 0
            VM Region Summary:
            ReadOnly portion of Libraries: Total=321.3M resident=218.0M(68%) swapped_out_or_unallocated=103.3M(32%)
            Writable regions: Total=167.5M written=52.9M(32%) resident=60.5M(36%) swapped_out=0K(0%) unallocated=107.0M(64%)
            REGION TYPE                      VIRTUAL
            ATS (font support)                 33.6M
            ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
            CG shared images                     96K
            CoreServices                       4704K
            MALLOC                            101.4M
            MALLOC guard page                    48K
            Memory tag=242                       12K
            Memory tag=243                        4K
            STACK GUARD                        56.0M
            Stack                              11.0M
            VM_ALLOCATE                        17.5M
            __DATA                             17.0M
            __IMAGE                             528K
            __LINKEDIT                        117.4M
            __TEXT                            203.9M
            __UNICODE                           544K
            mapped file                       225.2M
            shared memory                       308K
            TOTAL                             789.2M
            TOTAL, minus reserved VM space    789.2M
            Model: MacPro5,1, BootROM MP51.007F.B03, 8 processors, Quad-Core Intel Xeon, 2.4 GHz, 20 GB, SMC 1.39f11
            Graphics: ATI Radeon HD 5870, ATI Radeon HD 5870, PCIe, 1024 MB
            Memory Module: DIMM 1, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553754465238432D48392020
            Memory Module: DIMM 2, 4 GB, DDR3 ECC, 1066 MHz, 0x859B, 0x435435313237324241313036372E4D313846
            Memory Module: DIMM 3, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553754465238432D48392020
            Memory Module: DIMM 4, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553754465238432D48392020
            Memory Module: DIMM 5, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553754465238432D48392020
            Memory Module: DIMM 6, 4 GB, DDR3 ECC, 1066 MHz, 0x859B, 0x435435313237324241313036372E4D313846
            Memory Module: DIMM 7, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553754465238432D48392020
            Memory Module: DIMM 8, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553754465238432D48392020
            AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.17)
            Bluetooth: Version 4.1.7f2 12718, 3 service, 13 devices, 3 incoming serial ports
            Network Service: Ethernet 1, Ethernet, en0
            PCI Card: ATI Radeon HD 5870, sppci_displaycontroller, Slot-1
            Serial ATA Device: HL-DT-ST DVD-RW GH61N
            Serial ATA Device: WDC WD1001FALS-403AA0, 1 TB
            USB Device: hub_device, apple_vendor_id, 0x9126, 0xfa200000 / 2
            USB Device: USB Receiver, 0x046d  (Logitech Inc.), 0xc52b, 0xfa220000 / 6
            USB Device: Display iSight, apple_vendor_id, 0x8508, 0xfa250000 / 5
            USB Device: Apple LED Cinema Display, apple_vendor_id, 0x9226, 0xfa260000 / 4
            USB Device: Display Audio, apple_vendor_id, 0x1105, 0xfa240000 / 3
            USB Device: Backup+ Desk, 0x0bc2  (Seagate LLC), 0xa0a4, 0xfd100000 / 2
            USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x5a100000 / 2
            USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 5
            USB Device: microKEY-25, 0x0944  (KORG, Inc.), 0x0121, 0x5d100000 / 2
            USB Device: Hub in Macally ICEKEY keyboard, 0x2222, 0x1001, 0x3d100000 / 2
            USB Device: Macally ICEKey keyboard, 0x2222, 0x0005, 0x3d130000 / 3
            FireWire Device: built-in_hub, 800mbit_speed
            • 3. Re: Audition CC 2014 still crashing on startup (Mac)
              Something is choking on a font during startup.  Can you give us the list of fonts on your machine to see if we can repro?  Email to audbugs@adobe.com
              • 4. Re: Audition CC 2014 still crashing on startup (Mac)
                T Milner Level 1
                What's the simplest way to do that?   I'm using FontBook.  Is there a database or directory inside the app that I can copy and paste?  Basically, it's the whole Adobe Font Library plus a few misc. fonts that we've purchased over the years.
                Thanks.
                • 5. Re: Audition CC 2014 still crashing on startup (Mac)
                  _durin_ Adobe Employee
                  Actually, you might just want to select all the fonts in Font Book and run the "Validate Fonts" command, cleaning up any corrupt or misinstalled fonts it finds.  Audition generally launches correctly after those are repaired.
                  If you could grab a screenshot of the fonts it finds as corrupt, I'd be very curious to see it.  A fix in AuCC2014 should have resolved this.
                  • 6. Re: Audition CC 2014 still crashing on startup (Mac)
                    Charles VW Adobe Employee
                    Most of your fonts will be in /Library/Fonts
                    • 7. Re: Audition CC 2014 still crashing on startup (Mac)
                      T Milner Level 1
                      I'll post the list of fonts here;  I tried e-mailing it to the address provided and got an error message.  I did go into FontBook and clean out all the corrupt fonts.  It didn't help, but it probably needed to be done, anyway.  About a third of them failed validation.  It's interesting that an audio app would be the one having problems with a font.
