9 Replies Latest reply on Jun 24, 2014 7:35 AM by bingandham
    Multi paged document into individual PDF pages - with names
    bingandham Level 1
      I have an InDesign document that I use to create sell sheets for groups of sales people using data merge.
      I'm wondering if there's an easy way to extract these pages as individual pdf pages that have the names of each page (D_Smith.pdf, RJones.pdf etc.)
      Currently I do this using Acrobat and extract pages and manually tag each pdf.
        • 2. Re: Multi paged document into individual PDF pages - with names
          I don't do much with data merge, but you should have a master page item with the name field—so it could be scripted. The master page name field could be given a script label and then the content from the name field on each page could be picked up and used as the PDF title.
          • 3. Re: Multi paged document into individual PDF pages - with names
            If you are using OSX I have an AppleScript that might work
            • 5. Re: Multi paged document into individual PDF pages - with names
              See if this works. I'm assuming you have a text frame on the master page for the data merge name, which you want to use as the page's PDF title. If you select the frame on the master, and open the Script Label panel (Window>Utilities), you can give the frame a label. Keep in mind the script label will not be applied to existing pages where the frame has been overridden:
              Here's the script that exports PDF pages using the contents of the labeled text field as the title.If there are no text fields on a page with the MyName label the page number is used as the title instead:
              --the text field's label. This must match the text frame's label exactly.
              set targetlabel to "MyName"
              tell application "Adobe InDesign CS6"
                  activate
                  --prevent PDF's from opening as they are created
                  set view PDF of PDF export preferences to false
                  -------------------------------Export preset dialog----------------------------------
                  --check for an active document
                  if (count documents) is equal to 0 then
                      display dialog "Please open a document" buttons " OK " default button 1 with icon caution
                      return -128
                  end if
                  --the doc name for naming PDFs
                  set myFileName to name of active document
                  --PDF preset choice dialog.
                  set myLabelWidth to 250
                  set myDialog to make dialog with properties {name:"Export Preset"}
                  tell myDialog
                      tell (make dialog column)
                          tell (make border panel)
                                  tell (make dialog row)
                                      set PresertList to name of every PDF export preset of application "Adobe InDesign CS6"
                                      make static text with properties {static label:"PDF Preset:"}
                                      set myPDFPresetDropdown to make dropdown with properties {string list:PresertList, selected index:4, min width:myLabelWidth}
                                  end tell
                              end tell
                          end tell
                      end tell
                  end tell
                  --get the results
                  set myResult to show myDialog
                  if myResult = true then
                      set myPDFPreset to item ((selected index of myPDFPresetDropdown) + 1) of PresertList as item
                  else
                      return
                  end if
                  destroy myDialog
                  -------------------------------export PDFs----------------------------------
                  --choose the folder for exported PDFs
                  set myFolder to (choose folder with prompt "Please select an Export Destination") as string
                  tell active document
                      set NumberOfPage to pages per document of document preferences
                      with timeout of 5000 seconds
                          repeat with x from 1 to NumberOfPage
                              --set the contents of the labeled doc as the PDF's name
                              --if there is no labeled text field use the page number
                              try
                                  set pdftitle to (contents of every text frame of page x whose label = targetlabel)
                              on error
                                  set pdftitle to x as string
                              end try
                              set thePath to (myFolder & pdftitle & ".pdf")
                              --Set the page range, the tell has to be to ID
                                  set page range of PDF export preferences to (x as string)
                                  export document 1 format PDF type to thePath using PDF export preset myPDFPreset
                              end tell
                          end repeat
                      end timeout
                  end tell
                  display dialog "Pages have been exported."
              end tell
              • 7. Re: Multi paged document into individual PDF pages - with names
                bingandham Level 1
                I've never used a script. Do I just cut an paste this into a txt file and place in the scripts folder?
                • 8. Re: Multi paged document into individual PDF pages - with names
                  No, you have to paste the text into ScriptEditor and compile it.
                  Here's a zip archive with a complied version (ExportPDFByLabel.scpt). Just copy the script into your scripts folder (Applications/Adobe InDesign CC/Scripts/Scripts Panel). You run a script by double-clicking it from the scripts panel.
                  I've included the ID file I used to test, if you select the text field on the master page you'll see the label in the Scripts Label panel. When you run the script it asks for a destination folder for the PDFs
                  http://www.zenodesign.com/forum/ExportPDFLabel.zip
                  • 9. Re: Multi paged document into individual PDF pages - with names
                    bingandham Level 1
                    That worked perfect! Thanks so much!
