0 Replies Latest reply: Jun 30, 2014 8:41 AM by Apod42 RSS
    Pattern overlay - not quite so seamless
    Apod42 Community Member
      Hello all,
      In Photoshop select "Pattern overlay" for a layer and choose any pattern in the library. At a quick glance the pattern fill seems seamless, but at a very careful look there are fine lines/discolorations between the "tiles" composing the pattern overlay. Please take a look at the attached image for an exemplification (the image is on negative, to better show the problem).
      From your experience, any "quick fix" for this? Without too much blur, too much noise, ideally the texture should remain mostly unchanged... Thank you!
      Example image on negative, to better illustrate the problem. Notice the dark vertical and horizontal lines...
