9 Replies Latest reply on Jun 22, 2014 5:47 AM by rimcrazyph
    Over 4 mins to start AE CC 2014 on Mavericks???????
    rimcrazyph Level 1
      Ok, So I've upgraded my CC subscription to all of the 2014 apps.  I have a 2011 MBP.  It has a screaming SSD HD, 16Gb of Ram and a 2.3 Ghz Quad Core I7 CPU.   With the upgrade to 2014 AE now takes a whopping 4:09 to load. !?!?!?!?!?!?!  Are you kidding me?  (Note this is not the first load, that took forever, this is now the consistent load time).  In addition, it is telling me that Quicktime is not installed.  Really?  This is a Mac with OSX 10.9.3 installed.  So my questions are:
      1) What in the world is going on?
      2) Is there anything I can do to speed this up?
      3) What is up with AE not finding Quicktime.  How can I fix this.
      Slow in Phoenix........
        • 1. Re: Over 4 mins to start AE CC 2014 on Mavericks???????
          Check your Activity Monitor. I have a similar machine, a MacMini, and a new MacPro. All launch without problems. This tells me that something, like a firewall or other app is creating a conflict.
          • 2. Re: Over 4 mins to start AE CC 2014 on Mavericks???????
            Todd_Kopriva Level 8
            I've seen a couple of reports of this, and it seems to be a problem with After Effects failing to establish communication with the component that it uses to communicate with Apple's 32-bit QuickTime system (Adobe QT32 Server).
            Typically, when this sort of problem occurs, it's because of an overly aggressive firewall or similar software blocking communication over TCP.
            There's more detail about that here:
            troubleshooting QuickTime errors with After Effects CS5, CS5.5, CS6, and CC
            • 3. Re: Over 4 mins to start AE CC 2014 on Mavericks???????
              rimcrazyph Level 1
              Well I checked the activity monitor and something appears to be crashing.  I do not have any anti-virus on this machine and their should not be any firewall issues.  Below is  a screen dump of the activity monitor.  Is there a log file that is written when AE boots that might perhaps give more insight into what is going on?
              • 4. Re: Over 4 mins to start AE CC 2014 on Mavericks???????
                You can enable logging using the Help > Enable Logging command in After Effects.
                • 5. Re: Over 4 mins to start AE CC 2014 on Mavericks???????
                  rimcrazyph Level 1
                  Here are some snippets from the log file.  Obviously the Adobe QT32 Server.app is not running.  So where do I go from here????
                  Ticks = 7099  <140735225324304> <DynamicLink> <5> Attempting to launch dynamiclinkmanager
                  Ticks = 7099  <140735225324304> <DynamicLink> <5> /Applications/Adobe After Effects CC 2014/Adobe After Effects CC 2014.app/Contents/dynamiclinkmanager.app
                  Ticks = 7159  <140735225324304> <DynamicLink> <5> Attempting to launch dynamiclinkmanager
                  Ticks = 7159  <140735225324304> <DynamicLink> <5> /Applications/Adobe After Effects CC 2014/Adobe After Effects CC 2014.app/Contents/dynamiclinkmanager.app
                  Ticks = 7219  <140735225324304> <DynamicLink> <5> Attempting to launch dynamiclinkmanager
                  Ticks = 7219  <140735225324304> <DynamicLink> <5> /Applications/Adobe After Effects CC 2014/Adobe After Effects CC 2014.app/Contents/dynamiclinkmanager.app
                  Ticks = 7279  <140735225324304> <Assert> <0> Debug Assert failed!
                  Ticks = 7279  <140735225324304> <Assert> <0> Unable to launch /Applications/Adobe After Effects CC 2014/Adobe After Effects CC 2014.app/Contents/Adobe QT32 Server.app
                  CreateNamedServerConnection returned an error!