                      Thanks.
                      file://localhost/Users/tommilner/Library/Fonts/AachenStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ACaslonPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ACaslonPro-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ACaslonPro-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ACaslonPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/ACaslonPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ACaslonPro-SemiboldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AGaramondPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/AGaramondPro-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AGaramondPro-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AGaramondPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/AGaramondPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/AGaramondPro-SemiboldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-BoldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-BoldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-BoldItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-BoldItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-BoldItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-BoldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-Capt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-Disp.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-It.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-ItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-ItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-ItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-Lt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-LtCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-LtDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-LtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-LtItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-LtItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-LtItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-LtSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-SemiboldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-SemiboldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-SemiboldItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-SemiboldItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-SemiboldItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-SemiboldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/AJensonPro-Subh.otf
                      file://localhost/Users/tommilner/Library/Fonts/AlbertusMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AlbertusMTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/AlbertusMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AldusLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AldusLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/AlexaStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanaStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanaStd-ExtraBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanaStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanaStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanTypewriterStd-BdCnd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanTypewriterStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanTypewriterStd-Cond.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanTypewriterStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanTypewriterStd-LtCnd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AmericanTypewriterStd-Med.otf
                      file://localhost/Users/tommilner/Library/Fonts/Amigo
                      file://localhost/Users/tommilner/Library/Fonts/Amigo.
                      file://localhost/Users/tommilner/Library/Fonts/AndreasStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AnnaStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AntiqueOliveStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/AntiqueOliveStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/AntiqueOliveStd-BoldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/AntiqueOliveStd-Compact.otf
                      file://localhost/Users/tommilner/Library/Fonts/AntiqueOliveStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AntiqueOliveStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/AntiqueOliveStd-Nord.otf
                      file://localhost/Users/tommilner/Library/Fonts/AntiqueOliveStd-NordItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AntiqueOliveStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/ApolloMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ApolloMTStd-SemiBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ApolloMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ArcadiaLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ArcanaGMMStd-Manuscript.otf
                      file://localhost/Users/tommilner/Library/Fonts/AriadneLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/ArnoldBoecklinStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AshleyScriptMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AstrologyPiLTStd-1.otf
                      file://localhost/Users/tommilner/Library/Fonts/AstrologyPiLTStd-2.otf
                      file://localhost/Users/tommilner/Library/Fonts/Audio%20Pi
                      file://localhost/Users/tommilner/Library/Fonts/AudioLHPi
                      file://localhost/Users/tommilner/Library/Fonts/AudioPiLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AuriolLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/AuriolLTStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AuriolLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/AuriolLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AuriolLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/AuriolLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-BlackOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-BookOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-Heavy.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-HeavyOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-LightOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-MediumOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-Oblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/AvenirLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/Baker%20Signet
                      file://localhost/Users/tommilner/Library/Fonts/BakerSig
                      file://localhost/Users/tommilner/Library/Fonts/BalzanoStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BancoStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BansheeStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BaskervilleCyrLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BaskervilleCyrLTStd-Incline.otf
                      file://localhost/Users/tommilner/Library/Fonts/BaskervilleCyrLTStd-Upright.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauerBodoniStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauerBodoniStd-BlackCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauerBodoniStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauerBodoniStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauerBodoniStd-BoldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauerBodoniStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauerBodoniStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauerBodoniStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauhausStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauhausStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauhausStd-Heavy.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauhausStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/BauhausStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/BeeskneesStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellCentennialStd-Address.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellCentennialStd-BdListing.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellCentennialStd-NameNum.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellCentennialStd-SubCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellGothicStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellGothicStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellGothicStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellMTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellMTStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellMTStd-SemiBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BellMTStd-SemiBoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BelweStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BelweStd-Condensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/BelweStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/BelweStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/BemboStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BemboStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BemboStd-ExtraBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BemboStd-ExtraBoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BemboStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BemboStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BemboStd-SemiboldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BemboStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatGothicStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatGothicStd-BoldObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatGothicStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatGothicStd-BookObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatGothicStd-Heavy.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatGothicStd-HeavyObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatGothicStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatGothicStd-MediumObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/BenguiatStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerkeleyStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerkeleyStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerkeleyStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerkeleyStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerkeleyStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerkeleyStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerkeleyStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerkeleyStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerlingLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerlingLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerlingLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BerlingLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/BermudaLPStd-Dots.otf
                      file://localhost/Users/tommilner/Library/Fonts/BermudaLPStd-Open.otf
                      file://localhost/Users/tommilner/Library/Fonts/BermudaLPStd-Solid.otf
                      file://localhost/Users/tommilner/Library/Fonts/BermudaLPStd-Squiggle.otf
                      file://localhost/Users/tommilner/Library/Fonts/BernhardModernStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BernhardModernStd-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BernhardModernStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BernhardModernStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/BernhardStd-BoldCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/BickhamScriptStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BickhamScriptStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/BickhamScriptStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BiffoMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BirchStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BlackoakStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BlueIslandStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd-BoldCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd-Poster.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd-PosterCompressed.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd-PosterItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BodoniStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BookmanStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BookmanStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BookmanStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/BookmanStd-DemiItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BookmanStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/BookmanStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BookmanStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/BookmanStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BorderPiStd-15159.otf
                      file://localhost/Users/tommilner/Library/Fonts/BossaNovaMVBStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-BlackComp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-BlackCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-BoldComp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-BoldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-Comp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-Cond.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-SemiboldCmp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemAkademiStd-SemiboldCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemScriptStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemScriptStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemScriptStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemScriptStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemScriptStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriemScriptStd-Ultra.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-BoldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-BoldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-BoldItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-BoldItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-BoldItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-BoldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-Capt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-Disp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-ItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-ItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-ItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-LightCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-LightDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-LightIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-LightItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-LightItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-LightItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-LightPoster.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-LightPosterIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-LightSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-MediumCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-MediumDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-MediumIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-MediumItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-MediumItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-MediumItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-MediumSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-SemiboldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-SemiboldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-SemiboldItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-SemiboldItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-SemiboldItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-SemiboldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BriosoPro-Subh.otf
