1 Reply Latest reply on Jul 1, 2014 9:42 PM by JJMack
    implementing the traverseLayers function from xtools stdlib.js
    ojodegato Level 1
      I am trying to figure how to make a script which can search for a specific layer name in the layer palette, layer group and nested layer groups.
      I came across the xtools traverse layer function in the sdlib.js which might do the job. How to  implement this function was not clear to me.
      I would like to ask help from the scripting community to figure out how apply to this function to a script. I am not a programer and have basic javascript knowledge.
      thanks in advance
        • 1. Re: implementing the traverseLayers function from xtools stdlib.js
          To process all layer you need to use recursion. And layer names in a document need not be unique you can have many layers with the same name.
          I played around once with a script to look at document layers to get a little better understand as to how Photoshop works.
          // A Photoshop Script by JJMack's
          // This script processes ArtLayers.
          // This script is supplied as is. It is provided as freeware.
          // The author accepts no liability for any problems arising from its use.
          <javascriptresource>
          <about>$$$/JavaScripts/processArtLayers/About=JJMack's Process All Layers.^r^rCopyright 2009 Mouseprints.^r^rScript utility for action.^rNOTE:Deletes Seleted Area from background and all normal layers.</about>
          </javascriptresource>
          //<category>JJMack's Script</category>
          // enable double-clicking from Mac Finder or Windows Explorer
          #target photoshop // this command only works in Photoshop CS2 and higher
          // bring application forward for double-click events
          app.bringToFront();
          // ensure at least one document open
          if (!documents.length) {
            alert('There are no documents open.', 'No Document');
          // if at least one document exists, then proceed
          else {
            app.activeDocument.suspendHistory('processArtLayers','main()');
          // main - main function
          function main() {
            // declare local variables
            var saveactiveLayer = activeDocument.activeLayer;
            // Set the ruler units to PIXELS
            var orig_ruler_units = app.preferences.rulerUnits;
            app.preferences.rulerUnits = Units.PIXELS;
            try {
            processArtLayers(activeDocument);
            removeAllEmptyLayerSets(activeDocument);
            // display error message if something goes wrong
            catch(e) { alert(e + ': on line ' + e.line, 'Script Error', true); }
            try { activeDocument.activeLayer = saveactiveLayer;}
            catch(e) { } // may have been deleted
            // Reset units to original settings
            app.preferences.rulerUnits = orig_ruler_units;
          // End - main function
          // Function: processsArtLayers
          // Input: document or layer set
          // Return: <none>, all layers that were invisible are now gone
          function processArtLayers(obj) {
              for( var i = obj.artLayers.length-1; 0 <= i; i--) {
                  try {
                      processLayer(obj.artLayers[i]);
                  catch (e) {
              for( var i = obj.layerSets.length-1; 0 <= i; i--) {
            infoLayer(obj.layerSets[i]);    // Display layerSet informarion
                  processArtLayers(obj.layerSets[i]);
          // Function: removeAllEmptyLayerSets
          // Usage: find all empty layer sets and remove them, recursively
          // Return: empty layer sets are now gone
          function removeAllEmptyLayerSets(obj) {
              var foundEmpty = true;
                  if( removeAllEmptyLayerSets(obj.layerSets[i])) {
                      obj.layerSets[i].remove();
                  } else {
                      foundEmpty = false;
              if (obj.artLayers.length > 0) {
            foundEmpty = false;
              return foundEmpty;
          function processLayer(layer) {
            infoLayer(layer);
          function infoLayer(layer){
            try{
            alert("layer = " + layer
            + "\rallLocked = " + layer.allLocked
            + "\rblendMode = " + layer.blendMode
            + "\rbounds = " + layer.bounds
            + "\rfillOpacity = " + layer.fillOpacity
          // + "\rfilterMaskDensity = " + layer.filterMaskDensity // undefined for groups not valid others ??
          // + "\rfilterMaskFather = " + layer.filterMaskFeather // undefined for groups not valid others ??
            + "\rgrouped = " + layer.grouped
            + "\risBackgroundLayer = " + layer.isBackgroundLayer
            + "\rkind = " + layer.kind
            + "\rlayerMaskDensity = " + layer.layerMaskDensity
            + "\rlayerMaskFeather = " + layer.layerMaskFeather
            + "\rlinkedLayers = " + layer.linkedLayers
            + "\rname = " + layer.name
            + "\ropacity = " + layer.opacity
            + "\rparent = " + layer.parent
            + "\rpixelsLocked = " + layer.pixelsLocked
            + "\rpositionLocked = " + layer.positionLocked
          // + "\rtextItem = " + layer.textItem // Valid only when kind = LayerKind.TEXT.
            + "\rtransparentPixelsLocked = " + layer.transparentPixelsLocked
            + "\rtypename = " + layer.typename
            + "\rvectorMaskDensity = " + layer.vectorMaskDensity
            + "\rvectorMaskFeather = " + layer.vectorMaskFeather
            + "\rvisible = " + layer.visible
            + "\rxmpMetadata = " + layer.xmpMetadata
            catch(e){
          allLocked               * boolean read-write. true to completely lock the contents and settings of this layer.
          blendMode               * blendmode read-write. the blending mode.
          bounds                  * array of unitvalue read-only. an array of coordinates that describes the bounding rectangle of the layer.
          fillOpacity             * number [0.0..100] read-write. the interior opacity of the layer, a percentage value.
          filterMaskDensity        double read-write. the density of the filter mask (between 0.0 and 250.0)
          filterMaskFeather        double read-write. the feather of the filter mask (between 0.0 and 250.0)
          grouped                 * boolean read-write. true if this layer is grouped with the layer beneath it.
          isBackgroundLayer       * boolean read-write. true if this is the background layer of the document. a document can have only one background layer. if there is no background layer,
                                   setting this to true causes this to become the background layer.
          kind                    * layerkind read-write. sets the type (such as 'text layer') for an empty layer. valid only when the layer is empty and when isbackgroundlayer.
                                   you can use the kind property to make a background layer a normal layer; however, to make a layer a background layer, you must set isbackgroundlayer to true.
          layerMaskDensity        * double read-write. the density of the layer mask (between 0.0 and 100.0)
          layerMaskFeather        * double read-write. the feather of the layer mask (between 0.0 and 250.0)
          linkedlayers            * array of artlayer or layerset read-only. the layers linked to this layer. see artlayer.link.
          name                    * string read-write. the name.
          opacity                 * number [0.0..100.0]. read-write. the master opacity of the layer, a percentage value.
          parent                  * document read-only. the object's container.
          pixelsLocked            * boolean read-write. true if the pixels in the layer’s image cannot be edited using the paintbrush tool.
          positionLocked          * boolean read-write. true if the pixels in the layer’s image cannot be moved within the layer.
          textitem                 textitem read-only. the text item that is associated with the layer. valid only when kind = layerkind.text.
          transparentpixelslocked * boolean read-write. true if editing is confined to the opaque portions of the layer.
          typename                * string read-only. the class name of the referenced artlayer object.
          vectorMaskDensity       * double read-write. the density of the vector mask (between 0.0 and 250.0)
          vectorMaskFeather       * double read-write. the feather of the vector mask (between 0.0 and 250.0)
          visible                 * boolean read-write. true if the layer is visible.
          xmpMetadata             * xmpmetadata read-write. metadata for the layerb
