2 Replies Latest reply on May 10, 2007 9:36 AM by Newsgroup_User
    SQL: Order By ASC mixed with DESC
    francois-yanick
      Hi everyone,
      I guest this is a very advanced question concerning ORDER BY with an SQL query as I intend to have 2 type of order from the same table.
      Here it is: I have a table with 2 fiels:
      field 1 = BudgetShort Description which is a varchar and it is unique
      field 2 = BudgetAmountAvailable wich is a float
      the field BudgetShortDescription is contain a structure like this:
      [year].[program area].[area].[project].[activity].[action].[task]
      e.g.: 2007.6.1.2.4.5.2
      it is long story to explain how this table is generated but, in this issue, I need to use it where I would like to order by year DESC (so 2007 will come first and than 2006, 2005, etc...). But, I also want to order by the budget's structure (after the year) in an ascendant way so IU can have 2007.6.1.2.4.5.2, 2007.6.1.2.4.5.3, 2007.6.1.2.4.5.4, etc...
      I thought about creating a first query (the one that take the information from the table in the database) where I created a new variable in my query:
      SELECT distinct dbo.ContractBudgetDistribution.budgetId, dbo.BudgetList.BudgetShortDescription AS BudgetShortDescription, LEFT(dbo.BudgetList.BudgetShortDescription, 4) AS BudgetYear
      FROM dbo.ContractBudgetDistribution INNER JOIN dbo.BudgetList ON dbo.ContractBudgetDistribution.BudgetId = dbo.BudgetList.BudgetID
      ORDER BY BudgetYear DESC
      This work okay. But, after this, my idea was to go with a query of a query, just like this:
      SELECT *
      FROM qGetBudgetList
      ORDER BY BUDGETSHORTDESCRIPTION
      But it is not doing what I want. Of course because the system does not understand how to split such a same field. The solution to add a new field in the table for the year still an option but the problem will still the same as well as I still (a lot of still here) need to order in two ways what I got.
      Any help will be appreciated here!
      Thank's
        • 1. Re: SQL: Order By ASC mixed with DESC
          sanaullah
          Hi
          try like this
          ORDER BY BudgetYear DESC, BUDGETSHORTDESCRIPTION asc
          • 2. Re: SQL: Order By ASC mixed with DESC
            Level 7
            Try this instead:
            SELECT DISTINCT cbd.budgetId, bl.BudgetShortDescription
            FROM dbo.ContractBudgetDistribution cbd
            INNER JOIN dbo.BudgetList bl ON cbd.BudgetId = bl.BudgetID
            ORDER BY LEFT(bl.BudgetShortDescription, 4) DESC, bl.BudgetShortDescription
            HTH,
            Carl
            francois-yanick wrote:
            > Hi everyone,
            > just like this:
            > SELECT *
            > FROM qGetBudgetList
            > Thank's
