8 Replies Latest reply on Jun 25, 2014 7:20 AM by nellbern
    Not compiling
    nellbern
      The following will batch ID files but it is not compiling.
      Here is i want to achieve: Change doc prefs to inches, resize, bleeds, no slug, master margins, delete all unused masters, unlock-delete some layers & load master pages templates. The load master pages templates is not compiling. my brain is fried & i can't see where the error is
      try
        with timeout of 3600 seconds --1HR
        set source_folder to choose folder with prompt "Select folder containing Indesign Documents to batch"
        tell application "Finder" to set theFiles to files of source_folder whose name extension is "indd"
        end timeout
      on error number -1712 -- the comand time out, so cancel the script
        tell application "System Events"
        tell application process "Finder"
        click button "Cancel" of window "Choose a Folder"
        end tell
        end tell
        error number -128 --throw a user cancelled error
      end try
      repeat with oneFile in theFiles
        tell application "Adobe InDesign CS4"
        set user interaction level of script preferences to never interact
        activate
        set myDocument to open (oneFile as alias)
        tell myDocument
        tell view preferences
        set ruler origin to page origin
        set horizontal measurement units to inches
        set vertical measurement units to inches
        end tell
        --tell document preferences
        --Change current DocSize
        set page width to "7.9375 in"
        set page height to "9.75 in"
        --bleed and slug
        set document bleed bottom offset to ".25 in"
        set document bleed top offset to ".25 in"
        set document bleed inside or left offset to ".25 in"
        set document bleed outside or right offset to ".25 in"
        set slug bottom offset to "0"
        set slug top offset to "0"
        set slug inside or left offset to "0"
        set slug right or outside offset to "0"
        end tell
        --delete Unused Master pages- delete used Master
        set moreMasters to {}
        repeat with i from 1 to count of documents
        tell document i
        set allMasters to every master spread
        set theMasters to applied master of every page
        repeat with x in theMasters
        set end of moreMasters to applied master of x
        end repeat
        set theMasters to theMasters & moreMasters
        repeat with x in allMasters
        if x is not in theMasters then delete x
        end repeat
        if (exists (master spread "Z-OMX Master")) and (count master spreads) > 1 then delete master spread "Z-OMX Master"
        end tell
        end repeat
        end tell
        --change margins of the master spread
        set myMasterSpread to master spread 1
        tell margin preferences of page 1 of myMasterSpread
        -- page margins and columns.
        set top to ".25 in"
        set bottom to ".5 in"
        set left to ".5" --inside
        set right to ".75 in" --outside
        set column count to 2
        set column gutter to 0.279
        end tell
        --Page margins master page for the right-hand page.
        tell margin preferences of page 2 of myMasterSpread
        set top to ".25 in"
        end tell
        delete guides
        --unlock/colorize
        tell guide preferences
        set guides locked to false
        set ruler guides color to cyan
        end tell
        --make guides on Master Pages
        tell myMasterSpread's page 1
        make guide with properties {orientation:vertical, location:0.25}
        make guide with properties {orientation:vertical, location:7.6875}
        make guide with properties {orientation:horizontal, location:0.5}
        make guide with properties {orientation:horizontal, location:9.5}
        end tell
        tell myMasterSpread's page 2
        end tell
      --load Master template
      set docRef to document 1 of application "Adobe InDesign CS4"
      set templatePath to "Macintosh HD:Applications:Adobe InDesign CS4:Templates:Maxi_Templates.indd"
      (*Boolean if false indicates master spreads should be renamed in case of name clash*)
      loadMasters(docRef, templatePath, false)
        set templatePath to file path as string
        --set templatePath to "Macintosh HD:Applications:Adobe InDesign CS4:Templates:Maxi_Templates.indd"
      end tell
      (*Loads master spreads from referenced document.*)
      on loadMasters(docRef, filePath, doOverwrite)
        tell docRef
        if doOverwrite = true then
        load masters from filePath global strategy for master page load all with overwrite
        else
        load masters from filePath global strategy for master page load all with rename
        end if
        end tell
        end tell
      end loadMasters
        --display dialog "" buttons {"Cancel"} default button 1
        close myDocument saving yes
        end tell
        set user interaction level of script preferences to interact with all
        end tell
      end repeat
      beep 5
      with timeout of 10000 seconds
        activate
        --display dialog "DONE" buttons {" :-) OK"} with icon 1 default button 1 giving up after 15
        --display dialog "Done, check the links" with icon path to resource "ID_App_Icon.icns" in bundle (path to application "Adobe InDesign CS4")
        display dialog "DONE" buttons {" :-) OK"} giving up after 15 with icon path to resource "ID_App_Icon.icns" in bundle (path to application "Adobe InDesign CS4") --giving up after 15
        end tell
      end timeout
        • 1. Re: Not compiling
          Dirk Becker Level 4
          You're telling too much
          Seriously, that method declaration "on loadMasters" should not go into the tell clause, methods better stay top level. I moved it to the top of the script.
