0 Replies Latest reply on May 1, 2007 7:08 PM by Tekhni
    ProgressBar used to Preload FLV video
    Tekhni
      Okay I have a normal flash Professional 8 flash document with 2 layers
      Basically what happens when i test the movie and set it to simulate download is a blank (white screen) for ages (presumably whilst its loading the video) then the ProgressBar appears with a blink of an eye and then disapears and the video plays. The ProgressBar does seem to animate if you look closely but its only there for a split second.
      Why do i get a blank screen?
      Do i need to Preload the ProgressBar to make it come up first so people can actually see it?
      What am i doig wrong?
      Here is the set up below:
      1 layer has a FLV movie with a FLVPlayback component so the user can control the playback. This FLV has an instance name of mclip
      the other layer has the ProgressBar component with an instance name of my_pb
      the Parameters of the ProgressBar component are:
      Conversion: 1
      Direction right
      label: LOADING%3%%
      labelPlacement: bottom
      mode: polled
      source: this._parent.mclip
      and the ProgressBar instance has this actionscript attached to hide it once its finished loading:
      on (complete) {
      this.setVisible(false);
