3 Replies Latest reply on Jun 24, 2014 1:25 PM by Noel Carboni
    For Ps CC 2014 display box is only 384x640
    McDermottLtd Level 1
      I installed Ps CC 2014 but the display bounds are only 384 x 640.  I can only see a portion of the program screen.  How can I correct that?  I have the latest Nvidia GeForce 440 driver.  Ps CC ver 14 is installed and displays/works fine.  Thank you for your help. (system info below)
      screen shots:
      This is my entire screen-
      same computer/screen with ver 14-
      Here is my system info:
      Adobe Photoshop Version: 2014.0.0 20140508.r.58 2014/05/08:23:59:59  x64
      Operating System: Windows 7 64-bit
      Version: 6.1 Service Pack 1
      System architecture: Intel CPU Family:6, Model:12, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
      Physical processor count: 6
      Logical processor count: 12
      Processor speed: 3325 MHz
      Built-in memory: 12279 MB
      Free memory: 8085 MB
      Memory available to Photoshop: 10899 MB
      Memory used by Photoshop: 70 %
      3D Multitone Printing: Enabled.
      Touch Gestures: Disabled.
      Windows 2x UI: Enabled.
      Image tile size: 1024K
      Image cache levels: 4
      Font Preview: Medium
      TextComposer: Latin
      Display: 1
      Display Bounds: top=0, left=0, bottom=384, right=640
      OpenGL Drawing: Enabled.
      OpenGL Allow Old GPUs: Not Detected.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      AIFCoreInitialized=1
      AIFOGLInitialized=1
      OGLContextCreated=1
      glgpu[0].GLVersion="3.0"
      glgpu[0].GLMemoryMB=1536
      glgpu[0].GLName="GeForce GT 440/PCIe/SSE2"
      glgpu[0].GLVendor="NVIDIA Corporation"
      glgpu[0].GLVendorID=4318
      glgpu[0].GLDriverVersion="9.18.13.3788"
      glgpu[0].GLRectTextureSize=16384
      glgpu[0].GLRenderer="GeForce GT 440/PCIe/SSE2"
      glgpu[0].GLRendererID=3520
      glgpu[0].HasGLNPOTSupport=1
      glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
      glgpu[0].GLDriverDate="20140519000000.000000-000"
      glgpu[0].CanCompileProgramGLSL=1
      glgpu[0].GLFrameBufferOK=1
      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.40 NVIDIA via Cg compiler"
      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
      glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
      clgpu[0].CLPlatformVersion="1.1"
      clgpu[0].CLDeviceVersion="1.1 CUDA"
      clgpu[0].CLMemoryMB=1536
      clgpu[0].CLName="GeForce GT 440"
      clgpu[0].CLVendor="NVIDIA Corporation"
      clgpu[0].CLVendorID=4318
      clgpu[0].CLDriverVersion="337.88"
      clgpu[0].CUDASupported=1
      clgpu[0].CUDAVersion="6.0.1"
      clgpu[0].CLBandwidth=3.30384e+010
      clgpu[0].CLCompute=93.7119
      License Type: Subscription
      Serial number: 90970673560193308612
      Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2014\
      Temporary file path: C:\Users\Michael\AppData\Local\Temp\
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        C:\, 918.1G, 742.0G free
      Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2014\Required\Plug-Ins\
      Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2014\Plug-ins\
      Installed components:
         A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
         ACE.dll   ACE 2014/04/14-23:42:44   79.554120   79.554120
         adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
         AdbePM.dll   PatchMatch 2014/04/23-10:46:55   79.554276   79.554276
         AdobeLinguistic.dll   Adobe Linguisitc Library   8.0.0
         AdobeOwl.dll   Adobe Owl 2014/03/05-14:49:37   5.0.33   79.552883
         AdobePDFL.dll   PDFL 2014/03/04-00:39:42   79.510482   79.510482
         AdobePIP.dll   Adobe Product Improvement Program   7.2.1.3399
         AdobeXMP.dll   Adobe XMP Core 2014/01/13-19:44:00   79.155772   79.155772
         AdobeXMPFiles.dll   Adobe XMP Files 2014/01/13-19:44:00   79.155772   79.155772
         AdobeXMPScript.dll   Adobe XMP Script 2014/01/13-19:44:00   79.155772   79.155772
         adobe_caps.dll   Adobe CAPS   8,0,0,7
         AGM.dll   AGM 2014/04/14-23:42:44   79.554120   79.554120
         ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
         amtlib.dll   AMTLib (64 Bit)   8.0.0.45 BuildVersion: 8.0; BuildDate: Fri Mar 28 2014 20:28:30)   1.000000
         ARE.dll   ARE 2014/04/14-23:42:44   79.554120   79.554120
         AXE8SharedExpat.dll   AXE8SharedExpat 2013/12/20-21:40:29   79.551013   79.551013
         AXEDOMCore.dll   AXEDOMCore 2013/12/20-21:40:29   79.551013   79.551013
