2 Replies Latest reply on Jun 26, 2014 11:46 PM by patrickbcm
    hyperlink to button CS6
    patrickbcm Level 1
      Hello is use this script in Indesign CS5 and it works. Now i have CS6 and it's not working anymore.
      It makes the yellow bar but the hyperlink is empty.
      Does somebody know to fix this?
      Kind regards,
      Patrick
      /* Copyright 2014, Kasyan Servetsky
      February 3, 2014
      Written by Kasyan Servetsky
      http://www.kasyan.ho.com.ua
      e-mail: askoldich@yahoo.com */
      var scriptName = "Convert hyperlinks to buttons - 2.0",
      doc;
      Main();
      //===================================== FUNCTIONS  ======================================
      function Main() {
          var hyperlink, source, sourceText, destination, page, arr, outlinedText, gb, button, behavior, sourcePageItem,
          barodeCount = 0,
          hypCount = 0;
          if (app.documents.length == 0) ErrorExit("Please open a document and try again.", true);
          var startTime = new Date();
          doc = app.activeDocument;
          var layer = MakeLayer("Buttons");
          var swatch = MakeColor("RGB Yellow", ColorSpace.RGB, ColorModel.process, [255, 255, 0]);
          var hyperlinks = doc.hyperlinks;
          var progressWin = new Window ("window", scriptName);
          progressBar = progressWin.add ("progressbar", undefined, 0, undefined);
          progressBar.preferredSize.width = 450;
          progressTxt = progressWin.add("statictext", undefined,  "Starting processing hyperlinks");
          progressTxt.preferredSize.width = 400;
          progressTxt.preferredSize.height = 30;
          progressTxt.alignment = "left";
          progressBar.maxvalue = hyperlinks.length;
          progressWin.show();
          for (var i = hyperlinks.length-1; i >= 0; i--) {
              hyperlink = hyperlinks[i];
              source = hyperlink.source;
              destination = hyperlink.destination;
              if (source.constructor.name == "HyperlinkTextSource") {
                  sourceText = source.sourceText;
                  page = sourceText.parentTextFrames[0].parentPage;
                  arr = sourceText.createOutlines(false);
                  outlinedText = arr[0];
                  gb = outlinedText.geometricBounds;
                  outlinedText.remove();
              else if (source.constructor.name == "HyperlinkPageItemSource") {
                  sourcePageItem = source.sourcePageItem;
                  gb = sourcePageItem.geometricBounds;
                  page = sourcePageItem.parentPage;
              barodeCount++;
              progressBar.value = barodeCount;
              progressTxt.text = "Processing hyperlink " + hyperlink.name + " (Page - " + page.name + ")";
              if (source.constructor.name == "HyperlinkTextSource" || source.constructor.name == "HyperlinkPageItemSource") {
                  button = page.buttons.add(layer, {geometricBounds: gb, name: hyperlink.name});
                  button.fillColor = swatch;
                  button.fillTint = 50;
                  button.groups[0].transparencySettings.blendingSettings.blendMode = BlendMode.MULTIPLY;
                  behavior = button.gotoURLBehaviors.add();
                  behavior.url = destination.destinationURL;
                  hyperlink.remove();
                  source.remove();
                  hypCount++;
          var endTime = new Date();
          var duration = GetDuration(startTime, endTime);
          progressWin.close();
          alert("Finished. " + hypCount + " hyperlinks were convertted to buttons.\n(time elapsed: " + duration + ")", scriptName);
      function GetDuration(startTime, endTime) {
          var str;
          var duration = (endTime - startTime)/1000;
          duration = Math.round(duration);
          if (duration >= 60) {
              var minutes = Math.floor(duration/60);
              var seconds = duration - (minutes * 60);
              str = minutes + ((minutes != 1) ? " minutes, " :  " minute, ") + seconds + ((seconds != 1) ? " seconds" : " second");
              if (minutes >= 60) {
                  var hours = Math.floor(minutes/60);
                  minutes = minutes - (hours * 60);
                  str = hours + ((hours != 1) ? " hours, " : " hour, ") + minutes + ((minutes != 1) ? " minutes, " :  " minute, ") + seconds + ((seconds != 1) ? " seconds" : " second");
          else {
              str = duration + ((duration != 1) ? " seconds" : " second");
          return str;
      function MakeLayer(name, layerColor) {
          var layer = doc.layers.item(name);
          if (!layer.isValid) {
              layer = doc.layers.add({name: name});
              if (layerColor != undefined) layer.layerColor = layerColor;
          return layer;
      function MakeColor(colorName, colorSpace, colorModel, colorValue) {
          var doc = app.activeDocument;
          var color = doc.colors.item(colorName);
          if (!color.isValid) {
              color = doc.colors.add({name: colorName, space: colorSpace, model: colorModel, colorValue: colorValue});
          return color;
      function ErrorExit(error, icon) {
          alert(error, scriptName, icon);
          exit();
