8 Replies Latest reply on Jul 20, 2014 8:46 AM by chris breu
    Indesign Applescript Placed Object Layer Visibilty Override
    ingywoo
      Hi, trying to programmatically control layer visibility of placed objects (either AI or other ID files) in a multi-page Indesign document.  Have looked all over the dictionary but can't seem to figure a way to reference the layers.
      Would someone have an example of how to do this in Applescript?  (Please, not javascript, will convert one day but for now am staying with AS.)
      Thanks!
        • 2. Re: Indesign Applescript Placed Object Layer Visibilty Override
          Kevin Parrott Level 2
          Hi
          I am not sure if this is what your after, but this toggles layer visibility.
          tell application "Adobe InDesign CC 2014"
              activate
              tell document 1
                  set Flaplayer to "TEST"
                  --set myLayer to layer Flaplayer
                  --set the properties of myLayer to {locked:true}
                  --set active layer to Flaplayer
                  set visible of layer Flaplayer to false
              end tell
          end tell
          • 3. Re: Indesign Applescript Placed Object Layer Visibilty Override
            Mary Posner Level 3
            I think you're looking for something like this....
              set current visibility of graphic layer "myLayer" of graphic layer options of myGraphic to false
            • 4. Re: Indesign Applescript Placed Object Layer Visibilty Override
              chris breu
              Hi
              Here a little code snippet – hope it can help.
                  set myRectangle to make new rectangle of active document with properties {geometric bounds:{20, 20, 70, 70}}
                  set myLayer to item layer of myRectangle
                  set visible of myLayer to false
              end tell
              Have fun!
              • 5. Re: Indesign Applescript Placed Object Layer Visibilty Override
                ingywoo Level 1
                Thanks, Mary, your suggestion has put me on a good path, but I'm still having some trouble.
                I have several similar documents, each having multiple pages with one placed item per page that are linked, not embedded.  Each of those placed items may or may not have a layer with a specific name.  I'm trying to iterate through the links and toggle visibility of the layers within the placed objects as needed.
                Ultimately the script would:
                    Cycle through all links in the target doc.
                        Get a list of all layers in the current link of the cycle.
                        Cycle through a list of layer names to check.
                            Set the desired layer to visible, all others in the list to not visible.
                            (This could be with a string var that was the same as the desired entry in the list, or a numeric index var to compare with where the counter was in its cycle)
                Here's a verbose example of what I've got so far.  It assumes the target document is already open...
                # With which app are we working?
                    # With which document are we working?
                    set theDocName to "My Indesign Document"
                    # Which layer do we want to be visible?
                    set theDesiredLayer to "My Desired Visible Layer"
                    # Set the Document ID of the chosen document
                    set theDocID to document named theDocName
                    # Work with the chosen document
                    tell theDocID
                        # Create an object of all links of the chosen document
                        set theDocLinks to links of theDocID
                        # Set the count of all links in the chosen document
                        set theDocLinksCount to count of theDocLinks
                        # Cycle through all the linked objects
                        repeat with i from 1 to theDocLinksCount
                            # Create an object of the current link
                            set theCurLink to item i of theDocLinks
                            # Set the name of the current link
                            set theLinkName to name of theCurLink
                            # Create an object of the parent of the current link
                            set theLinkParent to parent of theCurLink
                            # Create an object of the graphic layer options of the parent of the current link
                            set theGraphicLayerOptions to graphic layer options of theLinkParent
                            # Get a count of the layers in the current link
                            set theLayerCount to count of graphic layers of theGraphicLayerOptions
                            # Cycle through the layers in the current link
                            repeat with j from 1 to theLayerCount
                                # Create an object of the current layer
                                set theLayer to item j of graphic layers of theGraphicLayerOptions
                                # THIS FAILS
                                set theLayerName to name of theLayer
                                log "Layer: '" & theLayerName & "' ~ Visible: '" & current visibility of graphic layer theLayerName of theOptions
                                # THIS WORKS ONLY UNDER CERTAIN CONDITIONS
                                set current visibility of graphic layer theDesiredLayer of theGraphicLayerOptions to true
                            end repeat
                        end repeat
                    end tell
                end tell
                The part that works does so only when I let it act on specific links (based on theLinkName).  If the link has no such layer, it bombs (as expected).
                I'd really rather just iterate through the layers of each link and take action based on whether or not my target layer exists in that link.  For that to happen, I need to be able to access the name of the layer.
                When cycling through the layers,
                *should* return a graphic layer object, which has a name property that I could then use for comparison.  But that always fails.
                I've also tried other properties of the graphic layer object such as parent, object reference, etc. It always bombs out when I try to work with the layer object.
                The obvious conclusion is that I'm not really creating a graphic layer object, but according to the dictionary it seems this should work.
                Any ideas what I'm doing wrong?
                Thanks!
                • 6. Re: Re: Indesign Applescript Placed Object Layer Visibilty Override
                  chris breu Level 1
                  sorry for my last answer, I missunderstood.
                  hope this helps.
                  have fun.
                  # here you can list layernames to set visible
                  set myLayerNameList to {"Layername 1", "Layername 2"}
                  tell application "Adobe InDesign CC"
                       set theDocLinks to links of active document
                       repeat with i in theDocLinks
                            set theGraphicLayers to name of graphic layers of graphic layer options of parent of i
                            repeat with j from 1 to count theGraphicLayers
                                 if item j of theGraphicLayers is in myLayerNameList then
                                      set current visibility of graphic layer j of graphic layer options of parent of i to true
                                 else
                                      set current visibility of graphic layer j of graphic layer options of parent of i to false
                                 end if
                            end repeat
                       end repeat
                  end tell
                  • 7. Re: Indesign Applescript Placed Object Layer Visibilty Override
                    ingywoo Level 1
                    Wow, that was so easy!  Thanks for the tip.
                    Took about 30 seconds for a 36 page document with 3 layers to check per link.
                    Had planned to use a list when everything was working.  Here's the final:
                        set theDocName to "My Indesign Document.indd"
                        # Create a list of layer names to check
                        set theLayersList to {"My Layer 1", "My Layer 2", "My Layer 3"}
                        set theDesiredLayer to item 2 of theLayersList
                         # No need to edit below... #
                        # Create an object of all document links in the chosen document
                        set theDocLinks to links of document named theDocName
                        # Cycle through the links
                            # Create an object of all the graphic layer names of the current link
                                # Set the current layer name
                                set theCurLayer to item j of theGraphicLayers
                                # Is this a layer to check?
                                if theCurLayer is in theLayersList then
                                    # Is it the layer I wish to be visible?
                                    if theCurLayer is theDesiredLayer then
                                        # YES - Set visibility to true
                                    else
                                        # NO - set visibility to false
                                    end if
                                end if
                            end repeat
                        end repeat
                    end tell
                    • 8. Re: Indesign Applescript Placed Object Layer Visibilty Override
                      chris breu Level 1
                      that's cool!
                      can you please set the status of your question to answered?
                      and maybe mark my answer?
                      have fun.
