2 Replies Latest reply on Jul 1, 2014 5:09 AM by happifeli
    Adobe Creative Cloud has stopped working
    happifeli
      I receive this error message everytime I try to open CC. It says "A problem caused the program t stop working correctly. Windows will close the program and notify you if a solution is available."
      I'm guessing Windows didn't find a solution because nothing popped up after that and CC just closed.
      I'm using Windows 8.
        • 1. Re: Adobe Creative Cloud has stopped working
          We can't know. You need to provide exact system information and the crash details from the Event Viewer.
          Mylenium
          • 2. Re: Adobe Creative Cloud has stopped working
            happifeli Level 1
            Hi Mylenium,
            Below are the two errors that were generated in the Event Viewer. I would also like to correct above as I am running Windows 8.1 on a 64bit machine.
            Thanks for any help you can provide!
            First Error:
            Windows cannot access the file  for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program Adobe Creative Cloud because of this error.
            Program: Adobe Creative Cloud
            File:
            The error value is listed in the Additional Data section.
            User Action
            1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
            2. If the file still cannot be accessed and
              - It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted.
              - It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer.
            3. Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER.
            4. If the problem persists, restore the file from a backup copy.
            5. Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance.
            Additional Data
            Error value: 00000000
            Disk type: 0
            And the error details are:
            -System
            -Provider
            [ Name] Application Error
            -EventID1005
            [ Qualifiers] 49152
            Level2
            Task100
            Keywords0x80000000000000
            -TimeCreated
            [ SystemTime] 2014-07-01T12:02:14.000000000Z
            EventRecordID57835
            ChannelApplication
            ComputerFeli-PC
            Security
            -EventData
            00000000
            0
            Second Error:
            Faulting application name: Creative Cloud.exe, version: 2.6.0.393, time stamp: 0x5382f671
            Faulting module name: igdusc32.dll, version: 8.15.10.9141, time stamp: 0x52379bbd
            Exception code: 0xc0000096
            Fault offset: 0x0007212c
            Faulting process id: 0x5ec
            Faulting application start time: 0x01cf952442a49184
            Faulting application path: C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe
            Faulting module path: C:\WINDOWS\SYSTEM32\igdusc32.dll
            Report Id: 8997cbb0-0117-11e4-bed0-3085a91aad3c
            Faulting package full name:
            Faulting package-relative application ID:
            -System
            -Provider
            -EventID1000
            [ Qualifiers] 0
            Level2
            Task100
            -TimeCreated
            EventRecordID57834
            ChannelApplication
            ComputerFeli-PC
            Security
            -EventData
            Creative Cloud.exe
            2.6.0.393
            5382f671
            igdusc32.dll
            8.15.10.9141
            52379bbd
            c0000096
            0007212c
            5ec
            01cf952442a49184