                      file://localhost/Users/tommilner/Library/Fonts/BrunoJBStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BrunoJBStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BrushScriptStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-BoldDisplay.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-BoldItalicDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-Display.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-ItalicDisplay.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-SemiBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/BulmerMTStd-SemiBoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/BundesbahnPiStd-1.otf
                      file://localhost/Users/tommilner/Library/Fonts/BundesbahnPiStd-2.otf
                      file://localhost/Users/tommilner/Library/Fonts/BundesbahnPiStd-3.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaeciliaLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaeciliaLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaeciliaLTStd-Heavy.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaeciliaLTStd-HeavyItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaeciliaLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaeciliaLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaeciliaLTStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaeciliaLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaflischScriptPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaflischScriptPro-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaflischScriptPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaflischScriptPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaflischScriptWebPro.ttf
                      file://localhost/Users/tommilner/Library/Fonts/CalcitePro-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/CalcitePro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CalcitePro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/CalibanStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CalvertMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CalvertMTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CalvertMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CandidaStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CandidaStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CandidaStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd-ExtraBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd-ExtraBoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd-SemiBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd-SemiBoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CantoriaMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/Cappi
                      file://localhost/Users/tommilner/Library/Fonts/Cappio
                      file://localhost/Users/tommilner/Library/Fonts/CaravanLTStd-1.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaravanLTStd-2.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaravanLTStd-3.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaravanLTStd-4.otf
                      file://localhost/Users/tommilner/Library/Fonts/CarolinaLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CartaStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CascadeScriptLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon3LTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon3LTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon224Std-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon224Std-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon224Std-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon224Std-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon224Std-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon224Std-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon224Std-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon224Std-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon540LTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/Caslon540LTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaslonOpenFaceLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CastellarMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaxtonStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaxtonStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaxtonStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaxtonStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaxtonStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CaxtonStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CelestiaAntiquaStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CelestiaAntiquaStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CelestiaAntiquaStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CelestiaAntiquaStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentaurMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentaurMTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentaurMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentaurMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentennialLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentennialLTStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentennialLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentennialLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentennialLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentennialLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentennialLTStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CentennialLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyExpandedLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyExpandedLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyOldStyleStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyOldStyleStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyOldStyleStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-BoldCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-BoldCondensedIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-BookCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-BookCondensedIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-HandtooledBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-HandtooledBoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-LightCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-LightCondensedIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-Ultra.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-UltraCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-UltraCondensedIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CenturyStd-UltraItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CerigoStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CerigoStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CerigoStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/CerigoStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CerigoStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/CerigoStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-BoldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-BoldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-BoldItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-BoldItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-BoldItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-BoldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-Capt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-Disp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-ItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-ItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-ItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-LightCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-LightDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-LightIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-LightItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-LightItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-LightItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-LightSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-SemiboldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-SemiboldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-SemiboldItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-SemiboldItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-SemiboldItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-SemiboldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/ChaparralPro-Subh.otf
                      file://localhost/Users/tommilner/Library/Fonts/CharlemagneStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CharlemagneStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/CharmeStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-BoldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-BoldCondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-BookCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-BookCondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-HdtooledBdIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-HdtooledBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-LightCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-LightCondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-Ultra.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-UltraCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-UltraCondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheltenhamStd-UltraItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CheqStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClairvauxLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClarendonLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClarendonLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClarendonLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceGothicLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceGothicLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceGothicLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceGothicLTStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceGothicLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceStd-Heavy.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceStd-HeavyItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ClearfaceStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/CloisterStd-OpenFace.otf
                      file://localhost/Users/tommilner/Library/Fonts/CochinLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CochinLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CochinLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CochinLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CongaBravaStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/CongaBravaStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CongaBravaStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CongaBravaStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/CongaBravaStd-SmBd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CongaBravaStencilStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/CongaBravaStencilStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CongaBravaStencilStd-Reg.otf
                      file://localhost/Users/tommilner/Library/Fonts/CongaBravaStencilStd-SmBd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CooperBlackStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CooperBlackStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopalStd-Decorated.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopalStd-Outline.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopalStd-Solid.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopperplateGothicStd-29AB.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopperplateGothicStd-29BC.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopperplateGothicStd-30AB.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopperplateGothicStd-30BC.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopperplateGothicStd-31AB.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopperplateGothicStd-31BC.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopperplateGothicStd-32AB.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopperplateGothicStd-32BC.otf
                      file://localhost/Users/tommilner/Library/Fonts/CopperplateGothicStd-33BC.otf
                      file://localhost/Users/tommilner/Library/Fonts/CorianderStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CoronaLTStd-BoldFaceNo2.otf
