This content has been marked as final.
Show 2 replies
1. Re: I try to insert some images on a website but the images are not in the right color mode. I do not know what to do? and also I have 1200 images to insert so I can not change one after one. So I need to set up an action, but I donot know how to do it...
c.pfaffenbichler Jun 28, 2014 8:26 AM (in response to stinnocent)What is the problem specifiaclly?
If the images are intended for web use I would recommend converting them to sRGB which could be done with Edit > Convert to Profile or with File > Save for Web, but as including a Save step in Actions and applying them as Batch can sometimes cause problems I would go with regular converting.
You could also try Image Processor Pro.
2. Re: I try to insert some images on a website but the images are not in the right color mode. I do not know what to do? and also I have 1200 images to insert so I can not change one after one. So I need to set up an action, but I donot know how to do it...
stinnocent Jun 28, 2014 8:40 AM (in response to stinnocent)Yes I think it works thanks a lot!!!
