13 Replies Latest reply: Dec 4, 2014 2:35 PM by Kevin-Monahan RSS
    blending modes bug
    Android772
      I want to report a bug in the program Premiere Pro CC 2014. it first appeared in version CC.
      blending modes bug
      Compound
      Arithmetic
      Composite
      each time one and the same
      Describe a situation in which there is this bug
      I apply a preset, any of these effects, or similar so that the clip is mixed with himself blending mode screen. so I very gently increases the brightness of the image.
      and sometimes there is a problem. clip is not blended with himself simultaneously. but with some time offset. it turns out that the image becomes lighter, but doubles, blended two different frame.
      strict laws, I did not reveal.
      but most often the bug occurs when the cut clip already applied effect. or when the effect is applied to the clips that are not on the first track. or when the effect is applied to multiple clips at once.
      I found some solution, but it is not very convenient.
      if you go to the drop down list with the names of the tracks and re-select the same track, the bug disappears.
      for example, we had chosen the "video 1", we once again choose "Video 1" and everything is current, as it should be.
      sorry for my english, I am Ukrainian.
      and sorry for wedding too)))