                      file://localhost/Users/tommilner/Library/Fonts/CoronaLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CoronaLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CoronetLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CoronetLTStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/CottonwoodStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CourierStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CourierStd-BoldOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/CourierStd-Oblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/CourierStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CritterStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-BoldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-BoldCaptIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-BoldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-BoldDispIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-BoldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-BoldSubhIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-Capt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-CaptIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-Disp.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-DispIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-Lt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-LtCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-LtCaptIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-LtDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-LtDispIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-LtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-LtSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-LtSubhIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-SemiboldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-SemiboldCaptIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-SemiboldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-SemiboldDispIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-SemiboldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-SemiboldSubhIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-Subh.otf
                      file://localhost/Users/tommilner/Library/Fonts/CronosPro-SubhIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/CTMercuriusStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/CTMercuriusStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CTMercuriusStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/CTMercuriusStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CTMercuriusStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/CTMercuriusStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CushingStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/CushingStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CushingStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/CushingStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CushingStd-Heavy.otf
                      file://localhost/Users/tommilner/Library/Fonts/CushingStd-HeavyItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CushingStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/CushingStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/CutoutStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/DanteMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/DanteMTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/DanteMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/DanteMTStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/DanteMTStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/DanteMTStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/DecorationPiLTStd-1.otf
                      file://localhost/Users/tommilner/Library/Fonts/DecorationPiLTStd-2.otf
                      file://localhost/Users/tommilner/Library/Fonts/DelphinLTStd-1.otf
                      file://localhost/Users/tommilner/Library/Fonts/DelphinLTStd-2.otf
                      file://localhost/Users/tommilner/Library/Fonts/DidotLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/DidotLTStd-Headline.otf
                      file://localhost/Users/tommilner/Library/Fonts/DidotLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/DidotLTStd-Ornaments.otf
                      file://localhost/Users/tommilner/Library/Fonts/DidotLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/DINEngschriftStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/DINMittelschriftStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/DINNeuzeitGroteskStd-BdCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/DINNeuzeitGroteskStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/DiotimaLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/DiotimaLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/DiskusLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/DiskusLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/DomCasualStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/DomCasualStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/DorchesterScriptMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/DoricLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/DucDeBerryLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/EccentricStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/EgyptienneFLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/EgyptienneFLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/EgyptienneFLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/EgyptienneFLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/EhrhardtMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/EhrhardtMTStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/EhrhardtMTStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/EhrhardtMTStd-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ElectraLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ElectraLTStd-BoldCursive.otf
                      file://localhost/Users/tommilner/Library/Fonts/ElectraLTStd-BoldCursiveDis.otf
                      file://localhost/Users/tommilner/Library/Fonts/ElectraLTStd-BoldDisplay.otf
                      file://localhost/Users/tommilner/Library/Fonts/ElectraLTStd-Cursive.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd-BoldCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd-BoldEx2.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd-BoldOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd-Cn.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd-DemiOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd-Ex2.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd-Oblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/EurostileLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/FranklinGothicStd-Condensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/FranklinGothicStd-ExtraCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/FranklinGothicStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/GiddyupStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/GlyphaLTStd-LightOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/GlyphaLTStd-Thin.otf
                      file://localhost/Users/tommilner/Library/Fonts/GlyphaLTStd-ThinOblique.otf
                      file://localhost/Users/tommilner/Library/Fonts/GlyphaLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/GothicThirteenStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyModernMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyModernMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudySansStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudySansStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudySansStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudySansStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudySansStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudySansStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudySansStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudySansStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyStd-ExtraBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyStd-Heavyface.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyStd-HeavyfaceItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/GoudyTextMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/GranjonLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/GranjonLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GranjonLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/GraphiteStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/GraphiteStd-BoldNarrow.otf
                      file://localhost/Users/tommilner/Library/Fonts/GraphiteStd-BoldWide.otf
                      file://localhost/Users/tommilner/Library/Fonts/GraphiteStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/GraphiteStd-LightNarrow.otf
                      file://localhost/Users/tommilner/Library/Fonts/GraphiteStd-LightWide.otf
                      file://localhost/Users/tommilner/Library/Fonts/GraphiteStd-Narrow.otf
                      file://localhost/Users/tommilner/Library/Fonts/GraphiteStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/GraphiteStd-Wide.otf
                      file://localhost/Users/tommilner/Library/Fonts/GreymantleMVBStd-Ornaments.otf
                      file://localhost/Users/tommilner/Library/Fonts/GreymantleMVBStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd-BoldExtended.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd-Condensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd-ExtraCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd-LightCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GrotesqueMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/GuardiLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/GuardiLTStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GuardiLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/GuardiLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GuardiLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/GuardiLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/Hadriano
                      file://localhost/Users/tommilner/Library/Fonts/HadriBol
                      file://localhost/Users/tommilner/Library/Fonts/HadriExtBol
                      file://localhost/Users/tommilner/Library/Fonts/HadriExtBolCon
                      file://localhost/Users/tommilner/Library/Fonts/HadriLig
                      file://localhost/Users/tommilner/Library/Fonts/HardwoodLPStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaInseratLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-Blk.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-BlkCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-BlkCondObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-BlkObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-BoldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-BoldCondObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-BoldObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-Comp.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-Cond.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-CondObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-ExtraComp.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-Fractions.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-FractionsBd.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-LightCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-LightCondObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-LightObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-Obl.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaLTStd-UltraComp.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-Bd.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BdCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BdCnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BdEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BdExO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BdIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BdOu.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-Blk.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BlkCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BlkCnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BlkEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BlkExO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-BlkIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-Cn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-CnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-Ex.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-ExO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-Hv.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-HvCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-HvCnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-HvEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-HvExO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-HvIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-It.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-Lt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-LtCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-LtCnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-LtEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-LtExO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-LtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-Md.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-MdCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-MdCnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-MdEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-MdExO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-MdIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-Th.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-ThCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-ThCnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-ThEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-ThExO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-ThIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-UltLt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-UltLtCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-UltLtCnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-UltLtEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-UltLtExO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-UltLtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-XBlkCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaNeueLTStd-XBlkCnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaRoundedLTStd-Bd.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaRoundedLTStd-BdCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaRoundedLTStd-BdCnO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaRoundedLTStd-BdO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaRoundedLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/HelveticaRoundedLTStd-BlkO.otf
