4 Replies Latest reply on Jun 21, 2014 11:18 AM by POCPhoto
    spin and path blur not available
    POCPhoto
      I have updated PS on creative cloud but cannot access the new spin and path blur filters.  Only the older filters are there.  Is there a way to fix this?
        • 1. Re: spin and path blur not available
          SG... Adobe Employee
          Make sure you are opening the 2014 release (15.0) of Photoshop CC. You can confirm by going to Help> System Info...
          When you're there copy paste the info in a reply so we can see your video card model and driver version.
          regards,
          steve
          • 2. Re: spin and path blur not available
            POCPhoto Level 1
            Hi Steve,
            I guess I am behind on a release though I have tried checking updates and Adobe says I am up to date.  I have 14.2.1.  Can I download 15.0 from Adobe?  I'm new to CC, as you can probably tell.
            Here is my info.  Thanks much for your kind help.
            Mark
            Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64
            Operating System: Windows 7 64-bit
            Version: 6.1 Service Pack 1
            System architecture: Intel CPU Family:6, Model:10, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
            Physical processor count: 4
            Logical processor count: 8
            Processor speed: 2195 MHz
            Built-in memory: 16332 MB
            Free memory: 6053 MB
            Memory available to Photoshop: 14652 MB
            Memory used by Photoshop: 59 %
            Image tile size: 1024K
            Image cache levels: 4
            Font Preview: Medium
            TextComposer: Latin
            Display: 1
            Display Bounds: top=0, left=0, bottom=900, right=1600
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGPUs=1
            gpu[0].OGLVersion="3.0"
            gpu[0].MemoryMB=3845
            gpu[0].RectTextureSize=8192
            gpu[0].Renderer="Intel(R) HD Graphics Family"
            gpu[0].RendererID=0
            gpu[0].Vendor="Intel"
            gpu[0].VendorID=0
            gpu[0].HasNPOTSupport=1
            gpu[0].DriverVersion="8.882.2.3000"
            gpu[0].Driver="igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32"
            gpu[0].DriverDate="20110930000000.000000-000"
            gpu[0].CompileProgramGLSL=1
            gpu[0].TestFrameBuffer=1
            gpu[0].OCLPresent=0
            gpu[0].CUDASupported=0
            gpu[0].OCLBandwidth=0
            gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Intel Build 8.15.10.2476"
            gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
            gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
            gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[512]
            gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[1024]
            gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[41]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
            License Type: Subscription
            Serial number: 96040665903990952997
            Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\
            Temporary file path: C:\Users\Mark\AppData\Local\Temp\
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
            C:\, 673.3G, 381.3G free
            Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\Plug-Ins\
            Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\
            Installed components:
            ACE.dll ACE 2013/10/29-11:47:16 79.548223 79.548223
            adbeape.dll Adobe APE 2013/02/04-09:52:32 0.1160850 0.1160850
            AdobeLinguistic.dll Adobe Linguisitc Library 7.0.0
            AdobeOwl.dll Adobe Owl 2013/10/25-12:15:59 5.0.24 79.547804
            AdobePDFL.dll PDFL 2013/10/29-11:47:16 79.508720 79.508720
            AdobePIP.dll Adobe Product Improvement Program 7.0.0.1786
            AdobeXMP.dll Adobe XMP Core 2013/10/29-11:47:16 79.154911 79.154911
            AdobeXMPFiles.dll Adobe XMP Files 2013/10/29-11:47:16 79.154911 79.154911
            AdobeXMPScript.dll Adobe XMP Script 2013/10/29-11:47:16 79.154911 79.154911
            adobe_caps.dll Adobe CAPS 7,0,0,21
            AGM.dll AGM 2013/10/29-11:47:16 79.548223 79.548223
            ahclient.dll AdobeHelp Dynamic Link Library 1,8,0,31
            aif_core.dll AIF 5.0 79.534508
            aif_ocl.dll AIF 5.0 79.534508
            aif_ogl.dll AIF 5.0 79.534508
            amtlib.dll AMTLib (64 Bit) 7.0.0.249 BuildVersion: 7.0; BuildDate: Thu Nov 14 2013 15:55:50) 1.000000
            ARE.dll ARE 2013/10/29-11:47:16 79.548223 79.548223
            AXE8SharedExpat.dll AXE8SharedExpat 2011/12/16-15:10:49 66.26830 66.26830
            AXEDOMCore.dll AXEDOMCore 2011/12/16-15:10:49 66.26830 66.26830
            Bib.dll BIB 2013/10/29-11:47:16 79.548223 79.548223
            BIBUtils.dll BIBUtils 2013/10/29-11:47:16 79.548223 79.548223
