6 Replies Latest reply on Jun 24, 2014 5:36 PM by ssprengel
    Camera Raw Saving To: Tiff Format
    animationlife Level 1
      Hello Everyone.
      I am working with Photo Shop 2014. Inside the Camera Raw, I have worked with a Raw Image, and after Applying all the setting to my Raw Shot, I have applied the same settings to my other Raw Images.
      Then, Inside the camera Raw, I selected all my Raw Images that the setting has already been applied to them,  and saved them all as a Tiff Format.
      Inside the Bridge If I open the Tiff file In Camera Raw, Every Setting Shows as 0 like nothing has been done to the Images. But off course, If I saved my Raw Image as a .dng Format and If I open the .dng format In camera Raw
      all the setting is there. What I am trying to know is Technically, If you saved your Camera Raw to a Tiff Format when you open that Tiff Format In the Camera Raw you are not able to see your saved settings am I correct ?
      Also, Inside my Tiff Setting, the Image Compression, I have It set to None, and since I use PC I have selected IBM PC, and Pixel order to Interleaved (RGBRGB). If you select LZW Dose that Compresses your Image ?
      What is LZW good for ?
      Thank you very much.
