7 Replies Latest reply on Jun 23, 2010 2:29 PM by IlyaLad
    ActiveX Xtra - projector doesn't terminate
    tfiene
      Hi all,
      Has anyone had problems with the projector not terminating correctly
      when working with the ActiveX Xtra? We are working on a Director
      application that uses some custom ActiveX controls. When the user
      quits the projector, the Process for the projector does not
      terminate. If you look in the Windows Task Manager and click on the
      Processes tab, the process for the projector is still there even
      after the user quits.
      I am using Director MX 2004 on Windows XP Pro. Users with other
      versions of Windows are also seeing the problem.
      One interesting note is that if we put the ActXPriv.x32 user
      interface component in the Xtras folder that the projector uses, the
      problem goes away (the process terminates correctly upon quitting).
      Unfortunately the documentation for the ActiveX Xtra says "Under no
      circumstances should the user interface component 'ActXPriv.X32' be
      redistributed with a packaged Director multimedia title."
      Thanks for any help!
      Tom
        • 1. Re: ActiveX Xtra - projector doesn't terminate
          Level 7
          I noticed your post on the other list you posted this to, and was going
          to suggest you try the ActiveX Xtra from the ActiveCompanionSet to see
          if it makes a difference: < http://www.xtramania.com/Downloads/VbScriptXtra/>
          • 2. Re: ActiveX Xtra - projector doesn't terminate
            Level 7
            I've been programming my own activex lately to control USB I/O boards. I'm
            finding activeX works a little better in Director MX than MX 2004 where in
            the ActiveX won't even load in.
            You might want to try making Director jump to a frame that the activeX is
            not in when it quits. Also, check that the ActiveX is properly cleaning up
            after itself when it terminates. Such as if it has something open, a file, a
            device, whatever.
            TR
            "tfiene" <webforumsuser@macromedia.com> wrote in message
            news:e9jvcn$gi$1@forums.macromedia.com...
            > Hi all,
            > Tom
            • 3. Re: ActiveX Xtra - projector doesn't terminate
              tfiene Level 1
              Thanks for the idea Sean. I tried the version of ActiveX Xtra that you mentioned and it does not seem to work.
              • 4. Re: ActiveX Xtra - projector doesn't terminate
                saoudi
                I'm getting the same problem in D11.5 on windows XPPro SP3 ( some bugs never die )
                So when you add the 'ActXPriv.X32' do you still keep the 'ActiveX.x32' in the xtras folder as well?
                • 5. Re: ActiveX Xtra - projector doesn't terminate
                  IlyaLad
                  I just thought that you might fail to unregister your activeX component when you stop the projector (in case you deliver the component's dll to the user with your projector package). Say my component is called axvlc.dll. It is placed in the same directory as my stub projector (given by: _movie.pass)
                  On startMovie -- I register the component:
                       axRegSuccess = ActiveXControlRegister(_movie.path&"axvlc.dll")
                       --axRegSuccess must be -1
                  end
                  on stopMovie -- I unregister it
                        axUnRegSuccess = ActiveXControlUnRegister(_movie.path&"axvlc.dll")
                        --axUnRegSuccess must be -1
                  end
                  • 6. Re: ActiveX Xtra - projector doesn't terminate
                    saoudi Level 1
                    What if I don't have a component .dll in the same folder as the projector?
                    I'm using the rtfText box which is a RICHTX32.OCX in windows system32 folder.
                    Do I still register it like you showed?
                    I sometimes use windows web browser component (dont know what ocx/dll) I just pick it from the drop list.
                    • 7. Re: ActiveX Xtra - projector doesn't terminate
                      IlyaLad Level 1
                      Hi Saoudi,
                      If you going to distribute your projector to users without bringing them the activex dll, then you must be sure that  the activeX is already  installed (means registerd) on the computers of your users, not only on yours. And with your case with the rtf component, it is perhaps automatically so.
                      Now answerring to your question. No, in your case, you don't have to bring th dll and register/unregister it. At least as far as I understand; I am not an expert in that.
                      Ilya
