7 Replies Latest reply on Jun 27, 2014 7:25 AM by c.pfaffenbichler
    how resize layer with a big image on size of layer mask ?
    Andy_Bat1 Level 1
      Hi all
      How to resize the image on the layer mask?
      * document - doc.width, doc.height
      * mask - activeLayer.bounds
      * and how to take the coordinates in the image with the mask if the image is larger than the size of the document?
        • 1. Re: how resize layer with a big image on size of layer mask ?
          c.pfaffenbichler Level 9
          When you disable the Layer Mask you should get the bounds of the Layer’s pixel content.
          • 3. Re: how resize layer with a big image on size of layer mask ?
            // 2014, use it at your own risk;
            #target "photoshop-70.032"
            if (app.documents.length > 0) {
            var ref = new ActionReference();
            ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
            var layerDesc = executeActionGet(ref);
            var layerMaskEnabled = layerDesc.getBoolean(stringIDToTypeID("userMaskEnabled"));
            if (layerMaskEnabled == true) {
            var idsetd = charIDToTypeID( "setd" );
                var desc4 = new ActionDescriptor();
                var idnull = charIDToTypeID( "null" );
                    var ref1 = new ActionReference();
                    var idLyr = charIDToTypeID( "Lyr " );
                    var idOrdn = charIDToTypeID( "Ordn" );
                    var idTrgt = charIDToTypeID( "Trgt" );
                    ref1.putEnumerated( idLyr, idOrdn, idTrgt );
                desc4.putReference( idnull, ref1 );
                var idT = charIDToTypeID( "T   " );
                    var desc5 = new ActionDescriptor();
                    var idUsrM = charIDToTypeID( "UsrM" );
                    desc5.putBoolean( idUsrM, false );
                desc4.putObject( idT, idLyr, desc5 );
            executeAction( idsetd, desc4, DialogModes.NO );
            alert (app.activeDocument.activeLayer.bounds)
            • 4. Re: how resize layer with a big image on size of layer mask ?
              Andy_Bat1 Level 1
              how resize mask or delete it ?
              • 5. Re: how resize layer with a big image on size of layer mask ?
                For deleting the Layer Mask I recommend recording Action Manager code with ScriptingListener.plugin
                Resizing it should be possible in DOM by selecting it (as the sole content of an Array for activeDocument.activeChannels).
                • 6. Re: Re: how resize layer with a big image on size of layer mask ?
                  Andy_Bat1 Level 1
                  //For deleting the Layer Mask I recommend recording Action Manager code with ScriptingListener.plugin
                  I'm write script on delete LM in ScriptListener, but it not worked !
                    var desc162 = new ActionDescriptor();
                    var ref125 = new ActionReference();
                    ref125.putEnumerated( idLyr, idOrdn, idTrgt );
                    desc162.putReference( idnull, ref125 );
                    var desc163 = new ActionDescriptor();
                    var idUsrs = charIDToTypeID( "Usrs" );
                    desc163.putBoolean( idUsrs, false );
                    desc162.putObject( idT, idLyr, desc163 );
                  executeAction( idsetd, desc162, DialogModes.NO );
                  Please, help me to defined 4 variables (left, top, right and bottom)!
                  row 33, 36 - indent Hor and Vert
                  row 41, 44 ??? This is %%  !!!
                  var idslct = charIDToTypeID( "slct" );
                    var desc164 = new ActionDescriptor();
                    var ref126 = new ActionReference();
                    var idChnl = charIDToTypeID( "Chnl" );
                    ref126.putEnumerated( idChnl, idOrdn, idTrgt );
                    desc164.putReference( idnull, ref126 );
                    var idMkVs = charIDToTypeID( "MkVs" );
                    desc164.putBoolean( idMkVs, false );
                  executeAction( idslct, desc164, DialogModes.NO );
                  var idTrnf = charIDToTypeID( "Trnf" );
                    var desc165 = new ActionDescriptor();
                    var ref127 = new ActionReference();
                    ref127.putEnumerated( idLyr, idOrdn, idTrgt );
                    desc165.putReference( idnull, ref127 );
                    var idFTcs = charIDToTypeID( "FTcs" );
                    var idQCSt = charIDToTypeID( "QCSt" );
                    var idQcsa = charIDToTypeID( "Qcsa" );
                    desc165.putEnumerated( idFTcs, idQCSt, idQcsa );
                    var idOfst = charIDToTypeID( "Ofst" );
                    var desc166 = new ActionDescriptor();
                    var idHrzn = charIDToTypeID( "Hrzn" );
                    var idPxl = charIDToTypeID( "#Pxl" );
                    desc166.putUnitDouble( idHrzn, idPxl, 13.500000 );
                    var idVrtc = charIDToTypeID( "Vrtc" );
                    desc166.putUnitDouble( idVrtc, idPxl, -6.500000 );
                    desc165.putObject( idOfst, idOfst, desc166 );
                    var idWdth = charIDToTypeID( "Wdth" );
                    var idPrc = charIDToTypeID( "#Prc" );
                    desc165.putUnitDouble( idWdth, idPrc, 125.064267 );
                     var idHght = charIDToTypeID( "Hght" );             What is this ?&&&&
                    desc165.putUnitDouble( idHght, idPrc, 135.227273 );
                    var idIntr = charIDToTypeID( "Intr" );
                    var idIntp = charIDToTypeID( "Intp" );
                    var idBcbc = charIDToTypeID( "Bcbc" );
                    desc165.putEnumerated( idIntr, idIntp, idBcbc );
                  executeAction( idTrnf, desc165, DialogModes.NO );
                  • 7. Re: how resize layer with a big image on size of layer mask ?
                    As for deleting a Layer Mask this would work on the active layer:
                    ////// delete or apply layer mask //////
                    function deleteLayerMask (apply) {
                    if (apply == undefined) {var apply = false};
                    try {
                    var idDlt = charIDToTypeID( "Dlt " );
                        var desc9 = new ActionDescriptor();
                            var ref5 = new ActionReference();
                            var idMsk = charIDToTypeID( "Msk " );
                            ref5.putEnumerated( idChnl, idChnl, idMsk );
                        desc9.putReference( idnull, ref5 );
                        var idAply = charIDToTypeID( "Aply" );
                        desc9.putBoolean( idAply, apply );
                    executeAction( idDlt, desc9, DialogModes.NO );
                    catch (e) {}
                    As for the second part I am not sure what you want to achieve exactly.
