1. Re: jQuery expander not working on BC. Script conflict?
Liam Dilley Jul 1, 2014 4:25 PM (in response to Jerry @ JBBD)Hi Jerry,
Check your errors:
I noticed your not starting any of your file paths correct so any subfolder access will not work too,
js/..... etc should be /js/..... You need the forward slash in front of things. With so many script files at a glance I could not find where your get request was but check the paths etc.
2. Re: jQuery expander not working on BC. Script conflict?
Jerry @ JBBD Jul 2, 2014 12:01 PM (in response to Liam Dilley)Thanks, Liam ...
1. Turned out the problem was that I hadn't yet uploaded the linked html modules. Once I did, the expander functioned. So it was plain stupidity on my part.
That being said, I'm reluctant to change any js or jQuery because I'm not a developer, just a designer with pretty good HTML and CSS skills. The site is based on a template called "One Click" from themeforest.com.
2. However, I'm noticing that the expander animation is not as smooth on BC as it was on my test server. The movement is a little jumpy and sudden. The same files, scripts, images, etc. I know that BC adds various lines and types of code when it serves a page, so are there any known BC/jQuery/js issues that I should be aware of? As you mentioned with the js/ and /js/ calls?
But most of all, thanks for taking the time to respond to this. I am deeply appreciative.
Thanks!
jerry
www.jbbd.net
