Soap, submit formdata
SPiller Jun 26, 2014 9:14 AMHi everybody,
I'm trying to submit a task and the related data to ALC using Soap, from an external application, to implement HTML/Angular Forms in ALC ES3, but can not find any doc nor any info about what service to invoke...
I've tried to use ProcessManagementTaskService, which seems to be the one invoked when a Flex form is submitted in the workspace, but can not get it work (I get a nullpointerexception on backend side, which, after some decompiling, seems to be caused by a lack of flex session... see ProcessManagementTaskServiceImpl on line 1090, it invokes FlexContext.getHttpRequest, which I bet is null at this point (but that may be the session as well)).
See that decompiled code:
private TaskItemResult callSubmitService(String taskId, int formIndex, com.adobe.idp.Document doc)
throws ProcessManagementException
if (doc == null) {
return null;
long start = ProcessManagementUtils.getCurrentTime();
try
long tid = Long.parseLong(taskId);
HttpServletRequest request = FlexContext.getHttpRequest();
request.getSession().setAttribute("prepared_taskId", ""); // ******* line 1090 -> NPE
Map inputMap = new HashMap();
Map httpHeaders = new HashMap();
String environmentBuffer = (String)doc.getAttribute("environment");
String userAgent = (String)doc.getAttribute("userAgent");
inputMap.put("targetUrl", getTargetUrl());
inputMap.put("relativeTargetUrl", "/rest/services/ProcessManagementDocumentHandlingService.submit");
inputMap.put("environmentBuffer", environmentBuffer);
inputMap.put("userAgent", userAgent);
inputMap.put("acrobatVersion", (String)request.getSession().getAttribute("acrobatVersion"));
inputMap.put("acroClientType", (String)request.getSession().getAttribute("acroClientType"));
inputMap.put("pm:callingApplication", "pm:workspace");
Enumeration headerNames = request.getHeaderNames();
while (headerNames.hasMoreElements()) {
String headerName = (String)headerNames.nextElement();
httpHeaders.put(headerName, request.getHeader(headerName));
httpHeaders.put("accept-language", (String)request.getSession().getAttribute("Accept-Language"));
inputMap.put("httpHeaders", httpHeaders);
TaskManager tm = TaskManagerClientFactory.getTaskManager(ProcessManagementUtils.getServiceClientFactory());
FormServiceInvokeResponse response = null;
long innerStart = ProcessManagementUtils.getCurrentTime();
try
response = tm.callSubmitService(tid, 0L, doc, inputMap);
catch (TaskManagerException e) {
String msg = ProcessManagementUtils.formatMessage("ALC-WKS-005-029", new Object[] { taskId });
throw new ProcessManagementException(msg, e);
catch (RuntimeException e) {
ProcessManagementUtils.traceTime(this, timeLogger, "submit.tm.callSubmitService", innerStart, Level.FINER);
TaskItemResult results = new TaskItemResult();
populateTaskItemResult(results, response);
FormInstance _formInstanceReturned = tm.getEmptyForm();
_formInstanceReturned.setDocument(response.getResultingDocument());
try
Object successSubmit = results.getMap().get("success");
Object renderAgain = results.getMap().get("newRender");
tm.setParticipantIPAddress(ProcessManagementUtils.getClientIPAddress(request));
if ((successSubmit != null) && (renderAgain != null)) {
if ((renderAgain.toString().compareTo("false") == 0) && (successSubmit.toString().compareTo("true") == 0)) {
tm.save(tid, _formInstanceReturned);
else
finally
jsr 6; } ProcessManagementUtils.traceTime(this, timeLogger, "submit.tm.save", innerStart, Level.FINER); ret;
return results;
finally
ProcessManagementUtils.traceTime(this, timeLogger, "submit", start, Level.FINER);
Then, I tried to invoke TaskManagerService, but I can't get it work too / doesn't seem to be the right service...
Can anybody shed some light on this?
Thanks you very much in advance!