          You can also eliminate a few nested "tell application InDesign", and to make things clear wrap the whole script into an explicit "on run" which is otherwise implied.
          The following compiles with my CS6, I did not test anything further.
            tell application "Adobe InDesign CS6"
            tell docRef
            else
            end if
            end tell
            end tell
          end loadMasters
          on run
            try
            end timeout
            end tell
            end tell
            end try
            activate
            tell myDocument
            end tell
            --bleed and slug
            end tell
            tell document i
            end repeat
            end repeat
            end tell
            end repeat
            set top to ".25 in"
            end tell
            set top to ".25 in"
            end tell
            delete guides
            --unlock/colorize
            end tell
            end tell
            end tell
            set templatePath to "Macintosh HD:Applications:Adobe InDesign CS6:Templates:Maxi_Templates.indd"
            --set templatePath to "Macintosh HD:Applications:Adobe InDesign CS6:Templates:Maxi_Templates.indd"
            end tell --- document
            end repeat
            end tell -- application
            beep 5
            activate
            --display dialog "Done, check the links" with icon path to resource "ID_App_Icon.icns" in bundle (path to application "Adobe InDesign CS6")
            display dialog "DONE" buttons {" :-) OK"} giving up after 15 with icon path to resource "ID_App_Icon.icns" in bundle (path to application "Adobe InDesign CS6") --giving up after 15
            end tell
            end timeout
          end run
          • 2. Re: Not compiling
            nellbern Level 1
            Thank you Dirk. I'm getting an error:
            Adobe InDesign CS4 got an error: every document of document \"P_1.indd\" doesn’t understand the count message." number -1708 from every document of document "P_1.indd"
            • 3. Re: Not compiling
              Dirk Becker Level 4
              Like I said, I did not test any further, and you're "tell"ing too much.
              Try to remove the loop/tell over the documents, the outside tell is already adressing a document.
              The block in question looks like copy-pasted from somewhere else, it would then become
                end repeat
                end repeat
              -- fancy comment here
              • 4. Re: Not compiling
                Dirk Becker Level 4
                The following script demonstrates some lesser known AppleScript syntax tricks.
                -- address InDesign version independent, by ID.
                -- works like an implicit tell application within the methods
                property parent : application id "com.adobe.indesign"
                -- help the applescript compiler
                using terms from application "Adobe InDesign CS6"
                  -- You could isolate other code blocks into similar "on …" handlers.
                  on deleteUnusedMasterSpreads(aDoc)
                  tell aDoc
                  -- build an ID list
                  set usedMasterIDs to id of applied master of every page
                  -- use "whose" to filter
                  -- store the whole expression as "reference"
                  set unusedMasterSpreads to a reference to (master spreads whose id is not in usedMasterIDs)
                  -- unfortunately, delete does not ignore the empty list
                  if exists unusedMasterSpreads then
                  delete unusedMasterSpreads
                  end if
                  end tell -- aDoc
                  end deleteUnusedMasterSpreads
                  on run
                  deleteUnusedMasterSpreads(document 1)
                  end run
                end using terms from
                • 5. Re: Not compiling
                  nellbern Level 1
                  You are absolutely right I copied the code from someone. I have some knowledge in AS but not good enough to build code from scratch. That is the consequence  of copying code but that's why I posted here so people like you can help me
                  • 6. Re: Not compiling
                    nellbern Level 1
                      How do apply the [None] master to all Master page? I tried this line & Im getting an error:
                    Invalid value for set property 'applied master'. Expected master spread or nothing, but received nothing." number 30477
                    set applied master of every master spread to master spread "[None]"
                    • 7. Re: Not compiling
                      Dirk Becker Level 4
                      Please mark this thread as answered if your original problem is solved, then open a separate thread per different question. It also helps to find AppleScript questions if you use an [AS] in the subject line.
                      • 8. Re: Not compiling
                        nellbern Level 1
                        I did marked as answered. Thanks for your help
