2 Replies Latest reply on Jun 27, 2014 3:06 AM by vasilisnikolo
    touchup  tool
    vasilisnikolo Level 1
      hello  i  have  a  trial  version  of  acrobat  XI  por(11.0.7)  and  i  look  for  something  called  touchup tool.where  is  it?can  i  remove  watermarks  with  that  tool?(i  am  new  in  acrobat)
        • 1. Re: touchup  tool
          a C student Level 3
          Hi vasilisnikolo,
          I think you are referring to the Touch Up Reading Order tool. You will find it in the Tools pane under Accessibility. If the Accessibility tools are hiding you can make them visible by View > Tools > Accessibility. But ... it will not be of help in removing a watermark. It is used to add and modify accessibility tags. To remove the watermark - first make sure you work with a copy of your document, since things can go horribly wrong using Acrobat. You could try selecting and deleting the watermark using the Edit Text & Images tool (under Content Editing) or the handy but deprecated Edit Object tool (under Print Production), or find it and deleted in the Content pane. If none of these work, you could try posting in the Creating, Editing, & Exporting PDFs forum - lots of knowledgeable helpful visitors there.
          • 2. Re: touchup  tool
            i  had  heard  fro  the  touchup  tool  which  is  under  print  production  in acrobat  X.conetnt pane?
