1. Re: 3D option doesn't work photoshop cc 2014
Chris CoxJun 28, 2014 1:55 PM (in response to SuperVan-FlyingDutchMan)
The error tells you the problem - your GPU has issues and can't run the 3D features.
Update the video card driver from the GPU maker's website - that should fix most of the bugs, but your GPU might still not meet the minimum requirements for the 3D features.
2. Re: 3D option doesn't work photoshop cc 2014
SuperVan-FlyingDutchMan Jun 29, 2014 5:03 AM (in response to Chris Cox)I can't find the good driver, can you help me??
My video card is Intel Celeron...
3. Re: 3D option doesn't work photoshop cc 2014
Noel Carboni Jun 29, 2014 5:54 AM (in response to SuperVan-FlyingDutchMan)SuperVan-FlyingDutchMan wrote:
That sounds more like a description of your CPU than your video card.
Maybe you could go into Photoshop CC, choose Help - System Info, copy the data, and paste it into a post here. That could help others identify the specifics of your hardware.
You're going to need to become more familiar with your computer workings to solve this.
-Noel
4. Re: 3D option doesn't work photoshop cc 2014
SuperVan-FlyingDutchMan Jun 29, 2014 6:00 AM (in response to Noel Carboni)This?? I don't know what you can do with this it's dutch.
Versie Adobe Photoshop: 2014.0.0 20140508.r.58 2014/05/08:23:59:59 x32
Besturingssysteem: Windows 7 32 bits
Versie: 6.1 Service Pack 1
Systeemarchitectuur: Intel CPU-familie:6, Model:10, Stepping:7 met MMX, SSE-integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
Aantal fysieke processors: 2
Snelheid processor: 1596 MHz
Ingebouwd geheugen: 1894 MB
Beschikbaar geheugen: 430 MB
Hoeveelheid beschikbaar geheugen voor Photoshop: 1451 MB
Geheugen in gebruik door Photoshop: 69 %
Afdrukken in 3D met meerdere tonen: Uitgeschakeld.
Aanraakbewegingen: Uitgeschakeld.
Windows 2x UI: Uitgeschakeld.
Blokgrootte van afbeelding: 128 kB
Niveaus voor afbeeldingscache: 4
Lettertypevoorvertoning: Normaal
TextComposer: Latijn
Scherm: 1
Grenzen: boven= 0, links= 0, onder= 768, rechts= 1366
OpenGL-tekenen: Ingeschakeld.
OpenGL-modus Oude GPU's toestaan: Niet gedetecteerd.
OpenGL-tekenmodus: Geavanceerd
OpenGL-modus Normaal toestaan: Waar.
OpenGL-modus Geavanceerd toestaan: Waar.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
glgpu[0].GLVersion="3.0"
glgpu[0].GLMemoryMB=818
glgpu[0].GLName="Intel(R) HD Graphics"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="9.17.10.3517"
glgpu[0].GLRectTextureSize=8192
glgpu[0].GLRenderer="Intel(R) HD Graphics"
glgpu[0].GLRendererID=262
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="igdumd32.dll,igd10umd32.dll,igd10umd32.dll"
glgpu[0].GLDriverDate="20140320000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Intel Build 9.17.10.3517"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447 ]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[512]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[1024]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[41]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
Type licentie: Evaluatieversie
Serienummer: Evaluatieversie
Toepassingsmap: C:\Program Files\Adobe\Adobe Photoshop CC 2014 (32 Bit)\
Tijdelijk bestandspad: C:\Users\Ilyass\AppData\Local\Temp\
Werkgeheugen van Photoshop heeft asynchrone I/O ingeschakeld
Werkvolume(s):
C:\, 149,0 GB, 28,0 GB vrij
Map met vereiste plug-ins: C:\Program Files\Adobe\Adobe Photoshop CC 2014 (32 Bit)\Required\Plug-ins\
Primaire map voor plug-ins: C:\Program Files\Adobe\Adobe Photoshop CC 2014 (32 Bit)\Plug-ins\
Geïnstalleerde componenten:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2014/04/14-23:42:44 79.554120 79.554120
adbeape.dll Adobe APE 2013/02/04-09:52:32 0.1160850 0.1160850
AdbePM.dll PatchMatch 2014/04/23-10:46:55 79.554276 79.554276
AdobeLinguistic.dll Adobe Linguisitc Library 8.0.0
AdobeOwl.dll Adobe Owl 2014/03/05-14:49:37 5.0.33 79.552883
AdobePDFL.dll PDFL 2014/03/04-00:39:42 79.510482 79.510482
AdobePIP.dll Adobe Product Improvement Program 7.2.1.3399
AdobeXMP.dll Adobe XMP Core 2014/01/13-19:44:00 79.155772 79.155772
AdobeXMPFiles.dll Adobe XMP Files 2014/01/13-19:44:00 79.155772 79.155772
