Is this possible ?
Installation of CF9 32 bits on Win7 64bits ?
I did it, with CGI and ISAPI for IIS7.
IIS 7 is OK, (http://127.0.0.1 is correct)
After CF9 install, I ran the WebServer ConfigurationTool
http://127.0.0.1 gives an error 500 :
then I uninstall C F9 , now I have a 404.2 error
I looked in install recommandation on the web (google).
I think I did the right way.
Then I am wondering if this is a question of 32bits and 64 bits ?
Thanks for urgent Help.
(I have an other PC with CF9 32bits on Win7 32bits, it is OK
and a CF9 64bits on Windows serveur 2008 64bits, it is OK)
Pierre.
Can you ensure that the Application pool is also running in 32-bit mode.
plarts wrote:
Is this possible ?
Pierre.
That seems to be the problem.
Regards,
Anit Kumar
I will try CF9 64 bits on Win 7 64 bits
or ask for a PC with win 7 32 bits.
( I already have each config, I have less problems with 32bits)
Then I will see if installation is successfull.
Pierre.
Hi, I did install CF9 64bits
And I have the Error 404.3
The page you are requesting cannot be served because of the extension configuration. If the page is a script, add a handler. If the file should be downloaded, add a MIME map.
I recap installation steps :
- Configure IIS7
- Install CF9 64bits
- I get the 404.3 Error when accessing the CF admin
- Running "web server configuration tool"
get the error : "jrun_iis6_wildcard.dll" not found
- Looking for that file : It does not exist, instead I have : jrun_iis6.dll
- Checking the MIME Map, there is no .cfm extension and others (.cfc etc...)
Then Do I have to make it manually ?
Declare all MIME map in IIS7 ?
I do not understand why the configuration tool is looking for : jrun_iis6_wildcard.dll
Thank for urgent help, this installation need to be done at a client.
Pierre.
ColdFusion 9.0 is not supported with IIS 7/7.5. ColdFusion 9.0.1 updater adds support for IIS 7/7.5. Kindly update your ColdFusion with 9.0.1 updater and then try the connector.
Please see What's new in ColdFusion 9.0.1 | Adobe Developer Connection.
Regards,
Anit Kumar