            boost_date_time.dll DVA Product 7.0.0
            boost_signals.dll DVA Product 7.0.0
            boost_system.dll DVA Product 7.0.0
            boost_threads.dll DVA Product 7.0.0
            cg.dll NVIDIA Cg Runtime 3.0.00007
            cgGL.dll NVIDIA Cg Runtime 3.0.00007
            CIT.dll Adobe CIT 2.1.6.30929 2.1.6.30929
            CITThreading.dll Adobe CITThreading 2.1.6.30929 2.1.6.30929
            CoolType.dll CoolType 2013/10/29-11:47:16 79.548223 79.548223
            dvaaudiodevice.dll DVA Product 7.0.0
            dvacore.dll DVA Product 7.0.0
            dvamarshal.dll DVA Product 7.0.0
            dvamediatypes.dll DVA Product 7.0.0
            dvaplayer.dll DVA Product 7.0.0
            dvatransport.dll DVA Product 7.0.0
            dvaunittesting.dll DVA Product 7.0.0
            dynamiclink.dll DVA Product 7.0.0
            ExtendScript.dll ExtendScript 2013/10/30-13:12:12 79.546835 79.546835
            FileInfo.dll Adobe XMP FileInfo 2013/10/25-03:51:33 79.154511 79.154511
            filter_graph.dll AIF 5.0 79.534508
            icucnv40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
            icudt40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
            imslib.dll IMSLib DLL 7.0.0.145
            JP2KLib.dll JP2KLib 2013/10/29-11:47:16 79.248139 79.248139
            libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
            libiomp5md.dll Intel(R) OMP Runtime Library 5.0
            libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
            LogSession.dll LogSession 2.1.2.1785
            mediacoreif.dll DVA Product 7.0.0
            MPS.dll MPS 2013/10/29-11:47:16 79.535029 79.535029
            msvcm80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
            msvcm90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
            msvcp100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
            msvcp80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
            msvcp90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
            msvcr100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
            msvcr80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
            msvcr90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
            ONCore8.dll ONCore 7.0.0.0
            ONCoreFoundation8.dll ONCoreFoundation7 7, 0, 0, 0
            ONDocument8.dll ONDocument 7.0.0.0
            ONProxySupport8.dll ONProxySupport 1.0.0.0
            PatchMatch.dll PatchMatch 2013/10/29-11:47:16 79.542390 79.542390
            pdfsettings.dll Adobe PDFSettings 1.04
            Photoshop.dll Adobe Photoshop CC CC
            Plugin.dll Adobe Photoshop CC CC
            PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 4.2.0.36
            PSArt.dll Adobe Photoshop CC CC
            PSViews.dll Adobe Photoshop CC CC
            SCCore.dll ScCore 2013/10/30-13:12:12 79.546835 79.546835
            ScriptUIFlex.dll ScriptUIFlex 2013/10/30-13:12:12 79.546835 79.546835
            svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
            tbb.dll Intel(R) Threading Building Blocks for Windows 4, 1, 2012, 1003
            tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 1, 2012, 1003
            updaternotifications.dll Adobe Updater Notifications Library 7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 7.0.1.102
            WRServices.dll WRServices Mon Feb 25 2013 16:09:10 Build 0.19078 0.19078
            Required plug-ins:
            3D Studio 14.2.1 (14.2.1 x001)
            Accented Edges 14.2.1
            Adaptive Wide Angle 14.2.1
            Angled Strokes 14.2.1
            Average 14.2.1 (14.2.1 x001)
            Bas Relief 14.2.1
            BMP 14.2.1
            Camera Raw 8.5
            Camera Raw Filter 8.5
            Chalk & Charcoal 14.2.1
            Charcoal 14.2.1
            Chrome 14.2.1
            Cineon 14.2.1 (14.2.1 x001)
            Clouds 14.2.1 (14.2.1 x001)
            Collada 14.2.1 (14.2.1 x001)
            Color Halftone 14.2.1
            Colored Pencil 14.2.1
            CompuServe GIF 14.2.1
            Conté Crayon 14.2.1
            Craquelure 14.2.1
            Crop and Straighten Photos 14.2.1 (14.2.1 x001)
            Crop and Straighten Photos Filter 14.2.1
            Crosshatch 14.2.1
            Crystallize 14.2.1
            Cutout 14.2.1
            Dark Strokes 14.2.1
            De-Interlace 14.2.1
            Dicom 14.2.1
            Difference Clouds 14.2.1 (14.2.1 x001)
            Diffuse Glow 14.2.1
            Displace 14.2.1
            Dry Brush 14.2.1
            Eazel Acquire 14.2.1 (14.2.1 x001)
            Embed Watermark 4.0
            Entropy 14.2.1 (14.2.1 x001)
            Extrude 14.2.1
            FastCore Routines 14.2.1 (14.2.1 x001)
            Fibers 14.2.1
            Film Grain 14.2.1
            Filter Gallery 14.2.1
