1 2 Previous Next 66 Replies Latest reply on Apr 3, 2017 12:56 PM by ONDA.ID
    Problem with color management: Indesign vs. Photoshop colors are not the same! Display color varies eventhough assigned profiles are the same. Solution?
    kotkkkkk Level 1
      I have problem with Color management in Indesign, Illustrator and Photoshop CS6 - displayed colors vary between programs.
      Pictures are displayed greenish in Illustrator and Indesign.
      And "normal" in Photoshop, Lightroom, Bridge.
      I checked:
      - Working Space: is the same in all three programs (RGB: sRGB IEC61966-2.1, CMYK: Coated FOGRA39 (ISO 12647-2:2004), I even tried switching them to preset North America general purpose 2, problem remains)
      - Assigned profile to document is the same (Tried assigning different profiles including sRGB IEC... but problem remains)
      - Monitor is calibrated (with i1, I even checked for corrupt profile with assigning display ICC profile as AdobeRGB)
      - Problem persist even if I hook up other monitor - this eliminates monitor and display ICC profile fault
      What could be the problem. I'm a bit desperate and don't even know what else to check. Unfortunatelly I don't have printer available to check the color that way.
      What could be the reason for mismatch between Photoshop and Indesign when displaying images?
      Thank you for your suggestions in advance!
        1 2 Previous Next
