3 Replies Latest reply on Jun 22, 2014 4:52 PM by Kerrigan Marois
    Packaging fonts to send to another designer
    Rachie000
      I am a freelance designer and I am passing some of my clients onto other designers. These clients have requested that I send them the files for all the projects I have worked on for them. Am I allowed to send the fonts that are used in these files as well or that would violate licensing agreements? When I package the InDesign files, I know that a box pops up reminding people that the fonts are under license and cannot be passed along unless they are going to a printer or other service provider. Does this include another designer?
      I'm just trying to do the right thing ... thanks!
        • 1. Re: Packaging fonts to send to another designer
          TᴀW Adobe Community Professional & MVP
          It does include another designer, yes. It also includes printers.
          But it depends what fonts you've used. If they're commercial fonts, then
          normally they can't be transferred. If they're free fonts (any of the
          fonts in Google's font collection, for instance), then there's no problem.
          • 2. Re: Packaging fonts to send to another designer
            In most cases the printer or service bureau also needs their own license to use the packaged fonts (which is why PDF with embedded fonts is a better way to work). The right thing is to tell the new designer they need to invest in the fonts themselves.
            • 3. Re: Packaging fonts to send to another designer
              Kerrigan Marois Level 1
              Hi Rachie,
              Unfortunately this is a very sensitive issue and can only truly be solved by looking through the specific End User License Agreement (EULA) for the fonts in question. You don't need to read the entire thing, but a couple items that are important to this issue specifically are the "level of embedding" thats in the EULA for the font. Look for
              Print and preview
              Editable
              Installable
              No embedding
              There are a couple more, and longer descriptions can be found here: Font Embedding Permissions | Adobe
              Sorry about not being able to give a straight answer, but font licensing, sharing and lending is all extremely sensitive and different for many fonts. If you are too bus and therefore sub-contracting these guys, it would be better for you to hire them, then they are your employees and they can use your companies license (again, might not be possible based on the EULA), OR, if you aren't hiring them and the client is demanding that, its too bad, part of the value of you as a freelancer includes all the font licenses you have, and thats something, unlike your work that you can't give to another designer. Its up to them or the client to buy that font.
              You can give the pdf to your work since you created it, but the fonts belong to the foundries, and thats why this is so complicated. Hope I could at least help clarify!
