1 Reply Latest reply on May 4, 2007 5:20 AM by batmitra
    webservice and flex
    kanukukreja
      Hello,
      i’m trying to get a result from web services in flex but I’m not able to get it.
      And one more thing instead of writing this code in MXML file I want to write it in to a class and then call it.
      Will you please help me out in this?
      Here’s my code:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" >
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      import mx.rpc.Responder
      import mx.rpc.Fault
      import mx.rpc.soap
      import mx.rpc.soap.WebService
      import mx.rpc.soap.WSDL
      import mx.rpc.soap.LoadEvent
      import flash.events.EventDispatcher
      import mx.rpc.soap.Operation
      var webService:WebService = new WebService();
      webService.wsdl= " http://210.7.70.114/ws/poker.asmx?wsdl";
      webService.loadWSDL();
      webService.addEventListener(LoadEvent.LOAD, onWSDL);
      webService.addEventListener(ResultEvent.RESULT, onRes);
      webService.addEventListener(FaultEvent.FAULT,onFault);
      webService.StartUserGameSession("mo64uq12557030rlzkxo45jke3yszb")
      private function onRes(event:ResultEvent):void {
      trace("successful")
      private function onFault(event:FaultEvent):void {
      trace("error")
      </mx:Script>
      </mx:Application>
        • 1. Re: webservice and flex
          batmitra Level 1
          Hi
          Are you using .Net for your webservice?
          If yes, then if you are using framework 1, you can't deal with webservices directly on flex, but you can build an array of objects and return it to flex, on flex you have to build an arrayCollection with those objects received.
          Another thing , if you want to have results, you must have an operation name, wich is the name of your method on your webservice, and you must invoke your webservice something like mywebservice.myoperation()
