This content has been marked as final.
Show 4 replies
1. Re: transform text to image?
Rave Jun 25, 2014 7:29 AM (in response to straightlife)Hi straightlife,
You can convert the searchable text to image by simply flattening the layers using Adobe pdf printer.
Go to File > Print > Adobe PDF Printer
Regards,
Rave
2. Re: transform text to image?
Test Screen Name Jun 25, 2014 7:54 AM (in response to Rave)I can't really see that solving the problem. The poster wants certain kinds of text (captions) to be converted, while other text is not.
3. Re: transform text to image?
straightlife Jun 25, 2014 9:09 AM (in response to Test Screen Name)Thanks, yes. the caption text is outlined, now, so it's "image" but I still need a way to combine "images" : caption outlines + image, to make one single image.
4. Re: transform text to image?
MichaelKazlow Jun 26, 2014 10:13 AM (in response to straightlife)That should be done before you entered everything into InDesign. You can crop the image and caption and re-import the new image into InDesign and create another pdf by export.
