0 Replies Latest reply on Jun 20, 2014 3:20 PM by nellbern
    Update Missing links
    nellbern
      I would to batch the process of changing document to inches & update all missing links, save & close. The images are located in a folder in another volume. The script is changing document to inches but it is not updating the missing links. In what part of the process I'm failing? I see --> error number -1708
      set source_folder to choose folder with prompt "Select folder containing Indesign Documents"
      tell application "Finder" to set theFiles to files of source_folder whose name extension is "indd"
      set myFolder to choose folder with prompt "Select the folder containing the graphics you want to update"
        set myFiles to every file of folder myFolder
      end tell
      repeat with oneFile in theFiles
        tell application "Adobe InDesign CS4"
        set user interaction level of script preferences to never interact
        activate
        set myDocument to open (oneFile as alias)
        tell myDocument
        tell view preferences
        set ruler origin to page origin
        set horizontal measurement units to inches
        set vertical measurement units to inches
        end tell
        end tell
        tell document 1
        set theLinks to (every link whose status is link missing)
        repeat with i from 1 to count of theLinks
        set thelink to item i of theLinks
        set theName to name of thelink as Unicode text
        set newpath to (myFolder as Unicode text) & theName
        try
        relink thelink to newpath
        end try
        end repeat
        end tell
        close myDocument saving yes
        end tell
      end repeat
