1 Reply Latest reply on Jun 29, 2014 2:32 PM by George_Johnson
    Validating an Acrobat forms text field
    BrianDunkin
      I'm using Acrobat X1 Pro and Live Cycle Designer ES4
      I have a numeric text field to capture a blank or 14 digit number.
      The display pattern is: null{}|num{zzzzzzzzzzzzzz}
      The edit pattern is: null{}|num{zzzzzzzzzzzzzz}
      The validation pattern is:
      The data pattern id : null{}|num{zzzzzzzzzzzzzz}
      I'm trying to make test that the user:
      only enters numbers
      enters nothing or a 14 digit number.
      Display an error message and set focus back on the field for wrong entries.
      This is the code:
      topmostSubform.Page1.AU01::exit - (JavaScript, client)
      // Test AU number format
      var re = /^[0-9]{14}$/
      //Allow blank space in field
      if (event.value !="") {
        if (re.test(event.value) == false) {
          app.alert ({
             cTitle: "Incorrect AU Format",
             cMsg: "Enter a valid 14-digit AU number."
           getField("AU01").setFocus);
      I get the error message when I exit the field regardless of what is in the field. And the set focus does not seem to work.
      I can program in VBA but find Javascript challenging. What good reference books can you recommend?
      May thanks.
      Brian Dunkin
