I'm using Acrobat X1 Pro and Live Cycle Designer ES4
I have a numeric text field to capture a blank or 14 digit number.
The display pattern is: null{}|num{zzzzzzzzzzzzzz}
The edit pattern is: null{}|num{zzzzzzzzzzzzzz}
The validation pattern is:
The data pattern id : null{}|num{zzzzzzzzzzzzzz}
I'm trying to make test that the user:
only enters numbers
enters nothing or a 14 digit number.
Display an error message and set focus back on the field for wrong entries.
This is the code:
topmostSubform.Page1.AU01::exit - (JavaScript, client)
// Test AU number format
var re = /^[0-9]{14}$/
//Allow blank space in field
if (event.value !="") {
if (re.test(event.value) == false) {
app.alert ({
cTitle: "Incorrect AU Format",
cMsg: "Enter a valid 14-digit AU number."
getField("AU01").setFocus);
I get the error message when I exit the field regardless of what is in the field. And the set focus does not seem to work.
I can program in VBA but find Javascript challenging. What good reference books can you recommend?
May thanks.
Brian Dunkin
Views
Total Likes