                      file://localhost/Users/tommilner/Library/Fonts/HerculanumLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/HighlanderStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/HighlanderStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/HighlanderStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/HighlanderStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/HighlanderStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/HighlanderStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/HiroshigeStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/HiroshigeStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/HiroshigeStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/HiroshigeStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/HiroshigeStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/HiroshigeStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/HiroshigeStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/HiroshigeStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/HoboStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/HolidayPiLTStd-1.otf
                      file://localhost/Users/tommilner/Library/Fonts/HolidayPiLTStd-2.otf
                      file://localhost/Users/tommilner/Library/Fonts/HolidayPiLTStd-3.otf
                      file://localhost/Users/tommilner/Library/Fonts/HorleyOldStyleMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/HorleyOldStyleMTStd-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HorleyOldStyleMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/HorleyOldStyleMTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/HorleyOldStyleMTStd-LightIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HorleyOldStyleMTStd-Sb.otf
                      file://localhost/Users/tommilner/Library/Fonts/HorleyOldStyleMTStd-SbIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/HorleyOldStyleMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ImmiFiveOFiveStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ImpactLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ImpressumStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ImpressumStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ImpressumStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/IndustriaLTStd-Inline.otf
                      file://localhost/Users/tommilner/Library/Fonts/IndustriaLTStd-Solid.otf
                      file://localhost/Users/tommilner/Library/Fonts/InflexMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/InsigniaLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/IronwoodStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/IsabellaStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/IsadoraStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/IsadoraStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/ItalianOldStyleMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ItalianOldStyleMTStd-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ItalianOldStyleMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ItalianOldStyleMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ItaliaStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ItaliaStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/ItaliaStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITC%20Zapf%20Dingbats
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-Bk.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-BkCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-BkCnObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-BkObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-BoldCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-BoldCnObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-BoldObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-DemiCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-DemiCnObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-DemiObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-Md.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-MdCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-MdCnObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-MdObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-XLt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-XLtCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-XLtCnObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCAvantGardeStd-XLtObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCErasStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCErasStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCErasStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCErasStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCErasStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCErasStd-Ultra.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-BkCd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-BkCdIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-BkCp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-BkCpIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-BkXCp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-BookIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-DemiIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-DmCd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-DmCdIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-DmCp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-DmCpIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-DmXCp.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-Hvy.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-HvyIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-MdCd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-MdCdIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-Med.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCFranklinGothicStd-MedIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-Bd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BdCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BdCondIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BdIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BdNarrow.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BdNarrowIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-Bk.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BkCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BkCondIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BkIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BkNarrow.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-BkNarrowIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-Lt.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-LtCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-LtCondIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-LtIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-LtNarrow.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-LtNarrowIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-Ult.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-UltCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-UltCondIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-UltIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-UltNarrow.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCGaramondStd-UltNarrowIta.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCKabelStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCKabelStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCKabelStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCKabelStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCKabelStd-Ultra.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCSymbolStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCSymbolStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCSymbolStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCSymbolStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCSymbolStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCSymbolStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCSymbolStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/ITCSymbolStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/JansonTextLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/JansonTextLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/JansonTextLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/JansonTextLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/JimboStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/JimboStd-BlackCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/JimboStd-BlackExpanded.otf
                      file://localhost/Users/tommilner/Library/Fonts/JimboStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/JimboStd-BoldCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/JimboStd-BoldExpanded.otf
                      file://localhost/Users/tommilner/Library/Fonts/JimboStd-Condensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/JimboStd-Expanded.otf
                      file://localhost/Users/tommilner/Library/Fonts/JimboStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/JoannaMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/JoannaMTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/JoannaMTStd-ExtraBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/JoannaMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/JoannaMTStd-SemiBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/JoannaMTStd-SemiBoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/JoannaMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/JuniperStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/KabelLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/KabelLTStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/KabelLTStd-Heavy.otf
                      file://localhost/Users/tommilner/Library/Fonts/KabelLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/KaufmannStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/KaufmannStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackCnDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackCnItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackCnItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackCnSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackExtCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackExtDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackExtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackExtItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackExtItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackExtItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackExtSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackScn.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackScnCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackScnDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackScnIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackScnItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackScnItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackScnItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackScnSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BlackSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldCnDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldCnItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldCnItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldCnSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldExtCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldExtDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldExtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldExtItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldExtItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldExtItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldExtSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldScn.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldScnCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldScnDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldScnIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldScnItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldScnItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldScnItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldScnSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-BoldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-Capt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-CnDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-CnItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-CnItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-CnSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-Disp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-Ext.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ExtCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ExtDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ExtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ExtItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ExtItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ExtItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ExtSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-ItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightCnDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightCnItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightCnItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightCnSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightExtCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightExtDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightExtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightExtItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightExtItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightExtItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightExtSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/KeplerStd-LightItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/LetterGothicStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/LetterGothicStd-BoldSlanted.otf
                      file://localhost/Users/tommilner/Library/Fonts/LetterGothicStd-Slanted.otf
