3 Replies Latest reply on Oct 19, 2018 10:57 AM by codya63421776
    Save Custom Swatch Folders?
    Living Data
      can I somehow save individual custom Swatch folders? It seems to save only the "Default Swatches" folder (which makes the option for other folders somewhat pointless)...
      Is it also possible to adjust the size of the swatch icons/squares?
      Thanks.
        • 1. Re: Save Custom Swatch Folders?
          Nipun Asthana Adobe Employee
          Unfortunately not. You may only customize and save your default Swatch to be available across all documents by default.
          Multiple Swatches/folders option is provided to let you organize (or restrict) the colors for a given project only and gets saved for corresponding project .
          You may wish to try out new workflows using the Kuler Panel (that lets you reuse themes) as explained here: Flash Professional Help | Working with Kuler Panel
          If you'd like to make any suggestions, post them here: Adobe - Feature Request/Bug Report Form
          Nipun
          • 2. Re: Save Custom Swatch Folders?
            pixelproject Level 1
            Why have the folder option if it's exclusive to a specific document?
            I don't understand the logic of removing the feature where you could save different swatches.
            Every project I work on for clients have a different colour theme. In the old Flash, you could create your theme or swatch, save it and import it into any flash file which was extremely useful.
            Having to add and change the default swatches, thereby either having to remove one project's colours or making it a massive swatch panel with more colours than you need seems a step backwards. And when I try create this new "theme library" I have to save 16 themes to a library? I really don't understand why this is.
            All I want to do is save a dozen or so colours out to their own swatch library so that I can import these into my project files for each client.
            Is there really no way to do this?
            • 3. Re: Save Custom Swatch Folders?
              codya63421776
              What i do is make my folder for my custom colors, then i clear colors, then move my customs into the default then save.
              When importing these colors they will go into default, so if the colors already exist in default then they wont come in order, so with a new document: clear your colors, add colors, move added to new folder, then load default colors.
              Sounds like a lot but it isn't, cheers.
