12 Replies Latest reply on May 3, 2007 11:08 AM by Newsgroup_User
    Photoshop Fill - A major integration issue?
    Stowball
      For the first time in a production environment, I was ready to use FW CS3 to slice and dice a colleague's PSD. I opened it in Photoshop and then in Fireworks for comparison - the two looked nothing alike.
      This particular colleague likes to take advantage of PS's Fill setting (as opposed to opacity and I can understand why in certain situations) - but Fireworks has no understanding of this Fill concept so every layer that uses it is darker in FW. So what's a guy to do?
      Is this a known integration issue? Will there be a solution for CS4? Can I wait that long? Is it ever really worth trying to open a PSD in Fireworks?
      I'm more than a little disappointed...
      Matt
      Firewoiks
        • 1. Re: Photoshop Fill - A major integration issue?
          Level 7
          The problem might be caused by the image mode settings in Photoshop. If
          he is creating images for the web he should be using the sRGB color
          space rather than CMYK. In addition, embedded color profiles are ignored
          by Fireworks just as they are by browsers.
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          http://www.adobe.com/communities/experts/
          • 2. Photoshop Fill - A major integration issue?
            Stowball Level 1
            Linda
            The problem is not caused by any colour mode or embedded profiles - it's caused by Fireworks' lack of support for Photoshop's Fill feature.
            The Fill feature is useful, because you can change the opacity of the actual fill, without changing the opacity of any effects - like strokes - that are applied to the layer.
            My colleague uses this method frequently in his designs.
            This PNG demonstrates it perfectly: http://www.mattstow.com/downloads/fill_test.png
            And the original PSD can be found here: http://www.mattstow.com/downloads/fill_test.psd
            This is a real issue for PS->FW interoperability - I basically could not use FW for the task of preparing a design for the web.
            I'd be interested to hear how this will affect other users.
            Regards
            Matt
            • 3. Re: Photoshop Fill - A major integration issue?
              Level 7
              You can change the opacity of the fill in FW as well
              Stowball wrote:
              > Linda
              > My colleague uses this method frequently in his his designs.
              > Regards
              > Matt
              • 4. Re: Photoshop Fill - A major integration issue?
                Level 7
                If all you are doing is slicing it up for the web, why not have your
                colleague send it to you as a flattened png or jpeg?
                SKB
                • 5. Re: Photoshop Fill - A major integration issue?
                  Level 7
                  I haven't tried this yet, but here's a thought:
                  PS is layer based, FW is object bases. As a result, in FW you can
                  control the opacity of layers AND objects. Is it similar enough to
                  Photoshop's Fill and Opacity in a layer? Maybe adjusting the opacity of
                  the object will get you what you need? It might impact the stroke on the
                  object, but you could possibly duplicate the object and remove/mask it's
                  fill, so the solid stroke remains.
                  It's a workaround, and a bit more work, but it might solve the problem
                  for now.
                  Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
                  Extending Knowledge, Daily
                  http://www.communityMX.com/
                  CommunityMX - Free Resources:
                  http://www.communitymx.com/free.cfm
                  .:Adobe Community Expert for Fireworks:.
                  news://forums.macromedia.com/macromedia.fireworks
                  news://forums.macromedia.com/macromedia.dreamweaver
                  Stowball wrote:
                  > Linda
                  > Regards
                  > Matt
                  • 6. Re: Photoshop Fill - A major integration issue?
                    Stowball Level 1
                    quote:
                    No, you can only change the opacity of an object in Fireworks. So, in the example I posted, the black border would also become semi-transparent - which is not the desired effect.
                    To change the opacity of a fill only can only be done with vectors, by changing the fill to a gradient, and setting the gradient nodes to be identical in colour and opacity.
                    Matt
                    • 7. Re: Photoshop Fill - A major integration issue?
                      Level 7
                      It's not going to affect me because I use Fireworks rather than
                      Photoshop for designing Web graphics. :-)
                      • 8. Re: Photoshop Fill - A major integration issue?
                        Stowball Level 1
                        Because slicing for the web is no longer a clear-cut, black-and-white exercise. For example, we need to consider how text resizing will affect the visuals of a design.
                        Take this crude example: http://www.mattstow.com/downloads/resize_header.png
                        The desired effect couldn't have been done if I was working from a flat file. I need layered files, to be able to do this kind of thing, thus I need the import of PSDs to be as perfect as possible, which includes understanding Photoshop's unique Fill opacity feature.
                        As a professional web and user interface designer, I recognise the importance of adding little touches to the sites I create. Not everyone will notice the time and effort that has gone into creating it, but if I can get a "wow" from a few users who appreciate will appreciate it, then I'm happy.
                        Regards
                        Matt
                        • 9. Re: Photoshop Fill - A major integration issue?
                          Stowball Level 1
                          for now.
                          Hi Jim
                          Yes, it's a workaround - but one I'd rather not have to do. For the example I provided, it was relatively simple, but for some of the stuff I'm given to work with, it's a Neddy-no-no.
                          If only I could get my team to work exclusively in FW!!!!! They can see the benefits, but they're too stuck in their ways and stubborn to change from Photoshop. Aaaarrrrrghhhh.
                          So in the meantime... Adobe, please provide a real solution. Alan...are you listening?
                          Matt
                          • 10. Re: Photoshop Fill - A major integration issue?
                            Level 7
                            A gradient fill can be made transparent. For a solid color just make
                            both ends of the gradient fill the same color.
                            So you can have the border be solid and the fill be semi-transparent
                            > Matt
                            • 11. Photoshop Fill - A major integration issue?
                              Level 1
                              Matt,
                              I believe that Alan is pretty darn busy lately.
                              Perhaps that you might want to address this issue with Adobe team by filling in a form to submit for feedback and/or suggestion through Adobe feature request form link below:
                              http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
                              I hope that helps.
                              Cheers, Brian
                              quote:
                              for now.
                              Hi Jim
                              Matt
                              • 12. Re: Photoshop Fill - A major integration issue?
                                Level 7
                                see the
                                I'm afraid you are going against the current. Even 'your' request was to
                                make Fireworks more interoperable with Photoshop rather than Photoshop
                                being more interoperable with Fireworks. :)
                                SKB
