17 Replies Latest reply on Jul 2, 2014 6:43 PM by HarveyLiu
    Script for batch delet redundant layer
    HarveyLiu Level 1
      I have thousands files in the different folders, each file has same layer named “Job Info”. Can someone help me to write a script for del this layer folder by folder?
      I expected the script tells me that I have to select a folder, then it can automatically open the files, del “job info” layer then save file, rewrite, close file
        • 1. Re: Script for batch delet redundant layer
          Chinnadk Level 4
          Try this.
          var folder = Folder.selectDialog ("Select the root folder");
          var myfiles = [];
          getsubfolderfiles(folder);
          for(var i =0;i<myfiles.length;i++)
                  var doc = app.open(myfiles[i],false);
                  var _layer = doc.layers.item("Job Info");
                  _layer.remove();
                  doc.save();
                  doc.close();
          function getsubfolderfiles(folder)
              var filelist = folder.getFiles();
              for(var i =0;i<filelist.length;i++)
                  if(filelist[i] instanceof Folder)
                      getsubfolderfiles (filelist[i]);
                  else if(filelist[i] instanceof File)
                      if(filelist[i].name.indexOf(".indd") > -1){
                          myfiles.push(filelist[i]);
          Regards,
          Chinna
          • 2. Re: Script for batch delet redundant layer
            HarveyLiu Level 1
            Great, helpfull! thank you so much, appreciate!
            • 3. Re: Script for batch delet redundant layer
              ASHOK KUMAR Level 1
              Hi Chinna
              Thanks for the your information, but how can we add additional 3 layers?
              ASHRAM
              • 4. Re: Re: Script for batch delet redundant layer
                Chinnadk Level 4
                Hi Ashram,
                Try this.
                var myfiles = [];
                var _layers = ["Job Info", "test1", "test2", "test3"];
                        for(var j=0;j<_layers.length;j++)
                            try
                                doc.layers.item(_layers[j]).remove();
                            catch(e){}
                        doc.save();
                        doc.close();
                Regards,
                Chinna
                • 5. Re: Script for batch delet redundant layer
                  ASHOK KUMAR Level 1
                  Hi Chinna
                  Thanks for your script.
                  But there is NO layers added in particular folder Indesign file.
                  ASHRAM
                  • 6. Re: Script for batch delet redundant layer
                    HarveyLiu Level 1
                    Hi, Chinna
                    here is a script for remove missing link oobject:
                    var link, image, frame,
                    doc = app.activeDocument,
                    links = doc.links,
                    counter = 0;
                    for (var i = links.length-1; i >= 0; i--) {
                        if (links[i].status == LinkStatus.LINK_MISSING) {
                            try {
                                link = links[i];
                                image = link.parent;
                                frame = image.parent;
                                frame.remove();
                                counter++;
                            catch (err) {
                                $.writeln(i + " - " + err);
                    is that possible to combine the function into remove layer?
                    I expected the script tells me that I have to select a folder, then it can automatically open the files, del “job info” layer, remove missing link object then save file, rewrite, close file
                    • 7. Re: Script for batch delet redundant layer
                      ASHOK KUMAR Level 1
                      Hi Chinna
                      Any update?
                      ASHRAM
                      • 8. Re: Re: Script for batch delet redundant layer
                        Chinnadk Level 4
                        Hi Ashram,
                        Sorry, I misunderstood your question. Please try the below.
                        var myfiles = [];
                        var _layers = ["test1", "test2", "test3"];
                                    try
                                        app.activeDocument.layers.add({name:_layers[j]})
                                    catch(e){}
                                doc.save();
                                doc.close();
                        Hi HarveyLiu,
                        Try this,
                        var myfiles = [];
                                try{
                                    _layer.remove();
                                    links = doc.links, counter = 0;
                                            try {
                                                link = links[i];
                                                frame.remove();
                                                counter++;
                                            catch (err) {
                                catch(e){}
                                doc.save();
                                doc.close();
                        Regards,
                        Chinna
                        • 9. Re: Script for batch delet redundant layer
                          HarveyLiu Level 1
                          Hi, Chinna,
                          Thank you for you help, but the script not work.
                          Regards,
                          Harvey
                          • 10. Re: Script for batch delet redundant layer
                            HarveyLiu Level 1
                            Hi, Chinna,
                            Very sorry,
                            I make a mistake, It works very well, but if the file has not such as "Job Info" layer, it will not remove the missing link object.
