1 Reply Latest reply on Oct 20, 2014 5:01 AM by Erez Inchy
    FlashBuilder 4.7 command line fails due to "Exception in com.adobe.flexbuilder.codemodel.CMCoreActivator.start() of bundle"
    Erez Inchy
      I'm facing this issue:
      When I use FB 4.7 GUI, everything works OK.
      When I use FB 4.7 command line, it fails as follows:
      • org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.codemodel.CMCoreActivator.start() of bundle com.adobe.flexbuilder.codemodel.
      By the way, I’ve overlaid FB 4.7 with AIR SDK 14 (which works fine in GUI).
      By the way2, I think the following thread reports exactly the same issue but is yet not answered:
      https://forums.adobe.com/thread/1445134
      here is the XML:
      <?xml version="1.0"?>
      <project default="main">
          <target name="main">
               <echo message="Info: Starting main target"/>
              <fb.exportReleaseBuild project="888PokerAndroid_3_2_0" destdir="c:\temp\erez_test" platform="android" verbose="true" android.password="poker" packagetype="platform" />
          </target>
      </project>
      it works fine in the GUI.
      any ideas?
      here is how I run it:
      C:\FB\mobile_Android_3.2.0_WS1>"C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\FlashBuilderC.exe" --launcher.suppressErrors -noSplash -application org.eclipse.ant.core.antRunner -data "C:\FB\mobile_Android_3.2.0_WS1" -file "c:\FB\build_888PokerAndroid_3_2_0.xml" main
      Buildfile: c:\FB\build_888PokerAndroid_3_2_0.xml
      main:
           [echo] Info: Starting main target
      [fb.exportReleaseBuild] Compiling 1 application to C:/GamingX/Develop/PokerClient/Flash/ProjectSources/888PokerAndroid/v3.2.99/bin-release-t emp...
      [fb.exportReleaseBuild] An internal build error has occurred. See the error log for more information: C:\FB\mobile_Android_3.2.0_WS1\.metadata\.log
      [fb.exportReleaseBuild] [compilation completed 3,816ms]
      BUILD FAILED
      c:\FB\build_888PokerAndroid_3_2_0.xml:5: Build failed.
      Total time: 6 seconds
      Job found still running after platform shutdown.  Jobs should be canceled by the plugin that scheduled them during shutdown: com.microsoft.tfs.client.common.ui.helpers.WorkbenchHelper$WorkbenchStartupJob
      Job found still running after platform shutdown.  Jobs should be canceled by the plugin that scheduled them during shutdown: com.microsoft.tfs.client.eclipse.TFSRepositoryProvider$1
      Job found still running after platform shutdown.  Jobs should be canceled by the plugin that scheduled them during shutdown: com.microsoft.tfs.client.eclipse.TFSEclipseClientPlugin$1
      F l a s h B u i l d e r C :
      A n   e r r o r   h a s   o c c u r r e d .   S e e   t h e   l o g   f i l e
      C : \ F B \ m o b i l e _ A n d r o i d _ 3 . 2 . 0 _ W S 1 \ . m e t a d a t a \ . l o g .
      any suggestions?
      thanks,
      Erez.