         Bib.dll   BIB 2014/04/14-23:42:44   79.554120   79.554120
         BIBUtils.dll   BIBUtils 2014/04/14-23:42:44   79.554120   79.554120
         boost_date_time.dll   photoshopdva   8.0.0
         boost_signals.dll   photoshopdva   8.0.0
         boost_system.dll   photoshopdva   8.0.0
         boost_threads.dll   photoshopdva   8.0.0
         cg.dll   NVIDIA Cg Runtime   3.0.00007
         cgGL.dll   NVIDIA Cg Runtime   3.0.00007
         CIT.dll   Adobe CIT   2.2.6.32411   2.2.6.32411
         CITThreading.dll   Adobe CITThreading   2.2.6.32411   2.2.6.32411
         CoolType.dll   CoolType 2014/04/14-23:42:44   79.554120   79.554120
         dvaaudiodevice.dll   photoshopdva   8.0.0
         dvacore.dll   photoshopdva   8.0.0
         dvamarshal.dll   photoshopdva   8.0.0
         dvamediatypes.dll   photoshopdva   8.0.0
         dvametadata.dll   photoshopdva   8.0.0
         dvametadataapi.dll   photoshopdva   8.0.0
         dvametadataui.dll   photoshopdva   8.0.0
         dvaplayer.dll   photoshopdva   8.0.0
         dvatransport.dll   photoshopdva   8.0.0
         dvaui.dll   photoshopdva   8.0.0
         dvaunittesting.dll   photoshopdva   8.0.0
         dynamiclink.dll   photoshopdva   8.0.0
         ExtendScript.dll   ExtendScript 2014/01/21-23:58:55   79.551519   79.551519
         icucnv40.dll   International Components for Unicode 2013/02/25-15:59:15    Build gtlib_4.0.19090
         icudt40.dll   International Components for Unicode 2013/02/25-15:59:15    Build gtlib_4.0.19090
         imslib.dll   IMSLib DLL   7.0.0.145
         JP2KLib.dll   JP2KLib 2014/03/12-08:53:44   79.252744   79.252744
         libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
         libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
         libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
         LogSession.dll   LogSession   7.2.1.3399
         mediacoreif.dll   photoshopdva   8.0.0
         MPS.dll   MPS 2014/03/25-23:41:34   79.553444   79.553444
         pdfsettings.dll   Adobe PDFSettings   1.04
         Photoshop.dll   Adobe Photoshop CC 2014   15.0
         Plugin.dll   Adobe Photoshop CC 2014   15.0
         PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   5.0.0
         PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   5.0.0.74
         PSArt.dll   Adobe Photoshop CC 2014   15.0
         PSViews.dll   Adobe Photoshop CC 2014   15.0
         SCCore.dll   ScCore 2014/01/21-23:58:55   79.551519   79.551519
         ScriptUIFlex.dll   ScriptUIFlex 2014/01/20-22:42:05   79.550992   79.550992
         svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
         tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 2, 2013, 1114
         tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 2, 2013, 1114
         TfFontMgr.dll   FontMgr   9.3.0.113
         TfKernel.dll   Kernel   9.3.0.113
         TFKGEOM.dll   Kernel Geom   9.3.0.113
         TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
         updaternotifications.dll   Adobe Updater Notifications Library   7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   7.0.1.102
         VulcanControl.dll   Vulcan Application Control Library   5.0.0.82
         VulcanMessage5.dll   Vulcan Message Library   5.0.0.82
         WRServices.dll   WRServices Fri Mar 07 2014 15:33:10   Build 0.20204   0.20204
         wu3d.dll   U3D Writer   9.3.0.113
      Required plug-ins:
         3D Studio 15.0 (2014.0.0 x001)
         Accented Edges 15.0
         Adaptive Wide Angle 15.0
         Angled Strokes 15.0
         Average 15.0 (2014.0.0 x001)
         Bas Relief 15.0
         BMP 15.0
         Camera Raw 8.0
         Camera Raw Filter 8.0
         Chalk & Charcoal 15.0
         Charcoal 15.0
         Chrome 15.0
         Cineon 15.0 (2014.0.0 x001)
         Clouds 15.0 (2014.0.0 x001)
         Collada 15.0 (2014.0.0 x001)
         Color Halftone 15.0
         Colored Pencil 15.0
         CompuServe GIF 15.0
         Conté Crayon 15.0
         Craquelure 15.0
         Crop and Straighten Photos 15.0 (2014.0.0 x001)
         Crop and Straighten Photos Filter 15.0
         Crosshatch 15.0
         Crystallize 15.0
         Cutout 15.0
         Dark Strokes 15.0
         De-Interlace 15.0
         Dicom 15.0
         Difference Clouds 15.0 (2014.0.0 x001)
         Diffuse Glow 15.0
         Displace 15.0
         Dry Brush 15.0
         Eazel Acquire 15.0 (2014.0.0 x001)
         Embed Watermark 4.0
         Entropy 15.0 (2014.0.0 x001)
         Export Color Lookup NO VERSION
         Extrude 15.0
