6 Replies Latest reply on Jun 26, 2014 7:41 AM by ECBowen
    CC 2014 benchmarks so far. Updating as their completed on different systems
    ECBowen Most Valuable Participant
      Before 6/18/2014 update
      4790K @ 4.7GHz
      32GB DDR3 1600
      1TB Crucial M550 SSD
      780Ti
      AVCHD 4 Layer 30 Minute test
      Adobe CC
      3 Layer - 26:30
      4 Layer – 29:40
      Red 4K to DPX 4096 x 2048 24p Full Range (max bit depth)
      3 Layer - 5:52
      4 layer - 5:20
      Red 6K to DPX 6K (max bit depth)
      1 Layer - 5:14
      Creative Cloud 2014
      3 Layer - 26:11
      4 Layer – 29:14
      3 Layer - 1:53
      4 layer - 1:48
      1 Layer - 1:28
      2x Xeon E5 2690 V2 CPU's @ 3GHz
      128GB DDR3 1600
      780Ti
      3 Layer - 29:29
      4 Layer – 31:21
      Red 4K to DPX 4096 x 2048 24p Full Range (max bit depth) 30 seconds of media
      3 Layer - 3:20
      4 layer - 3:20
      Realtime Playback 4K Full Res smooth without dropping frames.
      Poor CPU Threaded on export but not playback
      Average GPU load 50%
      Max GPU load 99%
      Red 6K to DPX 6K (max bit depth) 20 seconds of media
      1 Layer - 2:29
      Realtime Playback 6K Full Res smooth without dropping frames.
      Average GPU load 40%
      Max GPU load 99%
      R3D to 4K Pro Res results shortly.
        • 1. Re: CC 2014 benchmarks so far. Updating as their completed on different systems
          JFPhoton Level 3
          ....very interesting results !!!......the big question is why the dramatic performance increase regarding 4K and 6K, but, NONE on the AVCHD !!!
          It appears Adobe may be thinking 1080P is OVER already for professionals...hah!
          • 2. Re: CC 2014 benchmarks so far. Updating as their completed on different systems
            Well it was known before hand the GPU accelerated debayering for Red was coming in this update. The question really is what else has been updated and how has that changed CPU performance if any. Before this update R3D was threading great within Premiere both for playback and export. Now however the GPU accelerated debayering has changed that even though the performance is better. The CPU threading is fine during playback but very poor on export with the Dual CPU platform. I suspect that has to do with the decoding moving to Adobe's player versus using several instances of Red's Player in the past. Before you would see instances of Red's player in the processes when dealing with red media. Now there is only Adobe's and Quicktime showing. Once I have the complete benchmarks done on all the platforms, then maybe this can be taken to Adobe for review and optimizations in the future with the current threading. The Dual Xeon config shows so much potential now with realtime playback ie 6K full resolution playback with ease that the export times should be exponentially faster if threading was ideal. I will post more benchmark info in this thread as I get it done.
            Eric
            ADK
            • 3. Re: CC 2014 benchmarks so far. Updating as their completed on different systems
              128GB DDR3 1600
              2x 780Ti GPU's
              3 Layer - 29:59
              4 Layer – 32:05
              3 Layer - 3:39
              4 layer - 3:30
              1 Layer - 2:51
              Red 4K to Pro Res 4444 via Cinemartin PLIN Gold 30 seconds
              3:40 + 1 min to 2min Render time in Premiere
              • 4. Re: CC 2014 benchmarks so far. Updating as their completed on different systems
                128GB DDR3 1600
                780Ti
                DNG 2.4K to H264 2.4K 26 seconds of media
                1 Layer - :19
                CPU threads very well on export.
                Red 4K to H264 4K 30 seconds of media
                4 layer - 1:14
                CPU Threads very well on export
                Red 4K to Cineform 4K Film Scan 1 30 seconds of media
                4 Layer - 5:55
                CPU Threads poorly
                AE CC 2014
                Red 4K to AVI Lossless 4k 30 seconds of media
                1 Layer: 2:32
                CPU Threads very well on Export. Ram Preview used 99GB of ram at full res
                6 Core 4930K at 4.4GHz coming soon
                Note - Very significant speed difference if Match Source is selected for H264. The increase in performance for H264 comes from selecting match source only so far. 6 Core results will reflect both.
                • 5. Re: CC 2014 benchmarks so far. Updating as their completed on different systems
                  4930K @ 4.4GHz
                  64GB DDR3 1600
                  780Ti
                  3 Layer - 16:33 (Match Source selected)
                  3 Layer - 25:32 (HDTV 1080P 23.976)
                  4 Layer - 28:04 (HDTV 1080P 23.976)
                  4 Layer – 18:58 (Match Source selected)
                  3 Layer - 2:05
                  4 layer - 2:06
                  CPU threaded well for export after clearing cache by switching from Hardware MPE to Software MPE and back again before linking to AME. Realtime Playback threaded ideally.
                  Average GPU load 35%
                  1 Layer - 1:43
                  Average GPU load 15%
                  4 layer - :52 (Match Sequence H264)
                  CPU Threads very well on export. GPU load peaking at 99% consistantly.
                  1 Layer - :21
                  4 Layer - 5:44
                  CPU Threads poorly
                  AE CC 2014
                  1 Layer: 2:51
                  CPU Threads very well on Export. Ram Preview used 45GB of ram 3x at full res
                  • 6. Re: CC 2014 benchmarks so far. Updating as their completed on different systems
                    E5 2697 V2 12 Core at 2.7Ghz
                    64GB DDR3 1600
                    780Ti
                    3 Layer - 18:13 (Match Source selected)
                    3 Layer - 33:02 (HDTV 1080P 23.976)
                    4 Layer - 34:38 (HDTV 1080P 23.976)
                    4 Layer – 19:45 (Match Source selected)
                    3 Layer - 2:50
                    4 layer - 2:39
                    Average GPU load 42% allot of fluctuations
                    1 Layer - 1:56
                    Average GPU load 15% allot of fluctuations
                    4 layer - :54(Match Sequence H264)
                    4 Layer - 6:05
                    CPU Threads poorly
                    AE CC 2014
                    1 Layer: 2:37
                    CPU Threads very well on Export. Ram Preview used 45GB of ram 2x at full res
                    Did not complete all tests with 2x 780Ti cards on single 12 Core Xeon since results were the same as 1 GPU.
                    Mobile and Xeon laptops next but may be abit before I get some shells in to build and test.