            Flash 3D 14.2.1 (14.2.1 x001)
            Fresco 14.2.1
            Glass 14.2.1
            Glowing Edges 14.2.1
            Google Earth 4 14.2.1 (14.2.1 x001)
            Grain 14.2.1
            Graphic Pen 14.2.1
            Halftone Pattern 14.2.1
            HDRMergeUI 14.2.1
            IFF Format 14.2.1
            Ink Outlines 14.2.1
            JPEG 2000 14.2.1
            Kurtosis 14.2.1 (14.2.1 x001)
            Lens Blur 14.2.1
            Lens Correction 14.2.1
            Lens Flare 14.2.1
            Liquify 14.2.1
            Matlab Operation 14.2.1 (14.2.1 x001)
            Maximum 14.2.1 (14.2.1 x001)
            Mean 14.2.1 (14.2.1 x001)
            Measurement Core 14.2.1 (14.2.1 x001)
            Median 14.2.1 (14.2.1 x001)
            Mezzotint 14.2.1
            Minimum 14.2.1 (14.2.1 x001)
            MMXCore Routines 14.2.1 (14.2.1 x001)
            Mosaic Tiles 14.2.1
            Multiprocessor Support 14.2.1 (14.2.1 x001)
            Neon Glow 14.2.1
            Note Paper 14.2.1
            NTSC Colors 14.2.1 (14.2.1 x001)
            Ocean Ripple 14.2.1
            Oil Paint 14.2.1
            OpenEXR 14.2.1
            Paint Daubs 14.2.1
            Palette Knife 14.2.1
            Patchwork 14.2.1
            Paths to Illustrator 14.2.1
            PCX 14.2.1 (14.2.1 x001)
            Photocopy 14.2.1
            Photoshop 3D Engine 14.2.1 (14.2.1 x001)
            Photoshop Touch 14.0
            Picture Package Filter 14.2.1 (14.2.1 x001)
            Pinch 14.2.1
            Pixar 14.2.1 (14.2.1 x001)
            Plaster 14.2.1
            Plastic Wrap 14.2.1
            PNG 14.2.1
            Pointillize 14.2.1
            Polar Coordinates 14.2.1
            Portable Bit Map 14.2.1 (14.2.1 x001)
            Poster Edges 14.2.1
            Radial Blur 14.2.1
            Radiance 14.2.1 (14.2.1 x001)
            Range 14.2.1 (14.2.1 x001)
            Read Watermark 4.0
            Reticulation 14.2.1
            Ripple 14.2.1
            Rough Pastels 14.2.1
            Save for Web 14.2.1
            ScriptingSupport 14.2.1
            Shake Reduction 14.2.1
            Shear 14.2.1
            Skewness 14.2.1 (14.2.1 x001)
            Smart Blur 14.2.1
            Smudge Stick 14.2.1
            Solarize 14.2.1 (14.2.1 x001)
            Spatter 14.2.1
            Spherize 14.2.1
            Sponge 14.2.1
            Sprayed Strokes 14.2.1
            Stained Glass 14.2.1
            Stamp 14.2.1
            Standard Deviation 14.2.1 (14.2.1 x001)
            STL 14.2.1 (14.2.1 x001)
            Sumi-e 14.2.1
            Summation 14.2.1 (14.2.1 x001)
            Targa 14.2.1
            Texturizer 14.2.1
            Tiles 14.2.1
            Torn Edges 14.2.1
            Twirl 14.2.1
            Underpainting 14.2.1
            Vanishing Point 14.2.1
            Variance 14.2.1 (14.2.1 x001)
            Variations 14.2.1 (14.2.1 x001)
            Water Paper 14.2.1
            Watercolor 14.2.1
            Wave 14.2.1
            Wavefront|OBJ 14.2.1 (14.2.1 x001)
            WIA Support 14.2.1 (14.2.1 x001)
            Wind 14.2.1
            Wireless Bitmap 14.2.1 (14.2.1 x001)
            ZigZag 14.2.1
            Optional and third party plug-ins:
            Perfect Batch 8 8.5.0
            Perfect BW 8 8.5.0
            Perfect BW 8 Filter 8.5.0
            Perfect BW 8 Smart Filter 8.5.0
            Perfect Effects 8 8.5.0
            Perfect Effects 8 Filter 8.5.0
            Perfect Effects 8 Smart Filter 8.5.0
            Perfect Enhance 8 8.5.0
            Perfect Enhance 8 Filter 8.5.0
            Perfect Enhance 8 Smart Filter 8.5.0
            Perfect Mask 8 8.5.0
            Perfect Mask 8 Filter 8.5.0
            Perfect Mask 8 Smart Filter 8.5.0
            Perfect Portrait 8 8.5.0
            Perfect Portrait 8 Filter 8.5.0
            Perfect Portrait 8 Smart Filter 8.5.0
            Perfect Resize 8 8.5.0
            Perfect Resize 8 Engine Automation 8.5.0
            Perfect Resize 8 Engine Filter 8.5.0
            Perfect Resize 8 Filter 8.5.0
            Plug-ins that failed to load: NONE
            Flash:
            onOne
            Kuler
            Adobe Exchange
            Installed TWAIN devices: NONE
            • 3. Re: spin and path blur not available
              Hi Mark,
              Try this link for info on installing the 2014 version:
              2014 release of Photoshop CC: FAQ
              regards,
              steve
              • 4. Re: spin and path blur not available
                POCPhoto Level 1
                Steve - I contacted someone on chat help and there was an issue with the update that I had done this AM.  Even though it showed up to date it was not.  So, reinstalled the update and I now have 15.0 and the blur filters.  Thanks for your help.  You gave me a starting point to solve.
                Mark