         FastCore Routines 15.0 (2014.0.0 x001)
         Fibers 15.0
         Film Grain 15.0
         Filter Gallery 15.0
         Flash 3D 15.0 (2014.0.0 x001)
         Fresco 15.0
         Glass 15.0
         Glowing Edges 15.0
         Google Earth 4 15.0 (2014.0.0 x001)
         Grain 15.0
         Graphic Pen 15.0
         Halftone Pattern 15.0
         HDRMergeUI 15.0
         IFF Format 15.0
         Ink Outlines 15.0
         JPEG 2000 15.0
         Kurtosis 15.0 (2014.0.0 x001)
         Lens Blur 15.0
         Lens Correction 15.0
         Lens Flare 15.0
         Liquify 15.0
         Matlab Operation 15.0 (2014.0.0 x001)
         Maximum 15.0 (2014.0.0 x001)
         Mean 15.0 (2014.0.0 x001)
         Measurement Core 15.0 (2014.0.0 x001)
         Median 15.0 (2014.0.0 x001)
         Mezzotint 15.0
         Minimum 15.0 (2014.0.0 x001)
         MMXCore Routines 15.0 (2014.0.0 x001)
         Mosaic Tiles 15.0
         Multiprocessor Support 15.0 (2014.0.0 x001)
         Neon Glow 15.0
         Note Paper 15.0
         NTSC Colors 15.0 (2014.0.0 x001)
         Ocean Ripple 15.0
         OpenEXR 15.0
         Paint Daubs 15.0
         Palette Knife 15.0
         Patchwork 15.0
         Paths to Illustrator 15.0
         PCX 15.0 (2014.0.0 x001)
         Photocopy 15.0
         Photoshop 3D Engine 15.0 (2014.0.0 x001)
         Photoshop Touch 14.0
         Picture Package Filter 15.0 (2014.0.0 x001)
         Pinch 15.0
         Pixar 15.0 (2014.0.0 x001)
         Plaster 15.0
         Plastic Wrap 15.0
         PNG 15.0
         Pointillize 15.0
         Polar Coordinates 15.0
         Portable Bit Map 15.0 (2014.0.0 x001)
         Poster Edges 15.0
         Radial Blur 15.0
         Radiance 15.0 (2014.0.0 x001)
         Range 15.0 (2014.0.0 x001)
         Read Watermark 4.0
         Render Color Lookup Grid NO VERSION
         Reticulation 15.0
         Ripple 15.0
         Rough Pastels 15.0
         Save for Web 15.0
         ScriptingSupport 15.0
         Shake Reduction 15.0
         Shear 15.0
         Skewness 15.0 (2014.0.0 x001)
         Smart Blur 15.0
         Smudge Stick 15.0
         Solarize 15.0 (2014.0.0 x001)
         Spatter 15.0
         Spherize 15.0
         Sponge 15.0
         Sprayed Strokes 15.0
         Stained Glass 15.0
         Stamp 15.0
         Standard Deviation 15.0 (2014.0.0 x001)
         STL 15.0 (2014.0.0 x001)
         Sumi-e 15.0
         Summation 15.0 (2014.0.0 x001)
         Targa 15.0
         Texturizer 15.0
         Tiles 15.0
         Torn Edges 15.0
         Twirl 15.0
         Underpainting 15.0
         Vanishing Point 15.0
         Variance 15.0 (2014.0.0 x001)
         Water Paper 15.0
         Watercolor 15.0
         Wave 15.0
         Wavefront|OBJ 15.0 (2014.0.0 x001)
         WIA Support 15.0 (2014.0.0 x001)
         Wind 15.0
         Wireless Bitmap 15.0 (2014.0.0 x001)
         ZigZag 15.0
      Optional and third party plug-ins: NONE
      Plug-ins that failed to load: NONE
      Flash:
      Installed TWAIN devices: NONE
        • 1. Re: For Ps CC 2014 display box is only 384x640
          Noel Carboni Level 8
          First I've ever heard of that happening, wow.
          Your display driver seems up to date, so no problem there.
          Do you have anything special configured in your nVidia driver panel that might partition your desktop, or some 3rd party software installed that controls some aspect of your desktop (e.g., StarDock Fences)?
          Some really basic things to try (sorry they're blunt)...
          • Reboot
          • Reset Photoshop preferences
            Press and hold Control - Shift - Alt simultaneously immediately upon cold-starting Photoshop. If you get the keys down quickly enough - and you have to be really quick - it will prompt you to confirm deletion of your current preferences, which will lead to the establishment of a fresh default set. If it does not prompt you, you haven't been quick enough to get the keys down.
          • Check for an even more recent (or slightly older) display driver update from nVidia.com.
          Please follow up here when you do find out what's wrong.  I'd love to know what could cause a system to report such a small desktop size metric.
          -Noel
          • 2. Re: For Ps CC 2014 display box is only 384x640
            The reset Photoshop preferences did the trick.  Thank you!!
            • 3. Re: For Ps CC 2014 display box is only 384x640
              You're welcome.  Thanks for posting back that you were successful.
              Enjoy Photoshop!
              -Noel