                      file://localhost/Users/tommilner/Library/Fonts/LetterGothicStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/LithosPro-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/LithosPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/MesquiteStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-BoldCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-BoldCnIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-It.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-MediumIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/MinionPro-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BlackCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BlackCondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BlackIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BlackSemiCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BlackSemiCnIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BlackSemiExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BlackSemiExtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BoldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BoldCondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BoldSemiCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BoldSemiCnIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BoldSemiExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-BoldSemiExtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-Cond.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-CondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-It.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-LightCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-LightCondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-LightIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-LightSemiCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-LightSemiCnIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-LightSemiExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-LightSemiExtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiboldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiboldCondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiboldSemiCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiboldSemiCnIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiboldSemiExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiboldSemiExtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiCnIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadPro-SemiExtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadWebPro-Bold.ttf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadWebPro-Italic.ttf
                      file://localhost/Users/tommilner/Library/Fonts/MyriadWebPro.ttf
                      file://localhost/Users/tommilner/Library/Fonts/NeueHammerUnzialeLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/NewCenturySchlbkLTStd-Bd.otf
                      file://localhost/Users/tommilner/Library/Fonts/NewCenturySchlbkLTStd-BdIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/NewCenturySchlbkLTStd-Fra.otf
                      file://localhost/Users/tommilner/Library/Fonts/NewCenturySchlbkLTStd-FraBd.otf
                      file://localhost/Users/tommilner/Library/Fonts/NewCenturySchlbkLTStd-It.otf
                      file://localhost/Users/tommilner/Library/Fonts/NewCenturySchlbkLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/NuevaStd-BoldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/NuevaStd-BoldCondItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/NuevaStd-Cond.otf
                      file://localhost/Users/tommilner/Library/Fonts/NuevaStd-CondItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/OCRAStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/OratorStd-Slanted.otf
                      file://localhost/Users/tommilner/Library/Fonts/OratorStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/PoplarStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/PrestigeEliteStd-Bd.otf
                      file://localhost/Users/tommilner/Library/Fonts/RosewoodStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/SabonLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanMarcoLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-BoldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-BoldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-BoldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-Capt.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-Disp.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-Lt.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-LtCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-LtDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-LtSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-SemiboldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-SemiboldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-SemiboldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/SanvitoPro-Subh.otf
                      file://localhost/Users/tommilner/Library/Fonts/SassafrasStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SassafrasStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/ScotchRomanMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ScotchRomanMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ScriptMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifaStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifaStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifaStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifaStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifaStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifaStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifGothicStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifGothicStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifGothicStd-ExtraBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifGothicStd-Heavy.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifGothicStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerifGothicStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerlioLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/SerpeBol
                      file://localhost/Users/tommilner/Library/Fonts/SerpeBolObl
                      file://localhost/Users/tommilner/Library/Fonts/SerpeLig
                      file://localhost/Users/tommilner/Library/Fonts/SerpeLigObl
                      file://localhost/Users/tommilner/Library/Fonts/SerpeMed
                      file://localhost/Users/tommilner/Library/Fonts/SerpeMedObl
                      file://localhost/Users/tommilner/Library/Fonts/Serpentine
                      file://localhost/Users/tommilner/Library/Fonts/ShannBol
                      file://localhost/Users/tommilner/Library/Fonts/ShannBoo
                      file://localhost/Users/tommilner/Library/Fonts/ShannExtBol
                      file://localhost/Users/tommilner/Library/Fonts/ShannObl
                      file://localhost/Users/tommilner/Library/Fonts/Shannon
                      file://localhost/Users/tommilner/Library/Fonts/ShelleyLTStd-Script.otf
                      file://localhost/Users/tommilner/Library/Fonts/ShoLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/ShurikenStd-Boy.otf
                      file://localhost/Users/tommilner/Library/Fonts/SilentiumPro-RomanI.otf
                      file://localhost/Users/tommilner/Library/Fonts/SilentiumPro-RomanII.otf
                      file://localhost/Users/tommilner/Library/Fonts/SimonciniGaramondStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SimonciniGaramondStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SimonciniGaramondStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/SlimbachStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/SlimbachStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SlimbachStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SlimbachStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SlimbachStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/SlimbachStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SlimbachStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/SlimbachStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SmaragdLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/SnellRoundhandLTStd-BdScr.otf
                      file://localhost/Users/tommilner/Library/Fonts/SnellRoundhandLTStd-BlkScr.otf
                      file://localhost/Users/tommilner/Library/Fonts/SnellRoundhandLTStd-Scr.otf
                      file://localhost/Users/tommilner/Library/Fonts/SouvenirStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SouvenirStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SouvenirStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/SouvenirStd-DemiItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SouvenirStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/SouvenirStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SouvenirStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/SouvenirStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SpartanLTStd-BookClass.otf
                      file://localhost/Users/tommilner/Library/Fonts/SpartanLTStd-HeavyClass.otf
                      file://localhost/Users/tommilner/Library/Fonts/SpectrumMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SpectrumMTStd-SemiBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SpectrumMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/SpringLPStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/SpringLPStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/SpumoniLPStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelGaramondLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelGaramondLTStd-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelGaramondLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelGaramondLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-BdIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-BlkIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-LtIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-MedIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/StempelSchneidlerStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/StencilStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneInformalStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneInformalStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneInformalStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneInformalStd-MediumItal.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneInformalStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneInformalStd-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSansStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSansStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSansStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSansStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSansStd-Phonetic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSansStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSansStd-SemiboldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSerifStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSerifStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSerifStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSerifStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSerifStd-Phonetic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSerifStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StoneSerifStd-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrayhornMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrayhornMTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrayhornMTStd-ExtraBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrayhornMTStd-ExtraBoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrayhornMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrayhornMTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrayhornMTStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrayhornMTStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrumpfStd-Contour.otf
                      file://localhost/Users/tommilner/Library/Fonts/StrumpfStd-Open.otf
                      file://localhost/Users/tommilner/Library/Fonts/StudzStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/SymbolStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/SyntaxLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/SyntaxLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/SyntaxLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/SyntaxLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/SyntaxLTStd-UltraBlack.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-BoldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-BoldCondObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-BoldExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-BoldExtObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-BoldObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-Cond.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-CondObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-Ext.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-ExtObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-LightCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-LightCondObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-LightExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-LightExtObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-LightObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-Obl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TektonPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/TempoStd-HeavyCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/TempoStd-HeavyCondensedIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiepoloStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiepoloStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiepoloStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiepoloStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiepoloStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiepoloStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiffanyStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiffanyStd-DemiItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiffanyStd-Heavy.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiffanyStd-HeavyItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiffanyStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TiffanyStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesEuropaLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesEuropaLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesEuropaLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesEuropaLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesLTStd-ExtraBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesLTStd-Phonetic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesLTStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesLTStd-SemiboldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesNewRomanMTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesNewRomanMTStd-BoldCond.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesNewRomanMTStd-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesNewRomanMTStd-Cond.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesNewRomanMTStd-CondIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesNewRomanMTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesNewRomanMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesTenLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesTenLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesTenLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TimesTenLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/ToolboxStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-Bd2.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-Bd2Obl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-BdCn20.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-BdCn20Obl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-BoldExt.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-BoldObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-Cn18.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-Cn18Obl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-Extended.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-LightObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd-Obl.otf