AdobeXMPScript.dll Adobe XMP Script 2014/01/13-19:44:00 79.155772 79.155772
adobe_caps.dll Adobe CAPS 8,0,0,7
AGM.dll AGM 2014/04/14-23:42:44 79.554120 79.554120
ahclient.dll AdobeHelp Dynamic Link Library 1,8,0,31
amtlib.dll AMTLib 8.0.0.45 BuildVersion: 8.0; BuildDate: Fri Mar 28 2014 20:28:30) 1.000000
ARE.dll ARE 2014/04/14-23:42:44 79.554120 79.554120
AXE8SharedExpat.dll AXE8SharedExpat 2013/12/20-21:40:29 79.551013 79.551013
AXEDOMCore.dll AXEDOMCore 2013/12/20-21:40:29 79.551013 79.551013
Bib.dll BIB 2014/04/14-23:42:44 79.554120 79.554120
BIBUtils.dll BIBUtils 2014/04/14-23:42:44 79.554120 79.554120
boost_date_time.dll photoshopdva 8.0.0
boost_signals.dll photoshopdva 8.0.0
boost_system.dll photoshopdva 8.0.0
boost_threads.dll photoshopdva 8.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.2.6.32411 2.2.6.32411
CITThreading.dll Adobe CITThreading 2.2.6.32411 2.2.6.32411
CoolType.dll CoolType 2014/04/14-23:42:44 79.554120 79.554120
dvaaudiodevice.dll photoshopdva 8.0.0
dvacore.dll photoshopdva 8.0.0
dvamarshal.dll photoshopdva 8.0.0
dvamediatypes.dll photoshopdva 8.0.0
dvametadata.dll photoshopdva 8.0.0
dvametadataapi.dll photoshopdva 8.0.0
dvametadataui.dll photoshopdva 8.0.0
dvaplayer.dll photoshopdva 8.0.0
dvatransport.dll photoshopdva 8.0.0
dvaui.dll photoshopdva 8.0.0
dvaunittesting.dll photoshopdva 8.0.0
dynamiclink.dll photoshopdva 8.0.0
ExtendScript.dll ExtendScript 2014/01/21-23:58:55 79.551519 79.551519
icucnv40.dll International Components for Unicode 2013/02/25-15:59:15 Build gtlib_4.0.19090
icudt40.dll International Components for Unicode 2013/02/25-15:59:15 Build gtlib_4.0.19090
imslib.dll IMSLib DLL 7.0.0.145
JP2KLib.dll JP2KLib 2014/03/12-08:53:44 79.252744 79.252744
libeay32.dll The OpenSSL Toolkit 0.9.8g
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.2.1.3399
mediacoreif.dll photoshopdva 8.0.0
MPS.dll MPS 2014/03/25-23:41:34 79.553444 79.553444
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2014 15.0
Plugin.dll Adobe Photoshop CC 2014 15.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (32 bit) 5.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (32 bit) 5.0.0.74
PSArt.dll Adobe Photoshop CC 2014 15.0
PSViews.dll Adobe Photoshop CC 2014 15.0
SCCore.dll ScCore 2014/01/21-23:58:55 79.551519 79.551519
ScriptUIFlex.dll ScriptUIFlex 2014/01/20-22:42:05 79.550992 79.550992
ssleay32.dll The OpenSSL Toolkit 0.9.8g
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 2, 2013, 1114
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 2, 2013, 1114
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 7.0.1.102
VulcanControl.dll Vulcan Application Control Library 5.0.0.82
VulcanMessage5.dll Vulcan Message Library 5.0.0.82
WRServices.dll WRServices Fri Mar 07 2014 15:33:10 Build 0.20204 0.20204
wu3d.dll U3D Writer 9.3.0.113
Vereiste plug-ins:
3D Studio 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Adaptief groothoek 15.0
Andere wolken 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Arcering 15.0
Asymmetrisch 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Basreliëf 15.0
Bereik 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
BMP 15.0
Bol 15.0
Camera Raw 8.5
Camera Raw-filter 8.5
Chroom 15.0
Cineon 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Collada 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
CompuServe GIF 15.0
Conté crayon 15.0
Craquelure 15.0
De-Interlace 15.0
Dicom 15.0
Donkere lijnen 15.0
Droog penseel 15.0
Eazel Acquire 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Entropie 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Export Color Lookup NO VERSION
FastCore Routines 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Filigraan 15.0
Filmkorrel 15.0
Filter Figuurpakket 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Filter Foto's uitsnijden en rechttrekken 15.0
Filtergalerie 15.0
Flash 3D 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Fotokopie 15.0
Foto's uitsnijden en rechttrekken 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Fresco 15.0
Geaccentueerde randen 15.0
Gebrandschilderd glas 15.0
