6 Replies Latest reply on Jul 17, 2014 12:48 PM by evan.sante
    ui.dll fix not allowing Lightroom to open anymore?
    JoelandAmber
      I've been having issues with Lightroom crashing on me while editing in the develop module and while flagging in survey mode.  I saw the fix for the ui.dll, but once I installed that, Lightroom won't even open anymore (crashes before it even starts).
      Anyone else have trouble with this and find a workaround?  Not sure if it's the version of Lightroom that's causing the issues (believe I have 5.5 installed).  Any help is appreciated!
      Joel
      Here's the error report that's given after the new ui.dll is installed (and yes, I did rename the old .dll to ui.dll.old):
      Problem signature:
        Problem Event Name: APPCRASH
        Application Name: lightroom.exe
        Application Version: 5.5.0.10
        Application Timestamp: 5391f1ae
        Fault Module Name: MSVCR100.dll
        Fault Module Version: 10.0.40219.1
        Fault Module Timestamp: 4d5f034a
        Exception Code: 40000015
        Exception Offset: 00000000000761c9
        OS Version: 6.1.7601.2.1.0.256.48
        Locale ID: 1033
        Additional Information 1: 70ce
        Additional Information 2: 70ce5170e46e9db2ea1f68f7800deb05
        Additional Information 3: fa46
        Additional Information 4: fa468ff7b0454655a4145f29223f80e1
      System specs:
      Windows 7
      Intel 4820 OC'd to 4.5GHz
      32GB RAM
      1TB SSD
      This was the original error log that caused me to look for the new ui.dll:
      Problem signature:
      Fault Module Name: ui.dll
      Fault Module Version: 5.5.0.10
      Fault Module Timestamp: 5391ed91
      Exception Code: c000041d
      Exception Offset: 000000000010454d
      Locale ID: 1033
      Additional Information 1: 7c4d
      Additional Information 2: 7c4ded5003f4bbfe9c4ce44fcaa4574c
      Additional Information 3: 8d6e
      Additional Information 4: 8d6e6f6c2bda9e9bd465cee19dba6df1
      Also, here are the specs from the System Info in Lightroom:
      Lightroom version: 5.5 [968504]
      Operating system: Windows 7 Business Edition
      Version: 6.1 [7601]
      Application architecture: x64
      System architecture: x64
      Logical processor count: 8
      Processor speed: 4.4 GHz
      Built-in memory: 32706.9 MB
      Real memory available to Lightroom: 32706.9 MB
      Real memory used by Lightroom: 279.2 MB (0.8%)
      Virtual memory used by Lightroom: 247.5 MB
      Memory cache size: 139.6 MB
      Maximum thread count used by Camera Raw: 4
      System DPI setting: 96 DPI
      Desktop composition enabled: Yes
      Displays: 1) 1920x1080
      Application folder: C:\Program Files\Adobe\Adobe Photoshop Lightroom 5.5
      Library Path: C:\Working Drive\Weddings\2014-06-28 Adam and Whitney\LR\Adam & Whitney\Adam & Whitney-2.lrcat
      Settings Folder: C:\Users\Joel and Amber\AppData\Roaming\Adobe\Lightroom
      Installed Plugins:
      1) Behance
      2) Canon Tether Plugin
      3) Facebook
      4) Flickr
      5) Leica Tether Plugin
      6) Nikon Tether Plugin
      Config.lua flags: None
      Adapter #1: Vendor : 10de
        Device : 1187
        Subsystem : 27653842
        Revision : a1
        Video Memory : 1990
      AudioDeviceIOBlockSize: 1024
      AudioDeviceName: Speakers (High Definition Audio Device)
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: Uninitialized
      CardID: 4487
      Direct2DEnabled: false
      GPUDevice: D3D
      MaxTexture2DSize: 8192
      OGLEnabled: true
      Renderer: NVIDIA GeForce GTX 760
      ShaderModel: 11.1
      Vendor: Nvidia
      VendorID: 4318
      Version: 10de:1187:27653842:00a1
