3 Replies Latest reply on Jun 26, 2014 8:51 AM by Steve Werner
    Embeding via into InDesign
    auscamonline
      No matter what file type I try, and what extension I offer, I get an error when trying to add a video via URL. File(s) are Flash compliant and with correct extension )*.F4V)
        • 1. Re: Embeding via into InDesign
          Steve Werner Adobe Community Professional & MVP
          I've moved your question to the InDesign forum.
          The setup for placing Flash files from a URL into InDesign is not well documented. All I can offer is what I wrote in an article in InDesign Magazine three years ago:
          "To set up your document for streaming
          video, start by creating an empty frame or
          select a video you want to replace. Choose
          Video from URL from the Media panel menu.
          Specify the URL and click OK.
          "Note that the URL must point to a file that
          ends in the appropriate file extension; for
          example, http://www.fakeURL.com/videos/
          Intro_Video.f4v for a file on a web server. Use
          rtmp:// in the URL for a video on the Flash
          Media Server or Flash Streaming Service."
          • 2. Re: Embeding via into InDesign
            auscamonline Level 1
            Thanks! I have done exactly that. If the file is local, it plays fine, but if I select a URL for a file that I know is F4V and http based, I get the basic ‘go away you are not Flash compatible nor do you have the correct extension’ message.
            There must be a trick I am missing somewhere? ?? That same file when added locally, runs fine…
            David
            • 3. Re: Embeding via into InDesign
              When I wrote the article, I could find no documentation anywhere about exactly how to set it up, I'm afraid. Maybe someone more familiar with server setup can help. I have a feeling it has to do with that.