Geef diepte 15.0
Gemiddeld 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Gemiddelde 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Gescheurde randen 15.0
Gips 15.0
Glas 15.0
Gloed onscherp 15.0
Golf 15.0
Google Earth 4 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Grafische pen 15.0
Halftoonraster 15.0
HDRMergeUI 15.0
Hoeklijn 15.0
Houtskool 15.0
IFF-formaat 15.0
Inktomtrek 15.0
JPEG 2000 15.0
Kleur halftoon 15.0
Kleurpotlood 15.0
Klodder 15.0
Kneep 15.0
Knipsel 15.0
Korrel 15.0
Krijt en houtskool 15.0
Kristal 15.0
Kronkel 15.0
Lappendeken 15.0
Lenscorrectie 15.0
Matlab Operation 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Maximaal 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Mediaan 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Metingskern 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Mezzotint 15.0
Minimaal 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
MMXCore-routines 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Mozaïektegels 15.0
Neon gloed 15.0
NTSC-kleuren 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Oceaanrimpel 15.0
Ondersteuning van meerdere processors 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
OpenEXR 15.0
Oplichtende rand 15.0
Opslaan voor web 15.0
Optelling 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Paden naar Illustrator 15.0
Paletmes 15.0
PCX 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Perspectiefpunt 15.0
Photoshop 3D-engine 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Photoshop Touch 14.0
Pixar 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Plastic 15.0
PNG 15.0
Pointilleren 15.0
Poolcoördinaten 15.0
Portable Bit Map 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Posterranden 15.0
Postpapier 15.0
Radiaal vaag 15.0
Radiance 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Render Color Lookup Grid NO VERSION
Rimpel 15.0
Ruw pastel 15.0
Schokreductie 15.0
Schuin 15.0
Scriptondersteuning 15.0
Slim vervagen 15.0
Solariseren 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Spetters 15.0
Spons 15.0
Sproeilijn 15.0
Standaardafwijking 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Stempel 15.0
STL 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Structuurmaker 15.0
Sumi-e 15.0
Targa 15.0
Tegels 15.0
Uitvloeien 15.0
Vage lens 15.0
Variantie 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Verplaatsen 15.0
Vezels 15.0
Vlek 15.0
Voorbewerking 15.0
Watermerk insluiten 4.0
Watermerk lezen 4.0
Waterpapier 15.0
Waterverf 15.0
Wavefront|OBJ 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Welving 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
WIA-ondersteuning 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Wind 15.0
Wireless Bitmap 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
Wolken 15.0 (2014.0.0 20140508.r.58 2014/05/08:23:59:59)
ZigZag 15.0
Zon 15.0
Optionele plug-ins en plug-ins van derden: GEEN
Plug-ins die niet konden worden geladen: GEEN
Flash:
Geïnstalleerde TWAIN-apparaten: GEEN
5. Re: 3D option doesn't work photoshop cc 2014
Noel Carboni Jun 29, 2014 6:36 AM (in response to SuperVan-FlyingDutchMan)You have Intel HD graphics, and your display driver appears to be reasonably up to date (though it's 3 months old - you could double-check).
This is probably the problem.
Your system is severely lacking in RAM. As I recall the Intel graphics driver shares the main system RAM with the CPU. You may simply not have enough free RAM to be able to complete the 3D operation.
You might experiment with LOWERING the percentage. Close and restart Photoshop after making a change there. Also make sure you're not running any other applications that are taking up RAM.
-Noel
6. Re: 3D option doesn't work photoshop cc 2014
SuperVan-FlyingDutchMan Jun 29, 2014 7:29 AM (in response to Noel Carboni)Can i do something to use 3D?
7. Re: 3D option doesn't work photoshop cc 2014
Noel Carboni Jun 29, 2014 7:30 AM (in response to SuperVan-FlyingDutchMan)Assuming you read my last paragraph above, and it didn't work, you can try installing more RAM in your computer.
-Noel
