I have a slide(s) in a project that is set to 1280x720.
After I split the slide, for some reason, the new slide that is now created after the split, gets re-sized to some unknown size.
The slide appears zoomed in far to close so when I now play the project, or just that slide, the screen is zoomed in so far I cannot see most of the originally required capture area.
I've tried using the Modify>Rescale Project command to re-scale/re-size the whole project back to the required size, but I just cannot get the slide after the split to go back tot eh correct/required size.
This happens for ALL slides that I Split.
Any ideas how to fix this?
Thanks.
I'm a bit puzzled by 'split', are you talking about a cptx or a cpvc file?