                            and:
                            I run the script in indesgn cs3, the it will not tell me that the file has missing object,
                            but:
                            I run it in the cs6, it always tells me that the file has missing object. It is terrible that I have to press enter for the script can keep working
                            Best Regards,
                            Harvey
                            • 11. Re: Re: Script for batch delet redundant layer
                              Chinnadk Level 4
                              Hi Harvey,
                              Replace line numbers 6-9 with below,
                                      try{
                                              _layer.remove();
                                      catch(e{})
                                      try{
                              Regards,
                              Chinna
                              • 12. Re: Re: Script for batch delet redundant layer
                                ASHOK KUMAR Level 1
                                Hi Chinna
                                Now it's working fine. Thanks for your support.
                                ASHRAM
                                • 13. Re: Script for batch delet redundant layer
                                  HarveyLiu Level 1
                                  Hi,Chinna
                                  the Script runs very well, thank you for your helpfull scipt, I save a lot of time by using the script,thank you very much, appreciate!
                                  But if fix a little problem, it will very perfect.
                                  Why it keeps giving me a warrning like this:
                                  Best Regards,
                                  Harvey
                                  • 14. Re: Script for batch delet redundant layer
                                    HarveyLiu Level 1
                                    but if it is impossible to fix it, that still a perfect script, I will use it all the time!
                                    • 15. Re: Script for batch delet redundant layer
                                      Chinnadk Level 4
                                      Add this line at the top of the script.
                                      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
                                      and this at the bottom of the script.
                                      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
                                      • 16. Re: Script for batch delet redundant layer
                                        HarveyLiu Level 1
                                        Hi, Chinna,
                                        the script runs perfectly, thank you for your amazing script. I can use multi computer to run it, it save me a lot of time. thanks
                                        Harvey
                                        • 17. Re: Script for batch delet redundant layer
                                          HarveyLiu Level 1
                                          Hi, Chinna,
                                          I got this script which made by Trevor
                                          var doc = app.properties.activeDocument && app.activeDocument;
                                          if (!doc) {alert("Adiós Amigo") ; exit();}
                                          var sN = doc.swatches.everyItem ().name,
                                              sID = doc.swatches.everyItem ().id,
                                              /** UI */
                                              w = new Window ('palette', "Print by Color"),
                                              g1 = w.add('group'),
                                              g2 = w.add('group'),
                                              st = g1.add('statictext', undefined, "Select Swatch from Drop Down List")
                                              d = g1.add('dropdownlist', undefined, sN),
                                              b1 = g2.add('button', undefined, "PDF"),
                                              b2 = g2.add('button', undefined, "Print");
                                              b1.onClick = function () {proccessPages (d.selection, true)}
                                              b2.onClick = function () {proccessPages (d.selection)}
                                          w.show();
                                          function proccessPages (s, e) {
                                              var l, c = 0, o, p, pO = {}, pA = [];
                                              if (s == null) {alert("No Swatch Selected") ; return;};
                                              app.findTextPreferences = app.changeTextPreferences = null;
                                              s = doc.swatches.itemByID (sID[s.index]);
                                              app.findTextPreferences.fillColor = s;
                                              var pageFinds = doc.findText ();
                                              if (!(l = pageFinds.length)) {alert("No finds") ; return;};
                                              for (c = 0; c < l; c++) {
                                                  o = (p = pageFinds[c].parentTextFrames[0].properties.parentPage) && p.documentOffset + 1;
                                                  if (p) pO["_" + o] = o; // if the finds on a page add to page list
                                              c = 0;
                                              for (o in pO) pA[c++] = pO[o];
                                              var pageRange = "+" + pA.join(", +");
                                              doc.printPreferences.pageRange = pageRange;
                                              if (!e) doc.print(true);
                                              else {
                                                  app.pdfExportPreferences.pageRange = pageRange;
                                                  f = File.saveDialog("Export PDF", "PDF: *.PDF");
                                                  if (!f) return;
                                                  if (!f.toString().match(/\.pdf$/i)) f += ".pdf";
                                                  doc.exportFile (ExportFormat.PDF_TYPE, f, true);
                                          function: find a specify color of text and then gen pdf
                                          but now:
                                          I want to change the function of:
                                          find underline text and then gen pdf is that possible?
                                          thank you
                                          best regard
                                          Harvey
