2 Replies Latest reply on Aug 19, 2007 9:11 PM by Nandrad
    Flex 2 charting license watermark issue
    isterin
      We've purchased the flex 2 builder and flex charting. I've installed the serials and all works fine when the application is build using flex builder. The watermark is removed. When I build the application using command line (which points to same SDK as in flex builder), the watermark remains? Does anyone know how to resolve this issue or if this is a bug?
      Thanks.
        • 1. Re: Flex 2 charting license watermark issue
          isterin Level 1
          I understand I can use -licenses.license option to flex compiler, but I'm using a maven plugin and it doesn't support this. There should be a environmental of flex-config.xml setting to set the licenses file without having to do so on each compile. I'd modify the maven plugin code, but can't get access to the plugin source.
          • 2. Re: Flex 2 charting license watermark issue
            Nandrad
            I had the same problem and I am also using Maven instead of Ant to build.
            I managed to workout that you can add the mxmlc command line argument, "-licenses.license charting XXXXXXXXXXX", to the "flex-config.xml" using the following (Note: add it outside of the <compiler> tag):
            <licenses>
            <license>
            <product>charting</product>
            <serial-number>XXXXXXXXXX</serial-number>
            </license>
            </licenses>
            By doing this I could continue to build my Flex code through maven.
