1 Reply Latest reply on Jul 27, 2014 1:27 AM by areohbee
    HMAC in Lua - Lightroom plugin devlopment
    hewarocks
      Here is my requirement
      • I need to use HMAC-sha256 for Lightroom plugin development as I'm using that for security.
      I was trying to use this but with no luck https://code.google.com/p/lua-files/wiki/hmacThese are the steps I followed
      1. Got the code of https://code.google.com/p/lua-files/source/browse/hmac.lua and saved as 'hmac.lua' file in my plugin directory
      2. Got the code from this https://code.google.com/p/lua-files/source/browse/sha2.lua and saved as 'sha2.lua' file
      Now in the file I use it like this
      local hmac = require'hmac'
      local sha2 = require'sha2'
      --somewhere down the line inside a function
      local hashvalue = hmac.sha2('key', 'message')
      but unfortunately this does not work and I'm not sure what I'm doing wrong. Can anyone advice me what I'm doing wrong here? Or is there an easier and better way of doing this with a good example.
      Also I'm doing this to get the returned string
      local hashvalue = hmac.sha2( message, key )
      myLogger:enable("logfile")
      myLogger:trace ("=========================================\n")
      myLogger:trace ('Winter is coming, ' .. hashvalue)
      When I load lightroom it refuses to load the plugin and there is nothing on the log.
      Thank you very much for your help
