5 Replies Latest reply on Jun 30, 2014 1:58 PM by A.T. Romano
    can't get Premiere tutorials to play
    Avo
      Hello,
      I am opening Premiere elements, clicking on the Guided tab, and am then trying to play the video tutorials. However, the tutorials do not play. When I click on a subject (e.g.>Trimming unwanted frames), the same image (with 2 sets of instructions) Getting Started image/instructions appears, and not the videos. The same image appears no mater what topic I click on (e.g. Adding scores to your movie).
      Any idea what I am doing wrong? Thank you, Avo
        • 1. Re: can't get Premiere tutorials to play
          Avo Level 1
          I answered my own question. Thank you and Sorry for the false alarm.
          • 2. Re: can't get Premiere tutorials to play
            A.T. Romano Level 7
            Avo
            From your screenshot you appear to be working on Premiere Elements 12 Mac. Please be sure to install and work from the 12.1 Update. See Help Menu/Update. After that
            Open a new project....
            When you select Quick Guided, the first thing you should see is
            What are you selecting, "Getting started with Premiere Elements" or something else?
            For this troubleshooting, please start a new project and select "Getting started with Premiere Elements".
            You should see the following after you select that tutorial
            When you click NEXT at the bottom of that Guided Editing dialog, you should see
            Once you click on Add Media with the yellow frame, you should get
            Guided is not a video tutorial. It is a set of instructions to guide you through steps in different workflows.
            Please review and consider and then let us know if this is a matter of expectations and interpretations on the Guided feature or whether there
            are technical flaws in your project. If you use Expert Guided instead of Quick Guided do you find yourself in the same situation?
            ATR
            • 3. Re: can't get Premiere tutorials to play
              A.T. Romano Level 7
              Avo
              I did not see your report of success until after I had posted my reply.
              What turned out to be your answer? Was I correct in the expectations explanation or was it something else?
              Never hesitate to ask questions or to ask for explanations.
              Thanks.
              ATR
              • 4. Re: can't get Premiere tutorials to play
                Avo Level 1
                Thank you ATR. I appreciate the quick response! Avo
                • 5. Re: can't get Premiere tutorials to play
                  A.T. Romano Level 7
                  Avo
                  Thanks for the reply.
                  The following link will take you to some Premiere Elements 12 video tutorials that you might want to check out if you have not already.
                  Learn Premiere Elements 12 | Adobe TV
                  We are glad for the opportunity to be of assistance whenever needed.
                  Please update on your progress when you get the chance.
                  Best wishes
                  ATR
