5 Replies Latest reply on Jun 24, 2014 5:12 PM by myDavey
    Summing cells in a row
    myDavey Level 1
      Hi
      I have a table with many rows
      Sometimes I have to choose a few cells from a few columns and do some mathematical equation, and write into another cell
      E.g. I select columns 3-5 in rows 8-20
      I want to row by row get sum of the 3 columns selected, and the print it into the next column - column 6
      Is there an easy way to work with the cells selected in this situation
      Or do we have to iterate through the cells until we find which ones are selected and getting the row# and column# of the table
      If someone can help me we this I'd appreciate it
      Davey
        • 1. Re: Summing cells in a row
          Jump_Over Level 5
          Solution can be based on:
              1. iterating through selected cells
              2. detecting row's break
              3. place current sum to a cell next to the last of row in the selection
          I.e. like this:
          var
            mT = app.selection[0].cells.everyItem().getElements(),
            currSum, sumCell,
            len = mT.length,
            currCell, prevCell;
          while (len-->0) {
            currCell = mT[len];
            prevCell = mT[len-1];
            currSum = Number(currCell.contents);
            sumCell = currCell.parentRow.cells.nextItem(currCell);
            while (prevCell && currCell.parentRow == prevCell.parentRow && len-->0) {
                 currSum +=  Number(prevCell.contents);
                 currCell = mT[len];
            sumCell.contents = currSum.toString();
          Jarek
          • 2. Re: Summing cells in a row
            myDavey Level 1
            Hi Jarek
            Thanks a lot
            It was the 'nextItem' method that I was missing!
            Now, I understand everything you did here except the second loop
            I didn't test it, but why is the second loop needed?
            Also, little of a side point
            I wasn't using the 'everyItem().getElements()' here
            I never got it straight when its used and when not
            Can you please explain that?
            Davey
            • 3. Re: Summing cells in a row
              Jump_Over Level 5
              Second loop is for calculating a partial sum (from break to break)
              everyItem().getElements() returns an array of objects which is static and faster to iterate through.
              Otherwise you are iterating through an dinamic collection which is much more time consuming.
              Jarek
              • 4. Re: Summing cells in a row
                myDavey Level 1
                I guess I don't fully understand the method of your function yet
                I will try it now to see better how it works
                Regarding the everyItem().getElements()
                So basically its just faster, and therefore it would always be better to use it (unless we're too lazy to type the extra words )
                Thanks a lot
                Davey
                • 5. Re: Summing cells in a row
                  myDavey Level 1
                  Ok, just tried and approved
                  Works great!
                  And, now I understand what the second loop was for
                  Thanks a lot
                  Davey
