1 Reply Latest reply on Jun 26, 2014 11:08 AM by Magus069
    Using buttons to add and/or remove fields
    Adam_The_Man
      Hello all!
      I really need some help here. I'm making a form in LiveCycle ES Design 8.2. I can't seem to get my buttons to work like I want them to. I need to be able to hit the plus sign and have the form add another field for more issues and concerns. The minus sign already works to remove a field. I just can't seem to get it to add the next field/bullet point. As well. I can't seem to get the field to grow as the text increases. In that regard, I was hoping for some sort of wrap text feature. Currently, the text just keeps on going.... or if I hit enter towards the end of the field, it creates a scroll bar on the right rather than just expanding the field to accommodate for the text. Any and all help would be greatly appreciated!
      Adam
        • 1. Re: Using buttons to add and/or remove fields
          Magus069 Level 4
          Please can you show me your code for the + button, how do you add an instance? And also can you provide a picture of your hierarchy.
          To get a field expandable you must set 3 different properties to make it work fine:
          1. Object Palette -> 'Check' Allow Multiple Lines
          2. Object Palette -> Field Format -> 'Choose' Rich Text
          3. Layout Palette -> Size & Position - > Height -> 'Check' Expand to fit
