3 Replies Latest reply: Jul 7, 2014 7:55 AM by Sanjit_Das RSS
    Individual transition and playtimes in a diasshow - how ?
    Tåbeligt Community Member
      Hi
      As the headline says - how do I make a diasshow, where I can adjust the transition times and the play duration time individually - slide by slide ?
      Greetings
      Sten Søndergaard
        • 1. Re: Individual transition and playtimes in a diasshow - how ?
          Sanjit_Das Employee Hosts
          You can specify the transition speed and resume speed along with autoplay for any slideshow from slideshow options.
          Sanjit
          • 2. Re: Individual transition and playtimes in a diasshow - how ?
            Dear Sanjit
            Thanks for your answer, but I don't think you understand the question - or I'm too dumb to understand your answer. Well - in both cases it don't work for me.
            I can adjust transition and duration speed in any slidehow. Thats correct, but I can't specify the settings for each slide in the slideshow individually.
            My idea is for example to set transition speed for slide nr. 1 to 0,5 sec and duration 2 sec. For slide nr. 2 I want a transition time set to 3 sec and duration 5 sec.
            But when I change the settings for slide nr. 2, the changes also affects slide nr. 1.
            The slideshow does only allow one and the same transition setting and one and the same duration setting for all slides in the slideshow - as I see it.
            So - how do I make individually settings for all the slides ?
            Looking forward to hera from you again.
            Sten
            • 3. Re: Individual transition and playtimes in a diasshow - how ?
              Hi Sten
              Thanks for the details !
              We cannot setup transition and resume differently for multiple images in same slide, it would be same for all images in the slideshow.
              You can surely add your suggestion in our ideas section.
              Sanjit
