1. Re: Trying to understand different file sizes based on publishing options
milhousebarks Jun 30, 2014 10:35 AM (in response to milhousebarks)Okay, maybe I have part of the answer figured out. It looks like the optimized on individual slides is making my jpg photos on some slides into bmp images, which would definately add some bloat. So is that the main cuprit? Also, any insight into checking or unchecking the Advanced Project Compression?
Thanks.
2. Re: Trying to understand different file sizes based on publishing options
RodWard Jun 30, 2014 6:16 PM (in response to milhousebarks)Advanced Project Compression tries to optimise the compression settings on a slide-by-slide basis for better overall file size reduction. It's usually NOT a problem. However, in some cases we advise developers to turn it off as it is often responsible for 'artifacts' such as 'ghost lines' appearing on slides.
I usually find that using High 24bit compression actually gives lower file sizes than using the Optimized setting. Go figure...