                      file://localhost/Users/tommilner/Library/Fonts/TradeGothicLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/TrajanPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TrajanPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/TrumpMediaevalLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/TrumpMediaevalLTStd-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/TrumpMediaevalLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/TrumpMediaevalLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/UmbraStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversalStd-GreekwMathPi.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversalStd-NewswithCommPi.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversityRomanStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-BlackEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-BlackExObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-BlackObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-BoldCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-BoldCnObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-BoldEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-BoldExObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-BoldObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-Cn.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-CnObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-Ex.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-ExObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-LightCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-LightCnObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-LightObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-LightUltraCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-Obl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-ThinUltraCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-UltraCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-XBlack.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-XBlackEx.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-XBlackExObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd-XBlackObl.otf
                      file://localhost/Users/tommilner/Library/Fonts/UniversLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/UsherwoodStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/UsherwoodStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/UsherwoodStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/UsherwoodStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/UsherwoodStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/UsherwoodStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/UsherwoodStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/UsherwoodStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-BlackHeadline.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-BoldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-BoldCaptIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-BoldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-BoldDispIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-BoldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-BoldSubhIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-Capt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-CaptIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-Disp.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-DispIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-SemiboldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-SemiboldCaptIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-SemiboldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-SemiboldDispIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-SemiboldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-SemiboldSubhIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-Subh.otf
                      file://localhost/Users/tommilner/Library/Fonts/UtopiaStd-SubhIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/VAGRoundedStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/VAGRoundedStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/VAGRoundedStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/VAGRoundedStd-Thin.otf
                      file://localhost/Users/tommilner/Library/Fonts/VectoraLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/VectoraLTStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VectoraLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/VectoraLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VectoraLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VectoraLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/VectoraLTStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VectoraLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/VeljovicStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/VeljovicStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VeljovicStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/VeljovicStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VeljovicStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/VeljovicStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VeljovicStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/VeljovicStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VersaillesLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/VersaillesLTStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VersaillesLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/VersaillesLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VersaillesLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VersaillesLTStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/VersaillesLTStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/VersaillesLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/VerveStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/VerveStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/VerveStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/Visig
                      file://localhost/Users/tommilner/Library/Fonts/Visigoth
                      file://localhost/Users/tommilner/Library/Fonts/VivaStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/VivaStd-BoldCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/VivaStd-BoldExtraExtended.otf
                      file://localhost/Users/tommilner/Library/Fonts/VivaStd-Condensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/VivaStd-ExtraExtended.otf
                      file://localhost/Users/tommilner/Library/Fonts/VivaStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/VivaStd-LightCondensed.otf
                      file://localhost/Users/tommilner/Library/Fonts/VivaStd-LightExtraExtended.otf
                      file://localhost/Users/tommilner/Library/Fonts/VivaStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/VolutaScriptPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarningPiLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-BoldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-BoldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-BoldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-BoldItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-BoldItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-BoldItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-BoldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-Capt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-Disp.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-It.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-ItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-ItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-ItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-LightCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-LightDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-LightIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-LightItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-LightItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-LightItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-LightSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-Semibold.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-SemiboldCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-SemiboldDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-SemiboldIt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-SemiboldItCapt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-SemiboldItDisp.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-SemiboldItSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-SemiboldSubh.otf
                      file://localhost/Users/tommilner/Library/Fonts/WarnockPro-Subh.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-Bd.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-BdCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-BdScn.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-Cn.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-Lt.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-LtCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-LtScn.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-Rg.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-Sb.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-SbCn.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-SbScn.otf
                      file://localhost/Users/tommilner/Library/Fonts/WatersTitlingPro-Scn.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeidemannStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeidemannStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeidemannStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeidemannStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeidemannStd-Book.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeidemannStd-BookItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeidemannStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeidemannStd-MediumItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeissStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeissStd-ExtraBold.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeissStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/WeissStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/WendyLPStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/WendyLPStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/WendyLPStd-Medium.otf
                      file://localhost/Users/tommilner/Library/Fonts/WiesbadenSwingLTStd-Ding.otf
                      file://localhost/Users/tommilner/Library/Fonts/WiesbadenSwingLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/WilhelmKlingsporGotLTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/WilkeLTStd-Black.otf
                      file://localhost/Users/tommilner/Library/Fonts/WilkeLTStd-BlackItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/WilkeLTStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/WilkeLTStd-BoldItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/WilkeLTStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/WilkeLTStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/WillowStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/WittenbergerFrakturMTStd-Bd.otf
                      file://localhost/Users/tommilner/Library/Fonts/WittenbergerFrakturMTStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/WoodtypeOrnamentsStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZapfChanceryStd-Bold.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZapfChanceryStd-Demi.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZapfChanceryStd-Italic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZapfChanceryStd-Light.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZapfChanceryStd-LightItalic.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZapfChanceryStd-Roman.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZapfDin
                      file://localhost/Users/tommilner/Library/Fonts/ZapfDingbatsStd.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZebrawoodStd-Fill.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZebrawoodStd-Regular.otf
                      file://localhost/Users/tommilner/Library/Fonts/ZiptyDoStd.otf
                      • 8. Re: Audition CC 2014 still crashing on startup (Mac)
                        Charles VW Adobe Employee
                        T Milner wrote:
                        It's interesting that an audio app would be the one having problems with a font.
                        The irony isn't lost on us.
