I'm using Presenter 9.0.2 Build 173. It seems this is a new-er problem I have not seen before.
I create "beautiful" layouts in the PowerPoint slide -- but then when I publish to a playable PDF, there are some slides that the layout goes "crazy" -- by adding 'returns' in random places... sometimes only placing one-letter at a time on a line. This seems random to me.
I've imagined there there might be some "invisible" codes inserted into the slide.... so on one specific presentation, I noted the problem areas (from viewing the PDF), and then went back into the "beautifully formatted" slides and re-worked the slide by re-typing the specific lines that went "crazy."
This did not fix the problem (probably because there were no "invisible" codes anyway.)
So OVERALL ... the problem is that -- I can prepare and "beautifully" format my slide deck, but then when I publish to a playable PDF, there are many/multiple slides where the formatting goes "crazy" (certainly not appearing like the original formatting.)
This is a huge problem because, even when I re-work the "crazy" slides, the problem persists. This is also a huge problem because I have NO CONFIDENCE that the work I've completed will appear "beautiful" -- but looks "crazy", wrong, and poorly presented.
Thank you for your help.
Have something to add?
