0 Replies Latest reply on Jun 25, 2014 6:18 AM by sn0wctrl
    AFX imports only a single keyframe of mocha tracked shape
    sn0wctrl Level 1
      Hi there
      I'm using Mocha AE in/with the latest release of After Effects.  I have a shape tracked in Mocha, which I then want to pass back into After Effects.  I hit the Export Shape Data button in Mocha, switch to After Effects, select the layer (it's the same piece of video that I tracked in Mocha, in a composition of the same size and frame rate), and then Edit->Paste Mocha Mask
      The mask is pasted as you would expect, but the keyframes are not - so I have the mask shape only at/from the first frame of the Mocha track...
      What did I miss?
      All help appreciated....
      To clarify, I've been following the process from this tutorial video:
      http://www.imagineersystems.com/videos/mocha-ae-paste-mocha-shapes-to-after-effects-mask-c hannel/view
      ... but where, in the video, you see the moving glasses-sjhaped mask in Afx, I'm getting a static mask, with just the one keyframe
      (I'm using Win 7 Pro 64bit, on a reliable custom built PC)
