6 Replies Latest reply on Jun 27, 2014 7:28 AM by big_smile
    Batch replace a colour with another colour
    big_smile Level 1
      I have over 100 documents. In these documents, some of the objects use a regular black colour (e.g. C0, M0, Y0, K100). I need to replace it as a rich black (e.g. C75, M68, Y67, K90). The regular black colour is NOT saved as a swatch, so I can't just update the swatch. The objects are made of paths and shapes, some of which are in groups.
      I found a script here and have updated it to suit my needs (The original script requires you to select an object, my update automatically selects all objects in the file). It works fine on a simple document that has a few layers. However, on more complex documents that have multiple nested layers, I get the following error:
      Error 1302: No such element
      Line: 9
      ->       myItem=docRef.pathItems[i];
      Here is my code:
      var docRef = app.activeDocument;
      docRef.hasSelectedArtwork = true;
      var iL=docRef.pageItems.length;
      for (i=0;i<iL;i++){
                if (myItem.fillColor=="[CMYKColor]" && myItem.selected){ //implement only for CMYK and selected
           var c1=0;
           var m1=0;
           var y1=0;
           var k1=100;
           var c2=Math.round(myItem.fillColor.cyan); // round the number ( 0,0012 => 0 )
           var m2=Math.round(myItem.fillColor.magenta); // round the number ( 6,8898 => 7 )
           var y2=Math.round(myItem.fillColor.yellow);
           var k2=Math.round(myItem.fillColor.black);
           if (c1==c2&&m1==m2&&y1==y2&&k1==k2){ // compare
           myItem.fillColor.cyan=75;
           myItem.fillColor.magenta=68;
           myItem.fillColor.yellow=67;
           myItem.fillColor.black=90;
            redraw();
                          } // if compare
                } // if CMYK
           } // end for
      How can I overcome the error.
        • 1. Re: Batch replace a colour with another colour
          Larry G. Schneider Adobe Community Professional & MVP
          Have you tried working backwards?
          (i=iL;i>=0;i--)
          • 2. Re: Batch replace a colour with another colour
            pixxxel schubser MVP & Adobe Community Professional
            Sorry, you haven't enough time for giving a feedback (e.g. Duplicate a layer with a new Name)
            And you question here is not easy to answer, I haven't enough time for you - only for a quick start guide.
            You should loop through all documents.
            You should loop through all items (fill color and stroke color) and change the color if this color is your old black. (Why you won't change the color to RGB-black?)
            The difficult is:
            - items in nested nested grouped … groups
            - colors in strokes and fills were added in the appearance palette cannot be found with scripting
            • 3. Re: Batch replace a colour with another colour
              big_smile Level 1
              @Larry G.Schneider Thanks! Unfortunately, this produces the same error message.
              • 4. Re: Batch replace a colour with another colour
                big_smile Level 1
                pixxxel schubser Please accept my apologies for my rudeness. If you look at my past questions, you'll see that I normally do give feedback and also mark answers as helpful. In fact the only ones that are unmakred are the ones which were unanswered.
                What happened with the Duplicate Layer name project was that my computer went for repairs. When it came back, I had moved on to other things and had completely forgot about it! I know that's not really an excuse, but I didn't mean to skip the feedback on purpose. I do actually contribute on other sites and get frustrated by "help vampires" who ask for help but never give any back, so I am ashamed that I have become one. However, I will make an extra effort to return to my past good habits!
                The difficult is:
                I think that's the problem I've got. In the documents where the script does work, the items are nested in groups.
                • 5. Re: Re: Batch replace a colour with another colour
                  Hi @big_smile,
                  It's ok.
                  But you are right, I was a little bit frustrated. Because of: no feedback is the "worst" feedback.
                  And like I said before, your question isn't easy to answer. To check the difficult you can start with this little snippet:
                  var aDoc = app.activeDocument;
                  //var pI = aDoc.pageItems;
                  //var pILen=pI.length;
                  // please select some items before running this script snippet
                  var pI = aDoc.selection;
                  var item;
                  for (i=0;i<=pILen-1;i++) {
                      item = pI[i];
                      $.writeln("item "+i+":  "+item.typename);
                      $.writeln("clipped =  "+item.clipped);
                      if (item.typename == "PathItem") {
                          // if GroupItem --> loop through the groupItems.pathItems
                          // if CompoundPathItem --> loop through the CompoundPathItems.pathItems
                          $.writeln(item.fillColor)
                          $.writeln(item.strokeColor)
                          $.writeln(item.filled)
                          $.writeln(item.fillColor.color)
                          if (item.filled == true && item.fillColor.typename == "CMYKColor" ) {
                              alert("item "+i+"  fillColor:  "+item.fillColor.typename);
                          if (item.stroked == true && item.strokeColor.typename == "CMYKColor" ) {
                              alert("item "+i+"  strokeColor:  "+item.strokeColor.typename);
                  Please select some items before running this script snippet (otherwise it may takes a long time).
                  And please, check your JavaScript console in ESTK after running this script.
                  I know, this can't be a correct answer, but perhaps this is a little bit helpful for the beginning.
                  • 6. Re: Batch replace a colour with another colour
                    big_smile Level 1
                    @pixxxel schubser. I think this is actually going to more complicated then I hoped. For my current project, it looks like it will probably be quicker to do it manually. However, I am sure I will probably investigate it in the future. Thanks for your help!