                  Expression: false
                  Process: Adobe After Effects CC 2014.0 (13.0)
                  Process ID: 1153
                  Thread ID: 140735225324304
                  Thread Name:
                  File: /ae1300cc/pro/ext/adobe/MediaCore/Utilities/QT32Client/Src/QT32ServerManager.cpp
                  Line: 203
                  Function: virtual ASL::Result QT32Client::QT32ServerManager::InitializeClient(bool)
                  Ticks = 7279  <140735225324304> <Assert> <0> QT32Client::QT32Client::Initialize(ASL::InterfaceRef<QT32Client::QT32ServerManager, QT32Client::IQT32ServerManager> const&, bool)
                  QT32Client::Create()
                  ExporterQuickTimeHost::OnStartup(exportStdParms*, exExporterInfoRec*)
                  PrExporterModule<ExporterQuickTimeHost>::ExportEntry(int, exportStdParms*, void*, void*)
                  xSDKExport
                  ML::ExporterPluginModule::CallExportModule(int, void*, void*)
                  ML::ExporterPluginModule::StartupFromDisk(unsigned int, bool)
                  ML::ExporterModuleFactory::CreateUnknown(ASL::InterfaceRef<ML::IPlugin, ML::IPlugin>, int, int&)
                  ML::(anonymous namespace)::AddPlugin(ML::PluginEntry const&, bool&)
                  ML::(anonymous namespace)::LoadPluginList(ML::PluginNameList const&, std::vector<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::allocator<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >&)
                  ML::LoadPlugins(std::vector<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::allocator<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::vector<std::basic_string<unsigned
                  ML::PluginSupport::LoadAllPlugins(std::vector<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::allocator<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::vector<std::basi
                  ae::prem::MediaCoreData::MediaCoreData(char const*, bool, PF_World*, bool, bool, bool)
                  PREM_Birth
                  InitPREM(bool, bool, bool, bool)
                  CEggApp::BirthPkgGrpD(bool)
                  CEggApp::IEggApp(bool, bool)
                  CEggApp::CEggApp(bool, bool, int)
                  MainMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, void**, int, int, int)
                  EggMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, int)
                  main
                  start
                  ??? <1>
                  Ticks = 7329  <140735225324304> <ALOG> <5> PREM MediaCoreData About to Init DVAMediaBrowser
                  Ticks = 7348  <140735225324304> <ALOG> <5> EGG IEggApp Finished Initing Media Core
                  Ticks = 7348  <140735225324304> <ALOG> <5> EGG IEggApp Warning Quicktime not installed
                  Ticks = 7348  <140735225324304> <ALOG> <5> EGG IEggApp Media Core initialized successfully
                  • 6. Re: Over 4 mins to start AE CC 2014 on Mavericks???????
                    rimcrazyph Level 1
                    A few other notes.  This is ONLY a CC 2014 issue.  I opened up the previous version of AE CC and it opens fine AND I rendered a QT output just fine.  No problems.  PP CC 2014 has the same issue, (I gave up on it starting after 15 mins).  I believe Photoshop CC 2014 does also as it was having some slow start issues all be it not as bad as AE or PP.
                    • 7. Re: Over 4 mins to start AE CC 2014 on Mavericks???????
                      Try setting the _entire_ preferences folder and its contents to be read/write, not just read-only.
                      I mean this folder:
                      [drive]/Users/[username]/Library/Preferences/Adobe/
                      The Dynamic Link Manager seems to be failing to start because permissions are set incorrectly on some items in that folder.
                      This only seems to be a problem on Mac OS.
                      • 8. Re: Over 4 mins to start AE CC 2014 on Mavericks???????
                        I just wrote this brief article to summarize the solution to the problem that I'm pretty sure that you're hitting:
                        fixing permissions problem on Mac OS that impedes start of Adobe applications
                        • 9. Re: Over 4 mins to start AE CC 2014 on Mavericks???????
                          rimcrazyph Level 1
                          Bingo!!! Todd you are the bomb!.    That was the issue.  I changed permissions and it fired right up as it should.  Thanks so much.  I am fairly geeky but I don't think I ever would have found that.
                          Kudos your way.  I was contemplating a clean build and not looking forward to that at all.
