15 Replies Latest reply on Aug 4, 2014 4:15 PM by HarveyLiu
    Is that possible to write a script for export underline text to PDF?
    HarveyLiu Level 1
      When I do some alteration in the financial document, I have to underline it aim to show what I have amend, those underline was called “markup“. And then print (hard copy) and gen (PDF) the amendment, which mean I have to print and gen the underline text (or called markup text) after  alteration.
      sample pic:
      If:
      Client request a new version of markup which mean I have change the last markup color (last amendments’ underline color) into “back” and then make new markup to “red” like this:
      What I want:
      is that possible to write a script for print and gen the markup text only in the all open document
      and I want two versions
      1) gen all the markup text no matter what the underline color
      2) gen the red color of markup text
      thanks!
        • 1. Re: Is that possible to write a script for export underline text to PDF?
          Trevorׅ Adobe Community Professional
          Post the PDF of the exact output you want for those files
          1 screenshot of the indesign file
          and screenshots of both PDF files
          • 2. Re: Is that possible to write a script for export underline text to PDF?
            HarveyLiu Level 1
            first I want go gen those pages in which have underline text, not matter what colour of underline, or how many underline text
            how many I have to pay for it?
            • 3. Re: Is that possible to write a script for export underline text to PDF?
              HarveyLiu Level 1
              two of pic was exact what I want to output
              • 4. Re: Is that possible to write a script for export underline text to PDF?
                HarveyLiu Level 1
                I write the script first, then I'll pay to you then you give me the script
                • 5. Re: Is that possible to write a script for export underline text to PDF?
                  Send a link (public share) to the indesign source file and the PDF output files
                  Can't give any price until I get the files and fully understand what you want
                  For you I would want partial payment before writing the script and partial payment afterward
                  • 6. Re: Is that possible to write a script for export underline text to PDF?
                    HarveyLiu Level 1
                    in a file, in which some have underline some not
                    it was so simple, I just want gen the page in which have underline text, is that clear
                    • 7. Re: Re: Is that possible to write a script for export underline text to PDF?
                      Chinnadk Level 4
                      Hi HarveyLiu,
                      Does this you ask? It will export the pages which have underlined text.
                      var doc = app.documents;
                      app.findTextPreferences = null;
                      app.findTextPreferences.underline = true;
                      for(var i=0;i<doc.length;i++)
                              var found = doc[i].findText();
                              var _pages = [];
                              for(var j=0;j<found.length;j++)
                                      var txfms = found[j].texts[0].parentTextFrames;
                                      for(var k=0;k<txfms.length;k++)
                                              _pages.push(txfms[k].parentPage.name);
                              for(var j=0;j<_pages.length;j++)
                                      if(_pages[j] === _pages[j-1])
                                              _pages.splice(j,1);
                              if(_pages.length != 0)
                                      app.pdfExportPreferences.pageRange = _pages.toString();
                                      doc[i].exportFile(ExportFormat.PDF_TYPE, new File(doc[i].fullName.toString().replace(/\.indd$/i,".pdf")), false);
                              _pages = [];
                      Regards,
                      Chinna
                      • 8. Re: Is that possible to write a script for export underline text to PDF?
                        HarveyLiu Level 1
                        Thank you Chinna, thank you so much, geat for you to help, appreciate!
                        but I still continued to seek my second version
                        app.findTextPreferences.underlineColour = red;     <-------------- Can I add this line?
                        var _pages = [];
                                                _pages.splice(j,1);
                                _pages = [];
                        • 9. Re: Is that possible to write a script for export underline text to PDF?
                          HarveyLiu Level 1
                          Hi, Chinna
                          How can change it for second version of script:
                          only gen the red colour of underline text to pdf?
                          Best Regards,
                          Harvey
                          • 10. Re: Is that possible to write a script for export underline text to PDF?
                            HarveyLiu Level 1
                            Hi, Chinna
                            Can you help me to fix a little problem?
                            I want to add a folder into it?
                                    var _pages = [];
                                                    _pages.splice(j,1);
                                            doc[i].exportFile(ExportFormat.PDF_TYPE, new Folder( myFolder.fsName + "/<-----Out Folder/" ), new File(doc[i].fullName.toString().replace(/\.indd$/i,".pdf")), false);
                                    _pages = [];
                            but not work
                            • 11. Re: Re: Is that possible to write a script for export underline text to PDF?
                              Hi Harvey
                              You can use
                              app.findTextPreferences.underlineColor = "red";
                              Where Red is the name of the swatch but it must be in "quotes"
                              regarding the folder  issue you can use
                              doc[i].exportFile(ExportFormat.PDF_TYPE, new File("C:/my pdf exports folder/subFolder/" + doc[i].name.replace(/\.indd$/i,".pdf")), false);
                              Where "C:/my pdf exports folder/subFolder/" is the path of the folder. Take note of the / needed at the end of the folder name
                              HTH
                              Trevor
                              • 12. Re: Is that possible to write a script for export underline text to PDF?
                                HarveyLiu Level 1
                                Thanks Trevor
                                Thank you very much,
                                How can it credit a new folder in same folder as a subfolder
                                Harvey
                                • 13. Re: Re: Is that possible to write a script for export underline text to PDF?
                                  Chinnadk Level 4
                                  Second script:
                                          var _contents = [];
                                          if(found.length>0)
                                              var _file = new File(doc[i].fullName.toString().replace(/\.indd$/i,".txt"));
                                              _file.open('w');
                                                      _file.write(found[j].contents + "\r");
                                          _file.close();
                                  Regards,
                                  Chinna
                                  • 14. Re: Is that possible to write a script for export underline text to PDF?
                                    HarveyLiu Level 1
                                    Thank you Chinna, Thank you very much
                                    Harvey
                                    • 15. Re: Is that possible to write a script for export underline text to PDF?
                                      HarveyLiu Level 1
                                      Hi, China
                                      I fund this script has problems, I mean gen pdf script, could you please help me to fix it?
                                      1) this script gen multi times for one page?
                                      2) if there are some text frame on desktop, and the text frame has underline text, it will give me an error
                                      thanks
                                      Regard
                                      Harvey