                        • 9. Re: Audition CC 2014 still crashing on startup (Mac)
                          The font that we're loading on startup on my system is located here:
                          /System/Library/Fonts/LucidaGrande.ttc
                          If I choose "Get Info" on the font, I'm using version 9.0d11e0
                          • 10. Re: Audition CC 2014 still crashing on startup (Mac)
                            Sorry, that screenshot is for OSX 10.9.3, on OSX 10.8.5 (like your system) it is version 8.0d2e1
                            • 11. Re: Audition CC 2014 still crashing on startup (Mac)
                              T Milner Level 1
                              Okay, you've lost me now.  Is that a font that I don't have, but should, or have but should disable?  Lucida Grande is showing up in my Font Book, but when I do a search, it's not on my system.  There is a .ttf version of it in a copy of my System Folder from a backup I did a few months back, but it's not on the hard drive.  Is that the problem?
                              Edit:  the one on my backup disk is a .dfont.  Sorry.
                              Thanks.
                              • 12. Re: Audition CC 2014 still crashing on startup (Mac)
                                To find the font on my clean 10.8.5 system, I did the following
                                1. Open Font Book.app
                                2. In the upper-right corner, I searched for "lucida grande"
                                3. Right-Clicked on the entry in the center column ("Font"), and chose "Show in Finder"
                                4. Right-Clicked on that file in the newly opened Finder window, and chose "Get Info"
                                For me, it is "LucidaGrande.ttc" and is about 1.7 MB.
                                • 13. Re: Audition CC 2014 still crashing on startup (Mac)
                                  T Milner Level 1
                                  Ah, yes.  Apparently, the Desktop search function doesn't go into that hidden Library.  Anyway, I found it, and it appears to be the same version.  Should I move it to the trash?
                                  • 14. Re: Audition CC 2014 still crashing on startup (Mac)
                                    I can't say for sure if that will help anything, but go ahead and try it and let us know what happens.  Be sure to back up the file, since it is a system font and as far as I know, should be present on the system.
                                    We may also want to consider this troubleshooting step from Photoshop (Solution 6):
                                    http://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop-cs5.html#id_9946
                                    [edit]:
                                    Note that the Typesupport folder that applies to Audition is the following: /Users/[user name]/Library/Caches/Adobe/TypeSupport
                                    • 15. Re: Audition CC 2014 still crashing on startup (Mac)
                                      T Milner Level 1
                                      No luck.  The Computer won't even let me trash it.  I right click and select "Move to Trash" and it does, but then I get a message that the font has been restored, since the computer needs it to display text on screen.  It's not the end of the world.  Audition CC is working fine, so I'll just stick with it for a while.  If you come across a solution, please let me know.
                                      Thanks for your help.
                                      • 16. Re: Audition CC 2014 still crashing on startup (Mac)
                                        Sorry to go dark for a while.  We were investigating some workarounds.
                                        Just to clarify, Audition CC is working fine for you, but Audition CC 2014 isn't working fine on the same machine?
                                        For Audition CC 2014, can you try this as a workaround:
                                        1. Quit Premiere and Au
                                        2. Backup or archive /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeCoolType.framework
                                        3. Copy the Directory /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/AdobeCoolType.framework  -- to ---> /Applications/Adobe Audition CC 2014/Adobe Audition CC 2014.app/Contents/Frameworks/AdobeCoolType.framework
                                        4. Start Au
                                        Does that make a difference?
                                        • 17. Re: Audition CC 2014 still crashing on startup (Mac)
                                          T Milner Level 1
                                          I never did solve the problem on that machine, but I have since gotten a new
                                          iMac, running Mavericks, and Audition CC 2014 seems to be running fine on
                                          it.  (At least it opens;  I haven¹t done any actual work on it yet.)  The
                                          old machine, apparently, had a problem with one of the system fonts that was
                                          conflicting with Audition CC 2014.
                                          Notably, my home computer, a 2010 iMac running Mountain Lion, never had a
                                          problem with the new Audition.   It might still be worth investigating;
                                          other people may be having the same problem, though it may have been
                                          something very specific with my old Mac Pro.
                                          Thanks for checking back.
                                          • 18. Re: Audition CC 2014 still crashing on startup (Mac)
                                            Okay, that makes more sense that Audition CC and Audition CC 2014 are on two different systems, and not the same system.
                                            If you get a chance, can you please try the workaround on that old Mac Pro that was having the font issue?
                                            • 19. Re: Audition CC 2014 still crashing on startup (Mac)
                                              T Milner Level 1
                                              Sorry, but I had to de-authorize that computer for CC.  We¹re just using it
                                              as a mobile work station now.  If we reconnect it and re-authorize it, I¹ll
                                              give it a shot.  To clarify,  the problem originally occurred with Audition
                                              CC, and the fix presented in the forum took care of it.  Then, when CC 2014
                                              came out, it happened again on that same computer (Mac Pro), and the fix
                                              which had worked for CC didn¹t work for CC 2014.  The Mac Pro, like my home
                                              computer (iMac), was running Mountain Lion, even though my home computer
                                              never had a problem with Audition CC or CC 2014.
                                              In any case, if I get a chance to try the workaround, I¹ll let you know what
                                              happens.
                                              • 20. Re: Audition CC 2014 still crashing on startup (Mac)
                                                will i am
                                                Hey guys - I had this problem having upgraded machine and migrated my CC to the new machine. Audition crashing on startup.
                                                Sent in a crash report with my email and I was linked to the solution on this page here.
                                                I can confirm that having replaced the AdobeCoolType.framework folder with the one from premiere pro DOES fix the problem.
                                                My audition now runs.
                                                Also a bonus confirmation is that those crash reports do actually get read (I was previously a skeptic)
                                                Thanks for the fix Mr Van Winkle (the dude who responded to me)
                                                • 21. Re: Audition CC 2014 still crashing on startup (Mac)
                                                  ReubenFink
                                                  Thanks Charles,
                                                  I had this same issue and the Framework directory replacement worked like a charm.
