4 Replies Latest reply: Jun 27, 2014 4:05 AM by jadr RSS
    Multiple application pools for ColdFusion possible in the same IIS website?
    jadr Community Member
      I would like to set up a single website with CFM11 under IIS8.5
      In this website there are several CFM applications, each under a different "Application" subfolder. For security purposes, monitoring and separate maintenance shutdowns per application, these would all need their own "application pool".
      However, this means that these applications should run under a different application pool than their website root node. In IIS this causes a 403.18 exception:
      HTTP Error 403.18 - Forbidden
      The specified request cannot be processed in the application pool that is configured for this resource on the Web server.
      Most likely causes:
      •An ISAPI filter or custom module changed the URL to run in a different application pool than the original URL.
      •An ISAPI extension (or custom module) used ExecuteURL (or ExecuteRequest) to run in a different application pool than the original URL.
      •You have a custom error page that is located in one application pool but is referenced by a Web site in another application pool. When the URL is processed, it is determined by IIS that that it should have been processed in the first application pool, not the other pool.
      •The Web site has multiple applications configured. The application this request is configured to run in is set to run in an application pool that does not exist.
      All works fine if the "applications" in the subfolders run under the same application pool as the website root. However that is not my preferred setup... The behaviour is consistent over all CFM-applications that I deploy, no matter how simple they are...
      Two questions:
      - is coldfusion actually looking to "higher" folders than I expect it to? (and can that be avoided)
      - any hints or experiences on how to avoid / solve this issue?
